아두이노 > Exclusive 2.5 GHz Frequency Counter
TODAY1,672 TOTAL949,813
BASIC4MCU | 아두이노 | 아두이노 | Exclusive 2.5 GHz Frequency Counter
작성자 키트 작성일2017-09-13 13:38 조회2,771회 댓글0건
Exclusive 2
A frequency counter is one of the most important measuring tool we need as homebrew's of RF electronic. This frequency counter has very high performance and still is very easy to build and to use. Anyone can build it and have a professional frequency measuring tool. The counter is based around a LCD display with 2 lines and 16 chars. I have used a HD44780 based display which is very common. A PIC16F870 circuit controls all counting and display functions. A prescaler is added to make it possible to measure up to 2.5GHz with high sensitivity. The Display Module Size (W x H x T): 80mm X 36mm. The controller PCB has the same size. This makes the unit very small and slim.
Exclusive 2
Exclusive 2
Exclusive 2
Exclusive 2
Exclusive 2
Accurate LC Meter Capacitance Inductance Meter with 16F628 and LCD
Volt Ampere Meter with 16F876 Microcontroller and LCD display
Accurate LC Meter
Build your own Accurate LC Meter (Capacitance Inductance Meter) and start making your own coils and inductors. This LC Meter allows to measure incredibly small inductances making it perfect tool for making all types of RF coils and inductors. LC Meter can measure inductances starting from 10nH - 1000nH, 1uH - 1000uH, 1mH - 100mH and capacitances from 0.1pF up to 900nF. The circuit includes an auto ranging as well as reset switch and produces very accurate and stable readings.
PIC Volt Ampere Meter
Volt Ampere Meter measures voltage of 0-70V or 0-500V with 100mV resolution and current consumption 0-10A or more with 10mA resolution. The meter is a perfect addition to any power supply, battery chargers and other electronic projects where voltage and current must be monitored. The meter uses PIC16F876A microcontroller with 16x2 backlighted LCD.
50MHz 60MHz Frequency Meter
1Hz - 2MHz XR2206 Function Generator
60MHz Frequency Meter / Counter
Frequency Meter / Counter measures frequency from 10Hz to 60MHz with 10Hz resolution. It is a very useful bench test equipment for testing and finding out the frequency of various devices with unknown frequency such as oscillators, radio receivers, transmitters, function generators, crystals, etc.
1Hz - 2MHz XR2206 Function Generator produces high quality sine, square and triangle waveforms of high-stability and accuracy. The output waveforms can be both amplitude and frequency modulated. Output of 1Hz - 2MHz XR2206 Function Generator can be connected directly to 60MHz Counter for setting precise frequency output.
BA1404 HI-FI Stereo FM Transmitter
USB IO Board PIC18F2455
Be "On Air" with your own radio station! BA1404 HI-FI Stereo FM Transmitter broadcasts high quality stereo signal in 88MHz - 108MHz FM band. It can be connected to any type of stereo audio source such as iPod, Computer, Laptop, CD Player, Walkman, Television, Satellite Receiver, Tape Deck or other stereo system to transmit stereo sound with excellent clarity throughout your home, office, yard or camp ground.
USB IO Board
USB IO Board is a tiny spectacular little development board / parallel port replacement featuring PIC18F2455/PIC18F2550 microcontroller. USB IO Board is compatible with Windows / Mac OSX / Linux computers. When attached to Windows IO board will show up as RS232 COM port. You can control 16 individual microcontroller I/O pins by sending simple serial commands. USB IO Board is self-powered by USB port and can provide up to 500mA for electronic projects. USB IO Board is breadboard compatible.
ESR Meter
Audiophile Headphone Amplifier Kit
ESR Meter / Capacitance / Inductance / Transistor Tester Kit
ESR Meter kit is an amazing multimeter that measures ESR values, capacitance (100pF - 20,000uF), inductance, resistance (0.1 Ohm - 20 MOhm), tests many different types of transistors such as NPN, PNP, FETs, MOSFETs, Thyristors, SCRs, Triacs and many types of diodes. It also analyzes transistor's characteristics such as voltage and gain. It is an irreplaceable tool for troubleshooting and repairing electronic equipment by determining performance and health of electrolytic capacitors. Unlike other ESR Meters that only measure ESR value this one measures capacitor's ESR value as well as its capacitance all at the same time.
Audiophile headphone amplifier kit includes high quality audio grade components such as Burr Brown OPA2134 opamp, ALPS volume control potentiometer, Ti TLE2426 rail splitter, Ultra-Low ESR 220uF/25V Panasonic FM filtering capacitors, High quality WIMA input and decoupling capacitors and Vishay Dale resistors. 8-DIP machined IC socket allows to swap OPA2134 with many other dual opamp chips such as OPA2132, OPA2227, OPA2228, dual OPA132, OPA627, etc. Headphone amplifier is small enough to fit in Altoids tin box, and thanks to low power consumption may be supplied from a single 9V battery.
Arduino Prototype Kit
RF Remote Control 433MHz Four Channel
Arduino Prototype is a spectacular development board fully compatible with Arduino Pro. It's breadboard compatible so it can be plugged into a breadboard for quick prototyping, and it has VCC & GND power pins available on both sides of PCB. It's small, power efficient, yet customizable through onboard 2 x 7 perfboard that can be used for connecting various sensors and connectors. Arduino Prototype uses all standard through-hole components for easy construction, two of which are hidden underneath IC socket. Board features 28-PIN DIP IC socket, user replaceable ATmega328 microcontroller flashed with Arduino bootloader, 16MHz crystal resonator and a reset switch. It has 14 digital input/output pins (0-13) of which 6 can be used as PWM outputs and 6 analog inputs (A0-A5). Arduino sketches are uploaded through any USB-Serial adapter connected to 6-PIN ICSP female header. Board is supplied by 2-5V voltage and may be powered by a battery such as Lithium Ion cell, two AA cells, external power supply or USB power adapter.
200m 4-Channel 433MHz Wireless RF Remote Control
Having the ability to control various appliances inside or outside of your house wirelessly is a huge convenience, and can make your life much easier and fun. RF remote control provides long range of up to 200m / 650ft and can find many uses for controlling different devices, and it works even through the walls. You can control lights, fans, AC system, computer, printer, amplifier, robots, garage door, security systems, motor-driven curtains, motorized window blinds, door locks, sprinklers, motorized projection screens and anything else you can think of.
10 개 lmx2322 lmx2322tmx tssop16
US $9.10 / 10 개무료 배송
http://ko.aliexpress.com/item/Free-shipping-10PCS-LMX2322-LMX2322TMX-TSSOP16/874189072.html
조회수 2,771
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
62 아두이노 Adafruit Motor/Stepper/Servo Shield for Arduino kit - v1.2 이미지 키트 17-09-13 1387
61 아두이노 가스센서 이미지 키트 17-09-13 1331
60 아두이노 Arduino Waveform Generator 이미지 키트 17-09-13 1067
59 아두이노 Arduino Waveform Generator 키트 17-09-13 1027
58 아두이노 Arduino Waveform Generator 이미지 키트 17-09-13 1395
현재글 아두이노 Exclusive 2.5 GHz Frequency Counter 이미지 키트 17-09-13 2772
56 아두이노 AVR SIMULATOR IDE 이미지 키트 17-09-13 968
55 아두이노 Marlin 이미지 키트 17-09-13 1010
54 아두이노 opencircuits.com - Oscilloscope 이미지 키트 17-09-13 1054
53 아두이노 Zorkduino 키트 17-09-13 1029
52 아두이노 Single Chip AVR BASIC Computer V0.1 키트 17-09-13 1041
51 아두이노 Single Chip AVR BASIC Computer V0.3 키트 17-09-13 1074
50 아두이노 Single Chip AVR BASIC Computer 키트 17-09-13 964
49 아두이노 Single Chip Computer: Easy to produce AVR BASIC Computer 이미지 키트 17-09-13 1060
48 아두이노 Arduino Realtime Audio Processing 이미지 키트 17-09-13 972
MCU BASIC ⓒ 2019
