센서 > 터치스위치
TODAY276 TOTAL2,220,505
BASIC4MCU | 센서 | 기타센서 | 터치스위치
작성자 키트 작성일2017-09-04 15:02 조회2,123회 댓글0건
7413 CD4069 1N914 circuit : CMOS TOUCH SWITCH
7413 src800){this.height=this.height*800/this.width;this.width=800;}" border=0>
7413 CD4069 1N914
 This touch switch does not rely on mains hum for switching. It can be used with battery powered circuits. Schmitt trigger IC1 forms a I 100 kHz oscillator and IC2a which is biased into the linear region, amplifies the output and charges C1 via the diode. IC2b acts as a level detector. When the sensor is touched, the os-cillator signal is severely attenuated which causes C1 to discharge and IC2b to change state.
Touch Switch
Here is a touch switch that can be used to drive LEDs, relays etc through a buffer transistor stage. It may be built around any CMOS inverter chip. but preferably, around 4069 IC. The 4069 can be run off any regulated DC supply from +3V up to +15V.
touch switch circuit diagram
PARTS LIST
R*100Ω (For 9V)
D1IN4148
D2IN4148
D3IN4148
T1BC148
IC14069
S1Push Button Switch
RL1RELAY
When there is no connection between the pair of touch contacts wired in the circuit, the input of N1 is low and thus its output is high, which makes the input of N2 high and output low. thus no current flows through D1 and D2 in this condition.
When the contacts are bridged by a finger, N1’s input becomes high and it’s output becomes low: making the output of N2 high. Diode D1 now conducts and feeds a return pulse to the input of N1, thus effectively latching the circuit in the ‘on’ state. The output of N2 is fed through a buffer transistor state and switches on a relay, LED etc.
As 4069 (or 7404) IC has six such stages in it, three switches of this type can be made from each. Resistor R is used just to lessen the load on the battery and the transistor. For 9V power supply, vaule of R should be about 100 ohms. Values of R for other supply voltages (Vcc) can be derived form the relationship
R=( 1000 * Vcc )/Im
where Im is the relay’s current rating in mA. Since about of 100mA should be drawn from the power supply, a 100mA relay of appropriate voltage (say, 12V) may be selected for use.
http://www.electronicecircuits.com/electronic-circuits/touch-switch/
Touch Switch Monostable/Timer with 555 IC
A schematic diagram of a touch switch circuit is shown below. This circuit consist of timer, one shoot multivibrator and touch terminal. As timer, this circuit uses 555 timer which is connected to one-shot multivibrator. The touch terminal is used to trigger this circuit. The output of this  circuit can be used to drive a power transistor, CMOS circuitry, hexFET transistor or optocoupler. Here is the schematic diagram of the touch switch circuit:
Touch Switch II circuit schematic
Using the given values as shown in the schematic diagram, this circuit has timed ON period of 4 seconds. The value of C2 and R3 determines the ON time, increasing the value of C2 or R3 will increase the ON time. The ON time is decreased if the value of C2 or R3 is decreased.
http://freecircuitdiagram.com/2011/04/04/touch-switch-monostabletimer-with-555-ic/
Simple Touch Switch One Shot by 4011
Here is a simple touch control switch, I use IC 4011.
Logic HI at output is timer pulse delay control by C1
1S = C1 4.7uF(micro farad),
After touching the plate connected,so well pulse output.
Detail more, Please read in this image circuit.
3660040653_fbMOixjq_9772d1160686023-newbie-question-pulse-off-switch-alternate-action.gif
3660040653_ZyJn2rIR_images3Fq3Dtbn3AANd9GcQ1txmG_HYdcz_K3_Xe7CWi_DAdTu841GJQeXMgOBeX3NEsplWYq45vuC4 3660040653_S37Lghmd_images3Fq3Dtbn3AANd9GcTVC1uSlw4mIkTLN0CZVZIOMROyUR4DPUUijsNfnaH3rmMLlNcSaKCjxg 3660040653_IdYgWrja_images3Fq3Dtbn3AANd9GcR5-6o8dfbIKE0ZpV5fRBGaCi4KhEVAm_GsYz2pv8iHR9ipj5mdS6w8dmep 3660040653_oVBISEp1_images3Fq3Dtbn3AANd9GcTqIZIHf2GYEkgQ20Of4L63z54Xfmv9vk9QvP292N4c11bKS6hAm9xpUQ64dg 3660040653_gc9Jry3P_images3Fq3Dtbn3AANd9GcS7M9r6w7gylpvi2Ops8ptIH_GdWBunUwr1uuOoMh9PnQHdcVp0peDn6A 3660040653_BJFzY5bT_images3Fq3Dtbn3AANd9GcRV5Q3MTM4r2Vew5caogUN_HMec3GQ9PsThLLav9SabLozazCAz8TfT4HU
Touch Switch with 555 –
425 * 400 - 6k - gif
electroschematics.com
ON-OFF TOUCH SWITCH USING A
375 * 320 - 5k - gif
talkingelectronics.com
On Off Touch Switch
514 * 378 - 7k - gif
6MM LIGHT TOUCH SWITCH 250GF
640 * 640 - 89k - jpg
kr.digikey.com
A rectangular switch with a
270 * 220 - 18k - jpg
novitatech.org.au
터치 스위치를 손가락으로 톡톡
550 * 413 - 50k - jpg
enjoyitaewon.com
3660040653_5iRfWKYv_images3Fq3Dtbn3AANd9GcStOQ4BiLKlamXhS4AE6JS5DFlj3BK4zxMD1KczfuLTNwozRY6dWJvKWgxv 3660040653_xoTLUXjb_images3Fq3Dtbn3AANd9GcSu7i7ntEFfHIu3eTAp5PlqeTo_rI-QsiMQYPn2md-ZkTPGoOvYpuuC9Usq 3660040653_1a7WfnZX_images3Fq3Dtbn3AANd9GcSP-amD2ZYJLp4wEmsP4wpC5sXjZRHPoQXpXOkKKWcK0Wnexgz2x246l9Q 3660040653_6s9z0P32_images3Fq3Dtbn3AANd9GcTzT5evr_pCwf_FyqOuCraW4CsQ32OQKUM5nSF3paQx5cMhVMyZTfEqCnc 3660040653_65Ombawg_images3Fq3Dtbn3AANd9GcS4rh4MqxW1FHp5O0EZoG22QcNwMm66xno17GIkg3rXPTfS-xkzteq7Qro 3660040653_BZPefyJL_images3Fq3Dtbn3AANd9GcTHI4jVYltqBnC53oD9spBEjj-phkgqpDqI8LOdY6O4Ms6giicXJV3p6ztM
Touch Switch
470 * 290 - 7k - gif
touch-switch-circuit-using-
588 * 355 - 32k - jpg
circuitstoday.com
Touch Switch Circuit Diagram
962 * 596 - 62k - jpg
circuitstoday.com
of the touch switch is a
240 * 192 - 2k - gif
bytecraft.com
A touch switch is a useful
352 * 281 - 10k - gif
electronicidea.blogspot.com
Touch Switch And Delay Circuit
367 * 512 - 14k - gif
electronics-project-design.com
3660040653_2xub5hQf_images3Fq3Dtbn3AANd9GcTQGtq0VCs1BPKGvbrfiVArnIjUTlm8o9UltysScsmaRdvQriNObkn3dEjN 3660040653_the3AU9u_images3Fq3Dtbn3AANd9GcQRz0lwv1oquEAbmcUdfwBUIdVVOIajqgCFHNvnWMjDeYpI83pvTIw0WMM 3660040653_Nmz1ABCH_images3Fq3Dtbn3AANd9GcTOUGHVtlOlndHtfYLj7SLfMwTG42swCFkwYD-AMoPcjeAarydI_-wjwA 3660040653_HGTxwUZ4_images3Fq3Dtbn3AANd9GcS6BLzC6_rltDouiS6TrFIZccULCM1dYmTm9jqghXkeAI91Jrjkm3PVQ6EcQw 3660040653_8OFIKPxl_images3Fq3Dtbn3AANd9GcT8zinNCFI6sVpjcXi3fFzOpLWaqA8ZM_z2_F_ql2hwAm5bRXXt_HsvVow 3660040653_ixqUIfmC_images3Fq3Dtbn3AANd9GcQLkBsTDxlEC34QJt_U_a1ecZNVgnfQPWR1sbkbQWlzzQAotnmzpyGkUZ8
The Touch Switch circuit above
499 * 323 - 7k - gif
tech-electronic.blogspot.com
Touch switch project
549 * 357 - 12k - gif
afiata.com
Touch switch
400 * 309 - 48k - gif
SWITCH
640 * 640 - 141k - jpg
kr.digikey.com
Touch Sensitive Switch
649 * 351 - 9k - gif
softwareforeducation.com
Touch Switch Control
568 * 395 - 9k - gif
users.otenet.gr
http://www.google.co.kr/images?um=1&hl=ko&newwindow=1&tbm=isch&sa=1&q=touch+switch&aq=f&aqi=&aql=&oq
조회수 2,123
센서HOME > 센서 > 전체 목록
