아두이노 > Grove - Ear-clip Heart Rate Sensor
TODAY828 TOTAL1,150,244
BASIC4MCU | 아두이노 | 아두이노 | Grove - Ear-clip Heart Rate Sensor
작성자 키트 작성일2017-09-11 16:38 조회804회 댓글0건
Contents
 [hide
Introduction
The Heart Rate Ear clip kit contains a ear clip and a receiver module. The heart rate measure kit can be used to monitor heart rate of patient and athlete. The result can be displayed on a screen via the serial port and can be saved for analysis. The entire system is a high sensitivity, low power consumption and portable.
Model: MED03212P
Heart rate ear clip kit
Features
  • Low power consumption
  • Convenient to use
  • High sensitivity
  • Fully RoHS compliant
Specification
ItemMinTypicalMaxUnit
Voltage3.05.05.25V
Work Current6.5mA
Length of ear clip wire120cm
Measures Range≥30/min-
Application Ideas
  • Heart rate monitor.
Usage
The following sketch demonstrates a simple application of using the Ear-clip Heart Rate Sensor to measure heart rate.
  • Connect this module to the digital port D2 on Grove-Base shield. And connect Grove-LED to Digital port 4.
  • Plug the Base Shield into Arduino/Seeeduino.
Error creating thumbnail: Invalid thumbnail parameters
opy and paste code below to a new Arduino sketch.
// Function: This program can be used to measure heart rate, the lowest pulse in the program be set to 30.
//         Use an external interrupt to measure it.
// Hardware: Grove - Ear-clip Heart Rate Sensor, Grove - Base Shield, Grove - LED
// Arduino IDE: Arduino-1.0
// Author: FrankieChu
// Date: Jan 22, 2013
// Version: v1.0
#define LED 4//indicator, Grove - LED is connected with D4 of Arduino
boolean led_state = LOW;//state of LED, each time an external interrupt
//will change the state of LED
unsigned char counter;
unsigned long temp[21];
unsigned long sub;
bool data_effect=true;
unsigned int heart_rate;//the measurement result of heart rate
const int max_heartpluse_duty = 2000;//you can change it follow your system's request.
//2000 meams 2 seconds. System return error
//if the duty overtrip 2 second.
pinMode(LED, OUTPUT);
Serial.println("Please ready your chest belt.");
delay(5000);
arrayInit();
Serial.println("Heart rate test begin.");
attachInterrupt(0, interrupt, RISING);//set interrupt 0,digital port 2
digitalWrite(LED, led_state);//Update the state of the indicator
/*Function: calculate the heart rate*/
void sum()
 if(data_effect)
      heart_rate=1200000/(temp[20]-temp[0]);//60*20*1000/20_total_time
      Serial.print("Heart_rate_is:\t");
      Serial.println(heart_rate);
   data_effect=1;//sign bit
/*Function: Interrupt service routine.Get the sigal from the external interrupt*/
void interrupt()
    temp[counter]=millis();
Serial.println(counter,DEC);
    Serial.println(temp[counter]);
    switch(counter)
case 0:
sub=temp[counter]-temp[20];
Serial.println(sub);
default:
sub=temp[counter]-temp[counter-1];
    if(sub>max_heartpluse_duty)//set 2 seconds as max heart pluse duty
data_effect=0;//sign bit
counter=0;
Serial.println("Heart rate measure error,test will restart!" );
arrayInit();
    if (counter==20&&data_effect)
counter=0;
sum();
    else if(counter!=20&&data_effect)
    counter++;
counter=0;
data_effect=1;
/*Function: Initialization for the array(temp)*/
void arrayInit()
for(unsigned char i=0;i < 20;i ++)
temp[i]=0;
temp[20]=millis();
  • Upload the code, please click here if you do not know how to upload.
  • Make sure the sensor contacts your ear skin. This is the signal when we are measuring the heart rate:
GROVE heart rate chest belt Grove-heart rate serial
In the left of the figures which is a waveform diagram of the detected heartbeat, A high pulse comes when beating. Note: If the serial monitor return an error message, please change the position of the sensor.
Resources
Grove - Ear-clip Heart Rate Sensor Demo code
Support
If you have questions or other better design ideas, you can go to our forum or wish to discuss.
http://www.seeedstudio.com/wiki/Grove_-_Heart_rate_ear_clip_kit
조회수 804
아두이노HOME > 아두이노 > 전체 목록
