아두이노 > tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor module
TODAY870 TOTAL1,145,660
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor module
작성자 키트 작성일2017-09-13 14:41 조회1,378회 댓글0건
Arduino KY-036 Metal touch sensor module
WARNING this page is a copy/past of a bad google translation so it might contain errors. If you see a error help us to make it better and log in and change it. Big thanks!
Arduino KY-036 Metal touch sensor module Sku 121514 1
Buy on Dealextream
KEYES ARDUINO touch module
Metal Touch Interface module and number 13 comes with LED build a simple circuit to produce a touch cue lights 13 comes with digital interfaces of the LED, the metal touch sensor connected digital three interfaces, when a metal touch Sensor senses a key signal, LED ights, otherwise off.
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
int Led = 13 ; // define LED Interface
int buttonpin = 3// define Metal Touch Sensor Interface
int val ; // define numeric variables val
void setup ()
  pinMode (Led, OUTPUT) ; // define LED as output interface
  pinMode (buttonpin, INPUT) ; // define metal touch sensor output interface
void loop ()
  val = digitalRead (buttonpin) ; // digital interface will be assigned a value of 3 to read val
  if (val == HIGH) // When the metal touch sensor detects a signal, LED flashes
    digitalWrite (Led, HIGH);
    digitalWrite (Led, LOW);
cs
https://tkkrlab.nl/wiki/Arduino_KY-036_Metal_touch_sensor_module
조회수 1,378
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1183
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1129
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1379
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 1088
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 1016
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 1095
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 982
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1220
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1162
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1182
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1260
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1343
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 1103
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1247
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 1075
