아두이노 > tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing colorful LED module
TODAY930 TOTAL1,145,720
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing colorful LED module
작성자 키트 작성일2017-09-13 14:41 조회1,016회 댓글0건
Arduino KY-034 Automatic flashing colorful LED module
WARNING this page is a copy/past of a bad google translation so it might contain errors. If you see a error help us to make it better and log in and change it. Big thanks!
Part of Dealextream 37 sensors in a 1 kit
7 color flashing LED module automatically
7 color flashing LED module automatically uses 5mm round high-brightness light-emitting diode which has the following characteristics:
Specifications
  • Product Type: LED
  • Product Model: YB-3120B4PnYG-PM
  • Shape: Round LED 5mm DIP type
  • Color: pink yellow green (high brightness)
  • Lens type: white mist
  • Standard Forward Voltage :3.0-4 .5 V
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
Blink
Turns on an LED on for two second, then off for two second, repeatedly.
This example code is in the public domain.
void setup () {
  // Initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode (13, OUTPUT);
void loop () {
  digitalWrite (13, HIGH); / / set the LED on
  delay (2000); / / wait for a second
  digitalWrite (13, LOW); / / set the LED off
cs
https://tkkrlab.nl/wiki/Arduino_KY-034_Automatic_flashing_colorful_LED_module
조회수 1,016
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1183
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1129
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1379
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 1089
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 1017
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 1095
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 982
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1222
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1162
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1182
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1261
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1343
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 1103
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1247
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 1075
