아두이노 > serasidis.gr
TODAY1,341 TOTAL1,075,909
BASIC4MCU | 아두이노 | 아두이노 | serasidis.gr
작성자 키트 작성일2017-09-11 16:16 조회1,076회 댓글0건
Dear friends,
On this site, you will find many circuits based on AVR micro-controllers (iC) from Atmel. I will be adding more circuits, because micro controllers, are used in a lot of applications.
The purpose of my web site is to help you work with these little powerful integrated circuits, known as micro-controllers. I believe you will be helped a lot by the source code of the projects I published on my web site.
Todays, microcontrollers are very advanced. All microControllers contain FLASH memoryUSARTRAM,EEPROMSPITWI (I2C)  and many more features, all in one chip at  very low cost.
Micro-controllers are ideal for developing applications such as remote control by mobile phone, monitoring temperatures, pressures, air/liquid flow, driving LCD screens, electric motors, custom measuring instrument tools (oscilloscopes, volt meters etc), web servers/clients and many more.
The only limit is the end of  your imagination! Be creative!
Happy reading,
Vassilis Serasidis
Last update 10 October 2014
Arduino WebRadio player
An inexpensive WebRadio station player that plays audio streams up-to 64-kbps.
Few components (as always !) with great sound quality!
Published:    10 October  2014
Designed by:
Vassilis Serasidis (c) 05 October 2014
Language: Wiring (Arduino)
Arduino Network relay
Remote control your electrical devices through your local network or internet. The circuit contains one output (Relay) and one input (isolated input). The whole project is made in arduino nano platform with ENC28J60 ethernet module.
The controlling software "Network relay" was written for Android devices.
It is available  on Google play store!
Published:    10 September 2014
Designed by:
Vassilis Serasidis (c) 06 September 2014
ATmega8 and TWI (I2C) sensors / devices
Connect TWI (I2C) sensors to ATmega8 (AVR) microcontroller. This project connectsATmega8 with 24c32 eeprom, GY26 digital compass LIS302DL accelerometer,DS1307 Real Time Clock and PCT8574T I2C to parallel converter to control a 20x4 LCD.
Published:    3 October 2013
Designed by: Vassilis Serasidis (c) 29 September 2013
Language: C ( AVRstudio 6 )
125 kHz RFID tag reader
 This RFID reader is based on  a small 8 pin micro-controller (ATtiny13) and an Operational Amplifier (LM358). The reading-decoding and output the unique ID serial number of RFID tag is made entire in software by ATtiny13. No special chip is used!
Published:    21 May 2013 | v2.01 - Updated: 12 June 2014
Designed by: Vassilis Serasidis (c) 28 Aug 2012
4-input mini Logic Analyzer
 A mini Logic Analyzer wich has 4 inputs, it's portable (55x65 mm), battery powered and can capture data up to 400kHz.
Designed by: Vassilis Serasidis (c) 02 Jan 2012
Language: C ( AVRstudio4+ WinAVR )
AVR based oscilloscope
  A mega32 based low speed oscilloscope. It can be used to measure signals from 10Hz up to 7.7 kHz. The input voltage range can be up to 24V AC or 30V DC.
Designed by: Vassilis Serasidis (c) 01.Dec.2007
Updated on 19 Mar 2011 Voltage and frequency infomation is appeared on LCD.
Language: C ( AVRstudio4 + WinAVR )
PCB exposure box
Tired of spending hours and hours in wire soldering? Do your circuits look ugly and you are looking for a way to produce professional-like PCBs? Then you had better try photoetching. And the first step to do that is to have the right equipment that is an Automated Exposure Box
Designed by: Antonios Theodosiou (c) Sept.2010
Published:    25.Nov.2010
SMS remote control v3.0
This is the the 3rd version of the famous SMS remote control. The older T10s cell phone has been replaced by the GM-47 GSM module by allowing you to find easier this module. Moreover, 8 inputs were added for collecting data from switches (windows, doors, limit switches and more). The SMS is now protected by a password.
Designed by: Vassilis Serasidis (c) Jan.2006
Published:    27.Jul.2010
Language:    AVR assembly
Generic experimental AVR board v2.0
A simple and small AVR board to develop your applications. It consists of few, cheap and ordinary components like LEDs, Voltage regulator and capacitors.
Designed by: Vassilis Stergiopoulos (c) 26.Jul.2010
Language: AVR Assembly
LAN cable tester
Here's a very simple, but practical circuit, which is used to check the type of LAN cables (straight or cross) as well as possible faults. So we use a unit that has 8 outputs, each one of which produces a pulse successively.
Designed by: Vassilis Stergiopoulos (c) 01.May.2010
Infrared remote control receiver
You can control now your media center with this programmable RC5 receiver. Moreover, you can switch On/Off your Media Center by your remote control.
Designed by: Vassilis Serasidis (c) 08.Oct.2007
Updated on 12.Aug.2008 *** Sony protocol IR support ***
USB AVR In-System-Programmer
USB AVR programmer that supports a lot of AVR micro-controllers.
Designed by: Klaus Leidinger , Dimitris Porlidas ,
Mike Henning and Vassilis Serasidis (c) 09.Jun.2008
Electronic church bell controller
This circuit can ring the bells with a programmable order, making many melodies. Further, you can write and store your own melody.
Designed by: Antonis Pontikakis (c) 03.10.2007
2 channel RF remote control
This RF remote control it runs at 418 MHz frequency and support up to 2 channels. It is very safety as the transmitting code is changing every time you push any button (roll-code function)
Designed by: Vassilis Serasidis (c) 04.06.2004
Updated on 24.07.2005
SMS remote control v2.2
Control up to 8 devices ( On-Off  or Reset) by sending a SMS message from  any mobile phone, to  ericsson  T10s, of our circuit.
Designed by:Vassilis Serasidis   (c) 23.10.2002
Updated on: 25.12.2006
USB switch
You can connect one USB device like a printer or scanner on 2 computers and controlled by software.
- Available only in Greek language -
Designed by: Vassilis Serasidis    (c) 07.07.2006
Simple VGA/Video adapter
This project is about creating VGA/Video signals  using the 8-bit AVR MCU. The output can drive a TV set or a VGA monitor
Designed by: Ibragimov Maxim Rafikovich  at  07.11.2005
Communication of TRW-24G RF modules with AT90S2313 microcontroller
Communicate 2 TRW-24G RF modules (2.4GHz) with AVR micro-controller. This is more an example assembly code and not an integrated electronic circuit.
Designed by: Vassilis Serasidis    (c) 12.08.2005
MIDI generator
Control some MIDI device with ATtiny26. The code can be convert it for any AVR family micro-controller..
Analog inputs for ATtiny26
Study the Analog to Digital capabilities of Atmel ATtiny26. This check circuit uses only 3 inputs. Of course you can may changes to use more inputs.
Acceleration meter for cars
This circuit it is count the acceleration from -1000mg up to +1000mg. Can be used in lot of applications like cars, elevators, ramps and more.
This page is available in Greek and English language
Designed by: Michael Karaoglanidis
Electronic safety-lock with telecard as key
 This safety-lock can be work with up to 8 different telecards (empty  or not phonecards) as access keys. Each telecard can be registered or  unregistered from the  system, by press the  corresponding button. Keep in mind that cell phone SIM cards don't work with this reader.
AVR In-System Programmer
In-System Programmer (ISP) This programmer can program lot of AVR  micros and its  working with AVR Studio 4.
Designed by: Olesaether, Terie Frostad, Ingar Fredriksen, Morten W. Lund, Haakon Skar, Paal Kastnes
Visual Basic & AVR RS232 interface
 Control AVR micro-controllers via Visual Basic  software. You can use some development board like  MCU 100, STK200, STK500 or build your own  board, following the schematic.
AVR composite PAL colour bar generator
 After a lot of reading books, articles and discussions  with lot of electronic technicians, finally I did it. I  make an 6 colour bar generator entire-in-software  with AT90s2313-10 over-clocked at 17.734475  MHz !!!
Improved by: Zdenek Zechovsky
 Ultra low-cost programmer for AT90Sxxxx family
 With this programmer you can program AT90S1200,  2313,  2323, 2343, 4414, 4434, 8515, 8535
 Designed by: Jerry Meng
LCD 2x16 characters &  4x4 keypad assembly example
Connect  AT90S2313 with LCD display 2x16 char  and 4x4 keyboard (keypad). Its not any special code  (short or fast code) but its very good for beginners
Connect  RS232 modem to E-10G
Here is the instructions to build a cable adaptor  to  connect your pocket PC with any external  RS232  modem. The Pocket PC must have serial  port.
Programable LCD counter with memory backup
조회수 1,076
아두이노HOME > 아두이노 > 전체 목록
