아두이노 > Arduino and real time charts in Excel
TODAY1,064 TOTAL1,135,918
BASIC4MCU | 아두이노 | 아두이노 | Arduino and real time charts in Excel
작성자 키트 작성일2017-09-13 15:37 조회1,533회 댓글0건
Posts Tagged Serial Port
One of the most important things in the robot design is the possibility to check and control the values feeded by the analogic sensors, i.e. accelerometers, gyros, IR sensors.
In order to view the sensor values you can use the Serial Port that can be displayed in the Serial Monitor inside the Arduino IDE environment.
But it isn’t possible to show charts or save the data read from the sensors.
There are several software that allow to show the graphs derived from the sensors data, and I published in the past a tutorial (here).
Usually you use Processing or similar language that require always to write some code. You have to write code to change the charts or to implement new lines in the graphs.
I thought that the ideal situation would be to use a software that everyone knows: Microsoft Excel.
If it were possible to use Excel to receive the data from the serial port, it would be easy to make very nice and user friendly charts.
I searched in Google and i found a sw that allows easily to view the serial port values in Excel.
The sw is made by a competitor of Arduino, Parallax, the company that sells the Boe-Bot and the Propeller, wich are in direct competition with Arduino.
The sw is called PLX-DAQ and it is a free software. You can download it here. It works only in Windows, sorry.
In practice it is a little sw in VBA that adds some features to Excel to receive and elaborate real time data. If the data are in Excel it is also possible to save them in a file and it is possible to use the amazing function library already present in the spreadsheet software. The documentation about PLX-DAQ is complete and clear.
The PLX-DAQ takes commands in uppercase and every data row have to end with a ‘carriage return’. The serial port speed required by PLX-DAQ is particular, because it derives from Parallax world. In any case the rate is from 9600 bit/sec to 128.000 bit/sec. The speed of 128.000 bit/sec works fine in the Arduino!!
The main commands are:
  • LABEL used to define the column headings. The command format is:  Serial.println (“LABEL, INT_COLUMN”);
  • DATE, TIME that allows the serial port to send data to Excel. The first field is always TIME, then the fields of interest (val). The command format is:  Serial. print (“DATE, TIME,”);  Serial.println (val)
  • ROW, SET, k,  which allows you to define the next line to write. It is useful if you want to plot n data and then go back to first row and cycle. For example, you can plot 1000 data on the chart and then start again from the first position, in order to avoid a graph too large. The command format is: Serial.println (ROW, SET, 2) put the cursor in the second line next step.
Here’s an example that shows Excel function sin (x).
The Arduino code:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
int x = 0;
int row = 0;
void setup() {
  Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
  Serial.println("CLEARDATA");
  Serial.println("LABEL,Time,x,sin(x)");
void loop() {
  Serial.print("DATA,TIME,"); Serial.print(x); Serial.print(","); Serial.println(sin(x*PI/180));
  row++;
  x++;
  if (row > 360
    row=0;
    Serial.println("ROW,SET,2");
cs
PLX-DAQ enable a more complex interaction with Excel. It can take the cell values from Excel, it can read and write check box. You can see the PLX-DAW documentation for other details.
Tags: graphicplotSerial Port
Charting data sent via serial port in real time
Often it is needed to chart in real time the values coming from the serial port (RS-232). In Arduino environment it is a common need. If you have some values, only one possibility is offered by the Arduino IDE: to use the serial monitor. But on the serial monitor, the values are textual and also they are difficult to read during the elaborations. You can use Processing, but Processing is complicated when you like to show many graphics or when you like to see graphic and text values, when you like to customize the graphic. You must program in Java.
I discovered a simple tool made with QT graphic libraries, that needs only a light parametrization for plotting in an easy way the serial values. The sw is SERIALCHART.
Easily it is possible to customize the graphic and modify the colors without become crazy. The sw is explained here. You have to use also an easy configuration file explained here.
I made a test to see in a graphic the values read by a 3-axis accelerometer wired to an Arduino.
The code to read 3 axis from Arduino is very easy:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
// read x,y,z accelerometer values
// set input variables
int analogInput0 = 0;
int analogInput1 = 1;
int analogInput2 = 2;
// store input variables
int value0 = 0;
int value1 = 0;
int value2 = 0;
// set input pins
pinMode(analogInput0, INPUT);
pinMode(analogInput1, INPUT);
pinMode(analogInput2, INPUT);
// begin serial port communication
// read accelerometer values
value0 = analogRead(analogInput0);
value1 = analogRead(analogInput1);
value2 = analogRead(analogInput2);
// print values in the serial port, separated by comma
Serial.print(value0);
Serial.print(",");
Serial.print(value1);
Serial.print(",");
Serial.println(value2);
// wait and loop again
delay(100);   }
cs
The output produced by SerialChart is shown in the picture below, where I inserted also the parametrization made.
1
2
3
4
5
6
7
8
9
10
11
12
  Serial.println("CLEARDATA"); // clear
  sprintf(str,"CLEARDATA\n"); U0_STR(str);
  Serial.println("LABEL,Time,x,sin(x)"); //label text
  sprintf(str,"LABEL,Time,x,sin(x)\n"); U0_STR(str);
  sprintf(str,"DATA,TIME,%d,%.2f\n",x,sin(x*PI/180)); U0_STR(str);
  sprintf(str,"ROW,SET,2\n"); U0_STR(str);
cs
아두이노 명령어에 해당하는 AVR 코드를 추가했습니다.​
조회수 1,533
아두이노HOME > 아두이노 > 전체 목록
