아두이노 > DFRobot LM35 Linear Temperature Sensor (SKU:DFR0023)
TODAY380 TOTAL3,162,656
BASIC4MCU | 아두이노 | 아두이노 | DFRobot LM35 Linear Temperature Sensor (SKU:DFR0023)
작성자 키트 작성일2017-09-11 16:40 조회2,872회 댓글0건
From Robot Wiki
Jump to: navigationsearch
Introduction
The DFRobot LM35 Linear Temperature Sensor is based on the semiconductor LM35 temperature sensor. The DFRobot LM35 Linear Temperature Sensor can be used to detect ambient air temperature. This sensor is produced by National Semiconductor Corporation and offers a functional range between 0 degree Celsius to 100 degree Celsius. Sensitivity is 10mV per degree Celsius. The output voltage is proportional to the temperature.
It is commonly used as a temperature measurement sensors. It includes thermocouples, platinum resistance, thermal resistance and temperature semiconductor chips, which commonly used in high temperature measurement thermocouples. Platinum resistance temperature used in the measurement of 800 degrees Celsius, while the thermal resistance and semiconductor temperature sensor suitable for measuring the temperature of 100-200 degrees or below, in which the application of a simple semiconductor temperature sensor has good linearity and high sensitivity. The LM35 linear temperature sensor and sensor-specific expansion of Arduino board, in combination, can be very easy to achieve.
Specification
  • Based on the semiconductor LM35 temperature sensor
  • Can be used to detect ambient air temperature
  • Sensitivity: 10mV per degree Celcius
  • Functional range: 0 degree Celsius to 100 degree Celsius
Pin Definition
The definition of gray-scale sensor pin is
  1. Signal Output
  2. GND
  3. Power
Analog Sensor Pin Definition
Connection Diagram
Analog sensor connection diagram
Sample Code 1
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
    Serial.begin(9600);//Set Baud Rate to 9600 bps
    int val;
    int dat;
    val=analogRead(0);//Connect LM35 on Analog 0
    dat=(500 * val) /1024;;
    Serial.print("Temp:"); //Display the temperature on Serial monitor
    Serial.print(dat);
    Serial.println("C");
    delay(500);
Sample Code 2
조회수 2,872
아두이노HOME > 아두이노 > 전체 목록
