아두이노 > tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module
TODAY1,264 TOTAL951,733
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module
작성자 키트 작성일2017-09-13 14:40 조회989회 댓글0건
Arduino KY-033 Hunt sensor module
WARNING this page is a copy/past of a bad google translation so it might contain errors. If you see a error help us to make it better and log in and change it. Big thanks!
Arduino KY-033 Hunt sensor module Sku 118057 2
Buy on Dealextream
analog Hall magnetic sensor module
Analog magnetic sensor module and a digital interface, built-in 13 LED build a simple circuit to produce a magnetic flash Makers.13 comes with digital interfaces of the LED, the analog magnetic sensor connected to the power board analog 5 ARDUINO Interfaces, when analog magnetic sensor to a signal, LED lights, otherwise the lights out.
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
int sensorPin = A5; // select the input pin
int ledPin = 13// select the pin for the LED
int sensorValue = 0// variable to store the value coming from the sensor
void setup () {
  pinMode (ledPin, OUTPUT);
  Serial.begin (9600);
void loop () {
  sensorValue = analogRead (sensorPin);
  digitalWrite (ledPin, HIGH);
  delay (sensorValue);
  digitalWrite (ledPin, LOW);
  Serial.println (sensorValue, DEC);
cs
조회수 989
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1043
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1024
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1205
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 971
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 917
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 990
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 880
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1108
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1040
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1064
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1113
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1164
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 978
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1083
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 956
MCU BASIC ⓒ 2019
