아두이노 > Sparkfun-MP3-Player-Shield-Arduino-Library/SFEMP3Shield/Examples/FilePlayer/FilePlayer.ino
TODAY975 TOTAL1,135,829
BASIC4MCU | 아두이노 | 아두이노 | Sparkfun-MP3-Player-Shield-Arduino-Library/SFEMP3Shield/Examples/FilePlayer/FilePlayer.ino
작성자 키트 작성일2017-09-11 16:49 조회1,043회 댓글0건
* \file FilePlayer.ino
* \brief Example sketch of using the MP3Shield Arduino driver, with flexible list of files and formats
* \remarks comments are implemented with Doxygen Markdown format
* \author Bill Porter
* \author Michael P. Flaga
* This sketch listens for commands from a serial terminal (such as the Serial
* Monitor in the Arduino IDE). Listening for either a single character menu
* commands or an numeric strings of an index. Pointing to a music file, found
* in the root of the SdCard, to be played. A list of index's and corresponding
* files in the root can be listed out using the 'l' (little L) command.
* This sketch allows the various file formats to be played: mp3, aac, wma, wav,
* fla & mid.
* This sketch behaves nearly identical to MP3Shield_Library_Demo.ino, but has
* extra complicated loop() as to recieve string of characters to create the
* file index. As the Serial Monitor is typically default with no CR or LF, this
* sketch uses intercharacter time out as to determine when a full string has
* has been entered to be processed.
#include <SPI.h>
//Add the SdFat Libraries
#include <SdFat.h>
#include <SdFatUtil.h>
//and the MP3 Shield Library
#include <SFEMP3Shield.h>
// Below is not needed if interrupt driven. Safe to remove if not using.
#if defined(USE_MP3_REFILL_MEANS) && USE_MP3_REFILL_MEANS == USE_MP3_Timer1
#include <TimerOne.h>
#elif defined(USE_MP3_REFILL_MEANS) && USE_MP3_REFILL_MEANS == USE_MP3_SimpleTimer
#include <SimpleTimer.h>
#endif
* \brief Object instancing the SdFat library.
* principal object for handling all SdCard functions.
SdFat sd;
* \brief Object instancing the SFEMP3Shield library.
* principal object for handling all the attributes, members and functions for the library.
SFEMP3Shield MP3player;
int16_t last_ms_char; // milliseconds of last recieved character from Serial port.
int8_t buffer_pos; // next position to recieve character from Serial port.
* \brief Setup the Arduino Chip's feature for our use.
* After Arduino's kernel has booted initialize basic features for this
* application, such as Serial port and MP3player objects with .begin.
* Along with displaying the Help Menu.
조회수 1,043
아두이노HOME > 아두이노 > 전체 목록
