BASIC4MCU | 센서 | 기타센서 | Light Following Robot
작성자 키트 작성일2017-09-04 16:12 조회1,834회 댓글0건본문
By iRFAN @ December 15, 2012Light Following Robot without using microcontroller. This wheeled robot does not avoid collision. It runs towards the light or just brighter areas.
- Control method: non-autonomous,moves toward the light or bright areas
- Sensors / input devices: 9 volt Battery.,2x LDR, 2x BC547 Transistors, 2x 2 x 30 ohms Resistors, 2 x Gear motor wheels,1 x multi-directional wheel
- Target environment: indoor
The gear motor wheels, multi-directional wheel and the plastic sheet. I cut out 6 x 13 cm plastic for base.
Glued the wheels to make the body and connected the motors to the components.
After its completed.
Robot Schematic
조회수 1,834등록된 댓글이 없습니다.
