아두이노 > Arduino - Midi
TODAY1,420 TOTAL1,075,988
BASIC4MCU | 아두이노 | 아두이노 | Arduino - Midi
작성자 키트 작성일2017-09-11 16:24 조회1,048회 댓글0건
Learning   Examples | Foundations | Hacking | Links
Examples > Communication
MIDI Note Player
This tutorial shows how to play MIDI notes from an Arduino.
MIDI, the Musical Instrument Digital Interface, is a useful protocol for controlling synthesizers, sequencers, and other musical devices. MIDI devices are generally grouped in to two broad classes: controllers (i.e. devices that generate MIDI signals based on human actions) and synthesizers (including samplers, sequencers, and so forth). The latter take MIDI data in and make sound, light, or some other effect.
MIDI is a serial protocol that operates at 31,250 bits per second. The Arduino's built-in serial port (all of them on the Mega as well) can send data at that rate.
MIDI bytes are divided into two types: command bytes and data bytes. Command bytes are always 128 or greater, or 0x80 to 0xFF in hexadecimal. Data bytes are always less than 127, or 0x00 to 0x7F in hex. Commands include things such as note on, note off, pitch bend, and so forth. Data bytes include things like the pitch of the note to play, the velocity, or loudness of the note, and amount of pitch bend, and so forth. For more details, see the MIDI specification, or one of the many MIDI Protocol Guides on the Web.
MIDI data is usually notated in hexadecimal because MIDI banks and instruments are grouped in groups of 16.
For more see this introduction to MIDI or this example.
Hardware Required
  • Arduino UNO
  • (1) MIDI jack
  • (1) 220 ohm resistor
  • hook-up wire
  • MIDI enabled device (optional, for testing)
Attention
Since Serial object is used to use this tutorial with 32u4 based boards like Leonardo, replace Serial with Serial1
Circuit
All MIDI connectors are female, by definition of the MIDI spec. Here's how to wire the connector to the Arduino:
  • Arduino digital pin 1 connected to MIDI jack pin 5
  • MIDI jack pin 2 connected to ground
  • MIDI jack pin 4 connected to +5V through 220-ohm resistor
click the image to enlarge
image developed using Fritzing. For more circuit examples, see the Fritzing project page
Schematic
Code
 MIDI note player
 This sketch shows how to use the serial transmit pin (pin 1) to send MIDI note data.
 If this circuit is connected to a MIDI synth, it will play
 the notes F#-0 (0x1E) to F#-5 (0x5A) in sequence.
 The circuit:
 * digital in 1 connected to MIDI jack pin 5
 * MIDI jack pin 2 connected to ground
 * MIDI jack pin 4 connected to +5V through 220-ohm resistor
 Attach a MIDI cable to the jack, then to a MIDI synth, and play music.
 created 13 Jun 2006
 modified 13 Aug 2012
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/Midi
void setup() {
  //  Set MIDI baud rate:
  Serial.begin(31250);
void loop() {
  // play notes from F#-0 (0x1E) to F#-5 (0x5A):
  for (int note = 0x1E; note < 0x5A; note ++) {
    //Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
    noteOn(0x90, note, 0x45);
    //Note on channel 1 (0x90), some note value (note), silent velocity (0x00):
    noteOn(0x90, note, 0x00);
//  plays a MIDI note.  Doesn't check to see that
//  cmd is greater than 127, or that data values are  less than 127:
void noteOn(int cmd, int pitch, int velocity) {
  Serial.write(cmd);
  Serial.write(pitch);
  Serial.write(velocity);
See Also:
조회수 1,048
아두이노HOME > 아두이노 > 전체 목록
