아두이노 > Build Your FM transmission Station with Arduino - FM 방송국
TODAY711 TOTAL1,150,127
BASIC4MCU | 아두이노 | 아두이노 | Build Your FM transmission Station with Arduino - FM 방송국
작성자 키트 작성일2017-09-11 16:42 조회1,445회 댓글0건
Picture of Build Your FM transmission Station with Arduino
Project FM 080
Hi every body .
Before  A  3 months Ago , one of my friend ask me to build  a Simple FM transmitter , he Would to transmit An Audio File from computer and PLAY it on any radio channel , By adjust the frequency of receiver  as same as transmitter  frequency
I searched on the internet on for this circuit , But I don't find my target .
There  were some circuits with many component , or with miss component , so I search more and i Found one of the amazing method, effective and easy to use , with few component  .
and for easy interface with , I added  A graphical  LCD  Nokia 5110 PCD8544 , and  added a Potentiometer to tune the transmitter Frequency .
let's see what we need :
Remove these adsRemove these ads by Signing Up
Step 1: Material
Picture of Material
At first , I connect all part's on BreadBoard , and i design will PCB For it soon .
The component we need for this device :
1)Arduino Board  , Uno for example.
http://www.ebay.com/itm/Original-Genuine-Arduino-Uno-R3-Board-New-in-box-from-Italy-/271207670126?pt=LH_DefaultDomain_2&hash=item3f253ca16e
2) LCD Nokia 5110 PCD8544
http://www.ebay.com/itm/1pcs-84-48-LCD-Module-White-backlight-adapter-pcb-for-Nokia-5110-/400347868649?pt=LH_DefaultDomain_0&hash=item5d3697ade9
3)FM Transmitter module V1.0 ElecHouse
http://www.ebay.com/itm/140878623449?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
4)Solderless Jumper Male-Male
5) BreadBoard
6)potentiometer (50K , 500 Ohm)
7)Battery 9V With Holder .
Step 2: First Part : LCD Nokia 5110
Picture of First Part
images
nokia_5110_graphic_lcd_84_48_4-500x500
nokia5110_MED
sparkfun
This LCD was an Official LCD For Nokia 5110 Phone , It has a dimensions of 84*48 and can be interface on SPI Protocol .
I wrote An artical about it in arabic language on My Blog
http://www.genotronex.com/2013/03/nokia-5110-lcd.html
And the best way to program this series of LCD Is U8g library , It's support many LCD Controller , You can read More About it in this link
https://code.google.com/p/u8glib/wiki/userreference
this LCD comes with different modules , like adafruit  , sparkFun ,  chines stores  , No matter what you are using , Just pay attention to Pinout and it's connection To arduino Board  .
For sparkFun LCD you must read this quick start Guide . and for adafruit LCD you well need CD4050 TTL Converter
I used LCD 5110 which is compatible with 5V Logic input ", you can buy one like this from Ebay store .
Step 3: FM Transmitter Module
Picture of FM Transmitter Module
FM modulator-2
first
The FM Transmitter module is the Heart of this project , it comes form ElecHouse and Works on I2C Interface .
the range of this module without antenna around 40cm , you can connect an external antenna to increase the range of transmitter .
This module based on KT0803K Monolithic Digital Stereo FM Transmitter Radio-Station-on-a-Chip ,  designed to operate from 76-108 MHZ
the Full Data sheet for  KT0803K here
http://www.elechouse.com/elechouse/images/product/FM%20Transmitter%20Module/KT0803K.pdf
the library for this Module will found in the "Arduino Code "step .
Step 4: Potentiometer
Picture of Potentiometer
images
There are 2 Potentiometer in this project , One of it "50K ohm" connecting to Analoge Pin A0 to change the frequency of the Transmitter , and the other connecting to pin 7 On the LCD To adjust the Screen  Backlight
Step 5: Schematic
Picture of Schematic
fm
LCD
the schematic for this project is as following
 LCD installation video
FM Transmitter module installation video
potentiometer of the LCD Baclight  installation video
Step 6: Arduino Code
Picture of arduino Code
Project FM 080
Project FM 050
Project FM 021
The  full code , library, and schematic for this project you can find it on attachment
Note that you can change the FM Frequency band depend on your country , in this Line :
fmtx_init(fm_freq, USA); // you can change it for your countery.
USA
EUROPE
JAPAN
AUSTRALIA
CHINA
For My Country ,Jordan , I use USA "Works from 88-107MHz "
Code ://
//This program is distributed in the hope that it will be useful,
//but WITHOUT ANY WARRANTY; without even the implied warranty of
//MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
//You should have received a copy of the GNU General Public License
// along with this program. If not, see http://www.gnu.org/licenses/
//Name :Mohannad Rawashdeh .
//Date "13/5/2013 3:00pm
// Description: This  Code for  A FM transmission station
// for more info  http://www.genotronex.com/
// written by :Mohannad Rawashdeh , Genotronex@gmail.com
#include "U8glib.h"
#include
// draw Circle
//www.Genotronex.com
//Mohannad Rawashdeh
//U8GLIB_ST7920_128X64 u8g(13, 11, 12, U8G_PIN_NONE);// SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
U8GLIB_PCD8544 u8g(13, 11, 10, 9, 8);    // SPI Com: SCK = 13, MOSI = 11, CS = 10, A0 = 9, Reset = 8
int channel=0;
float fm_freq = 90;  // Here set the default FM frequency
int reading=0;
int last_reading=0;
int Current_reading=0;
int mapping_reading=000;
void setup(void){
pinMode(A0,INPUT);
USA
EUROPE
JAPAN
AUSTRALIA
CHINA
  // Jordan works as USA Frequency range 87.5-110MHz
u8g.setRot180();
u8g.setColorIndex(1); // pixel on !
u8g.firstPage();
  do{
    set_screen(1);
  while(u8g.nextPage() );
  u8g.firstPage();
  do{
    set_screen(0);
   Clear();
    u8g.firstPage();
  do{
    intro();
  delay(2500);
   u8g.firstPage();
  do{
    intro2();
  delay(2500);
  Clear();
// Reading Any Tunning change here.
void Analog_pin_read(){
   channel=mapping_reading;
   Current_reading=channel;
   fmtx_set_freq(channel);
void set_screen(int i){
u8g.setColorIndex(i); // pixel on !
for (int x_axis=0;x_axis<84;x_axis++){
for (int y_axis=0;y_axis<44;y_axis++){
u8g.drawPixel(x_axis,y_axis);
void Clear(void){
  u8g .setFont(u8g_font_04b_03);
  u8g.setFontRefHeightExtendedText();
  u8g.setDefaultForegroundColor();
  u8g.setFontPosTop();
void intro(void){
  u8g.drawFrame(0,0,83,47);
  u8g .setFont(u8g_font_osr18);
  u8g.drawStr( 5, 25, "FM Tx ");
  u8g .setFont(u8g_font_tpss);
  u8g.drawStr( 5, 40, " System");
void intro2(void){
  u8g.drawStr( 2, 7, "Build Your FM station! ");
  u8g.drawStr( 2, 15, "Change the Freq");
  u8g.drawStr( 2, 26, "From Poten");
  u8g.drawStr( 2, 38, "www.genotronex.com");
//change frequency value On lcd here
void number(int value){
  u8g .setFont(u8g_font_unifont);
  u8g.drawStr( 5, 15, "Frequency ");
  u8g.setPrintPos(10,45);
  u8g.println(value,DEC);
  u8g.drawStr( 45, 38, "MHz ");
  reading=analogRead(A0);
  mapping_reading=map(reading,0,1023,87,108);
  mapping_reading=constrain(mapping_reading,87,108);
  if( mapping_reading!= Current_reading){
  Clear();
  Analog_pin_read();
u8g.firstPage();
  do{
  number(channel);
Step 7: Final Video
Picture of final Video
connect your system to computer for example and bring a Phone with build-in radio and adjust the frequency to listen to your computer music on the radio  channel
at the end , the video for the whole system
FM Radio Transmitter Module Arduino compatible -- Build your own radio station
Introduction
Ever thinking about set up a music radio station yourself? I think it would be great if you could build a music station and share your music with others. Pretty cool, right?
This module could modulate your voice on the FM radio wave. And anyone who has a radio device could receive it. We build everything on this module, which makes it very easy to build a tiny radio station. We also reate library for Arduino to work with this module. We make everything easy for you.
Feature
  • I2C interface 5V TTL compatible
  • Arduino plug and play
  • Onboard MIC
  • VCC Input: 3.0V ~ 5.0V
Connection
If is very easy to connect it with Arduino if you have Arduino Sensor Shield V6.
If you don't have sensor shield, you could wire them in the following way:
Arduino        FM Module
GND   ------------   GND
5V   ------------   VCC
SDA   ------------   SDA
SCL   ------------   SCL
Then connect the antenna. Any metal line about 75cm can serves as an antenna.
Code
Download the libary and upload the example sketch to Arduino. The open Serial monitor:
Turn out your radio device and set it at FM 90MHz. Enjoy!
Document
Product List
  1. FM Transmitter module x1
  2. 4pin wire x1
  3. Doule male recording line x1
조회수 1,445
아두이노HOME > 아두이노 > 전체 목록
