아두이노 > SFEMP3Shield - Arduino Library for VS10xx shield
TODAY1,105 TOTAL1,135,959
BASIC4MCU | 아두이노 | 아두이노 | SFEMP3Shield - Arduino Library for VS10xx shield
작성자 키트 작성일2017-09-11 16:47 조회877회 댓글0건
Logo
SFEMP3Shield  1.02.14
MP3Shield_Library_Demo.ino File Reference
Example sketch of using the MP3Shield Arduino driver, demonstrating all methods and functions. More...
#include
#include
#include
#include <SFEMP3Shield.h>
Include dependency graph for MP3Shield_Library_Demo.ino:
Go to the source code of this file.
Functions
void setup ()
 Setup the Arduino Chip's feature for our use. More...
void loop ()
 Main Loop the Arduino Chip. More...
void parse_menu (byte key_command)
 Decode the Menu. More...
void help ()
 Print Help Menu. More...
Variables
SdFat sd
 Object instancing the SdFat library. More...
SFEMP3Shield MP3player
 Object instancing the SFEMP3Shield library. More...
uint32_t millis_prv
Detailed Description
Remarks
comments are implemented with Doxygen Markdown format
Author
Bill Porter
Michael P. Flaga
This sketch listens for commands from a serial terminal (like the Serial Monitor in the Arduino IDE). If it sees 1-9 it will try to play an MP3 file named track00x.mp3 where x is a number from 1 to 9. For eaxmple, pressing 2 will play 'track002.mp3'. A lowe case 's' will stop playing the mp3. 'f' will play an MP3 by calling it by it's filename as opposed to a track number.
Sketch assumes you have MP3 files with filenames like "track001.mp3", "track002.mp3", etc on an SD card loaded into the shield.
Definition in file MP3Shield_Library_Demo.ino.
Function Documentation
void help()
Print Help Menu.
Prints a full menu of the commands available along with descriptions.
Definition at line 540 of file MP3Shield_Library_Demo.ino.
This is called at the end of Arduino kernel's main loop before recycling. And is where the user's serial input of bytes are read and analyzed by parsed_menu.
Additionally, if the means of refilling is not interrupt based then the MP3player object is serviced with the availaible function.
Note
Actual examples of the libraries public functions are implemented in the parse_menu() function.
Definition at line 122 of file MP3Shield_Library_Demo.ino.
void parse_menu(byte key_command)
Decode the Menu.
Parses through the characters of the users input, executing corresponding MP3player library functions and features then displaying a brief menu and prompting for next input command.
Definition at line 149 of file MP3Shield_Library_Demo.ino.
After Arduino's kernel has booted initialize basic features for this application, such as Serial port and MP3player objects with .begin. Along with displaying the Help Menu.
Note
returned Error codes are typically passed up from MP3player. Whicn in turns creates and initializes the SdCard objects.
See Also
Error Codes
Definition at line 65 of file MP3Shield_Library_Demo.ino.
Variable Documentation
uint32_t millis_prv
Definition at line 139 of file MP3Shield_Library_Demo.ino.
principal object for handling all the attributes, members and functions for the library.
Definition at line 49 of file MP3Shield_Library_Demo.ino.
SdFat sd
SdFat sd;.
principal object for handling all SdCard functions.
Definition at line 42 of file MP3Shield_Library_Demo.ino.
https://github.com/madsci1016/Sparkfun-MP3-Player-Shield-Arduino-Library/blob/master/SFEMP3Shield/SFEMP3Shield.h
조회수 877
아두이노HOME > 아두이노 > 전체 목록
