아두이노 > tkkrlab - Arduino 37 sensors - KY-038 Microphone sound sensor module
TODAY990 TOTAL1,135,844
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-038 Microphone sound sensor module
작성자 키트 작성일2017-09-13 14:42 조회1,178회 댓글0건
Arduino KY-038 Microphone sound sensor module
Arduino KY-038 Microphone sound sensor module Sku 135533 1
Buy on Dealextream
Microphone sound detection module
For sound detection Module has two outputs:
  1. AO, analog output, real-time output voltage signal of the microphone
  2. DO, when the sound intensity reaches a certain threshold, the output high and low signal
The threshold-sensitivity can be adjusted via potentiometer on the sensor
Connecting to the Arduino
  • Pin + to Arduino 5+
  • Pin - to Arduino -
  • Pin A0 to Arduino A0 (for analog program)
  • Pin D0 to Arduino 13 (for digital program)
Example code: Digital output
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
int Led = 13 ;// define LED Interface
int buttonpin = 3// define D0 Sensor Interface
int val = 0;// define numeric variables val
void setup ()
  pinMode (Led, OUTPUT) ;// define LED as output interface
  pinMode (buttonpin, INPUT) ;// output interface D0 is defined sensor
void loop ()
  val = digitalRead(buttonpin);// digital interface will be assigned a value of pin 3 to read val
  if (val == HIGH) // When the sound detection module detects a signal, LED flashes
    digitalWrite (Led, HIGH);
    digitalWrite (Led, LOW);
cs
Example Code : analog outputs
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
int sensorPin = A0; // select the input pin for the potentiometer
int ledPin = 13// select the pin for the LED
int sensorValue = 0// variable to store the value coming from the sensor
void setup ()
  pinMode (ledPin, OUTPUT);
  Serial.begin (9600);
void loop ()
  sensorValue = analogRead (sensorPin);
  digitalWrite (ledPin, HIGH);
  delay (sensorValue);
  digitalWrite (ledPin, LOW);
  Serial.println (sensorValue, DEC);
cs
https://tkkrlab.nl/wiki/Arduino_KY-038_Microphone_sound_sensor_module
조회수 1,178
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1179
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1123
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1373
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 1084
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 1011
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 1092
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 974
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1217
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1159
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1180
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1256
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1338
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 1100
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1239
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 1071
