아두이노 > tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic sensor
TODAY906 TOTAL1,145,696
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic sensor
작성자 키트 작성일2017-09-13 14:41 조회1,088회 댓글0건
Arduino KY-035 Class Bihor magnetic sensor
Part of Dealextream 37 sensors in a 1 kit
analog Hall magnetic sensor module
KY-035 is an analog magnetic field sensor module. The strength of the field is given by an analog voltage at the signal pin of the module KY-035. The sensor is connected to gnd and 5V of the Arduino board. The output voltage is measured by analog pin A5 on the Arduino board.
The example program measures the output voltage of the sensor en presents the measured value in the serial monitor of the Arduino.
The led on the board flashes in a speed depending on the strength of the magnetic field. With a small magnet this can be demonstrated.
Connecting to the Arduino
  • Pin - = GND, connect to GND of the Arduino
  • Pin (middle pin) +5 V, connect to Arduino +5 V
  • Pin S signal, connect to Arduino pin A5
  • Power consumption sensor, 8 mA
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
KY-035 Hall analog sensor
int sensorPin = A5;    // select the input pin
int ledPin = 13;       // select the pin for the LED
int sensorValue = 0;   // variable to store the value coming from the sensor
void setup () {
  pinMode (ledPin, OUTPUT);
  Serial.begin (9600);
void loop () {
  sensorValue = analogRead (sensorPin);
  digitalWrite (ledPin, HIGH);
  delay (sensorValue);
  digitalWrite (ledPin, LOW);
  Serial.println (sensorValue, DEC);
cs
https://tkkrlab.nl/wiki/Arduino_KY-035_Class_Bihor_magnetic_sensor
조회수 1,088
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1183
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1129
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1379
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 1089
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 1016
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 1095
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 982
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1221
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1162
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1182
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1261
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1343
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 1103
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1247
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 1075
