아두이노 > Single Chip Computer: Easy to produce AVR BASIC Computer
TODAY1,198 TOTAL951,667
BASIC4MCU | 아두이노 | 아두이노 | Single Chip Computer: Easy to produce AVR BASIC Computer
작성자 키트 작성일2017-09-13 13:17 조회1,060회 댓글0건
IMG_0645
IMG_0639
This instructable will document and explain my latest project, a standalone computer system based upon a single chip (IC); the ATmega 1284P. The 1284P is responsible for all aspects of the system, including running the BASIC interpreter, generation RCA video signals and reading keyboard input. This computer system runs TinyBASIC just like my Arduino BASIC Shield but this project is completely standalone meaning no Arduino is needed and only a single AVR is needed.
This single chip computer has a video output via RCA, allows a PS/2 keyboard to be connected, allows circuits and components to be connected using the IO headers and runs the TinyBASIC programming interpreter. All components are placed on a single sided PCB which has a simple layout and is easy to produce. The onboard ATmega 1284P is running on a 16MHz crystal. This computer is also low power (it does not draw large amounts of current as it uses a micro-controller which are generally low power devices and the circuit current draw is limited by the voltage regulator to 1A) and some of the PCB components are reusable (such as the ATmega 1284P and the resistors etc).
The images of the blue PCB are for the second version of this computer (details for this board can be found on Hackaday projects: https://hackaday.io/project/1260-single-chip-avr-basic-computer
Update (07/12/14): I updated the design of the computer by adding an additional EEPROM IC allowing full size BASIC programs to be saved. The new design of this computer is documented on Hackaday projects at the following link:https://hackaday.io/project/3537-avr-basic-computer-v01
I had PCBs for this new computer design created professionally at a board house and I am selling the remaining PCBs on eBay at the following link:http://www.ebay.co.uk/itm/121510974344
Update (28/07/14): I have ordered more PCBs (sent PCB files to the board house) and will be putting the boards up on eBay when I receive them (I will post the listing link when I receive the boards). I have slightly updated the design of the PCB to include a USBasp programming header, a few more GPIO pins and a header which allows a small PCB containing a 64Kbit EEPROM IC (an EEPROM storage card) to be connected (used for storing BASIC programs).
조회수 1,060
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
62 아두이노 Adafruit Motor/Stepper/Servo Shield for Arduino kit - v1.2 이미지 키트 17-09-13 1389
61 아두이노 가스센서 이미지 키트 17-09-13 1333
60 아두이노 Arduino Waveform Generator 이미지 키트 17-09-13 1069
59 아두이노 Arduino Waveform Generator 키트 17-09-13 1027
58 아두이노 Arduino Waveform Generator 이미지 키트 17-09-13 1397
57 아두이노 Exclusive 2.5 GHz Frequency Counter 이미지 키트 17-09-13 2773
56 아두이노 AVR SIMULATOR IDE 이미지 키트 17-09-13 971
55 아두이노 Marlin 이미지 키트 17-09-13 1011
54 아두이노 opencircuits.com - Oscilloscope 이미지 키트 17-09-13 1055
53 아두이노 Zorkduino 키트 17-09-13 1033
52 아두이노 Single Chip AVR BASIC Computer V0.1 키트 17-09-13 1042
51 아두이노 Single Chip AVR BASIC Computer V0.3 키트 17-09-13 1076
50 아두이노 Single Chip AVR BASIC Computer 키트 17-09-13 966
현재글 아두이노 Single Chip Computer: Easy to produce AVR BASIC Computer 이미지 키트 17-09-13 1061
48 아두이노 Arduino Realtime Audio Processing 이미지 키트 17-09-13 974
MCU BASIC ⓒ 2019
