센서 > Prototyping the RADARduino
TODAY536 TOTAL2,225,270
BASIC4MCU | 센서 | RADAR | Prototyping the RADARduino
작성자 키트 작성일2017-08-30 16:16 조회1,521회 댓글0건
Reactance Labs
Main menu
Post navigation
 PreviousNext
UPDATE: February 3, 2014:  The RADARduino has received a commodity classification from the Department of Commerce as 6A008.b.  Since the design itself will be open source, all of the technology will be freely available.  Check back here for more details soon.
For those of you who read IEEE Spectrum magazine, this month’s edition includes an article called “Coffee-Can Radar” which details author David Schneider’s experiences in building a short range radar based on the work of Dr. Gregory Charvat, who in 2011 taught a short course at MIT on Cantenna Radars.  This course has spread to other institutions including to the University of California Davis, University of Vermont, Michigan State University, MIT Lincoln Labs, etc.
Dr. Charvat’s FMCW (frequency modulated continuous wave) radar project uses a collection of connectorized Mini-Circuits components for the RF section, and several traditional components on a breadboard for the back end processing and VCO (voltage controlled oscillator) control.  Antennas are of the “cantenna” type, and the whole system operates in the 2.4 GHz band with an output power of ~ 10 mW.
I decided that this project called for a kit version built on a single printed circuit board.  So I started thinking about how to modify the project to expand on Dr. Charvat’s work, as well as provide backwards compatibility.
In thinking about ways to expand the usability of the radar, I decided that instead of controlling the VCO with a ramp generator chip, I’d use an Arduino microcontroller with a DAC (digital to analog converter).  This allows for the arbitrary generation of radar waveforms and frequency chirps, in addition to USB computer interface.
The first major component change was to integrate the RF components, which meant finding suitable surface mount parts for the LNA (low noise amplifier), mixer, VCO, buffer amplifier, and power splitter.  At this stage I decided to increase the frequency to the 5.8 GHz band which allows for the use of smaller antennas.
On the back end, I switched from a discrete anti-aliasing filter to an integrated part, and added a boost converter to generate the +12V required to control the VCO over its usable range.
This past week, we started assembly of the first prototypes, which are nearly ready for testing.
The first part of the assembly is the surface mount RF components.  It is planned that this portion of the circuitry will come pre-assembled, as there are too few people with reflow soldering capabilities, and packaging SMT components is time consuming.
Spreading solder paste onto one of the boards using a Kapton stencil
Solder paste applied to the SMT pads
Alex KJ6WIL placing SMT components on the three prototype boards
SMT parts populated and ready for the oven
Prototype boards undergoing reflow using an OSPID controller and a hacked toaster oven
Nearly complete prototype next to an Arduino (VCO is missing, will be installed soon)
The radar stacked on an Arduino
As was mentioned in the caption, the VCO is missing.  Digikey sent the wrong part, but tomorrow the right ones should arrive and will be installed.  We are looking forward to the next stage which will be to fire it up and see what problems or issues we may run into.  RF is never easy to get right the first time!
-Tony KC6QHP
This entry was posted in Uncategorized by Tony. Bookmark the permalink.
40 THOUGHTS ON “PROTOTYPING THE RADARDUINO
조회수 1,521
센서HOME > 센서 > 전체 목록
