아두이노 > Arduino Waveform Generator
TODAY1,396 TOTAL1,077,519
BASIC4MCU | 아두이노 | 아두이노 | Arduino Waveform Generator
작성자 키트 작성일2017-09-13 13:51 조회1,143회 댓글0건
//wavetype storage:
//0 is pulse
//1 is triangle
//2 is saw
//3 is sine
byte type=0,i,typecurrent=8,typelast,typecounter[4],PWTolerance=8,freqTolerance=2;
int pulseWidthScaled,PWCurrent,frequency,freqCurrent;
unsigned int freqscaled;
long t,samplerate,period;
float pulseWidth;
//storage variables- I used these to cut down on the math being performed during the interrupt
byte wave,sawInc,triInc;
int sawByte=0,triByte=0,sinNum=0,sinInc;
  DDRD=0xFF; DDRB=0xFF;
  OCR1A=159; TCCR1B=(1<<WGM12)||(1<<CS10); TIMSK1|=(1<<OCIE1A); // 16000000/1/(159+1)=100KHz
  samplerate=100000;
  PORTB=1<<type;
  //initialize variables
  frequency=analogRead(A5);  // initialize frequency
  freqscaled=48*frequency+1// from 1 to ~50,000\
  period=samplerate/freqscaled;
  pulseWidth=analogRead(A4); // initalize pulse width
  pulseWidthScaled=int(pulseWidth/1023*period);
  triInc=511/period;
  sawInc=255/period;
  sinInc=20000/period;
  sei();
void checkFreq(){
  freqCurrent=analogRead(A5);
  if(abs(freqCurrent-frequency)>freqTolerance){ // if reading from pot exceeds tolerance
    frequency=freqCurrent;                      // new frequency- number between 0 and 1024
    freqscaled=48*frequency+1;                  // from 1 to ~50,000
    triInc=511/period; if(triInc==0)triInc=1;
    sawInc=255/period; if(sawInc==0)sawInc=1;
void checkPW(){
  PWCurrent=analogRead(A4);
  if(abs(PWCurrent-pulseWidth)>PWTolerance){ // if reading from pot exceeds tolerance
    pulseWidth=PWCurrent;                    // new pulse width,val between 0 and 1023
void checkShape(){//debounce and check states of buttons
  //  4 momentary switches control waveshape
  //   -pulse connects to A0
  //   -triangle A1
  //   -saw A2
  //   -sine A3
  typelast=typecurrent;
  if     (digitalRead(A0)==LOW){ typecurrent=1;}
  else if(digitalRead(A1)==LOW){ typecurrent=2;}
  else if(digitalRead(A2)==LOW){ typecurrent=4;}
  else if(digitalRead(A3)==LOW){ typecurrent=8;}
  for(i=0;i<4;i++){
    if(i==type){}
      if((typecurrent&(1<<i))^(typelast&(1<<i))){  // current diff than prev and debounce
        if((typecurrent&(1<<i)))type=i;            // currently depressed//set wave type
        else                    typecounter[i]=12// else set debounce counter to 12
      else if(((typecurrent&(1<<i))==(typelast&(1<<i )))){ // if current same as prev and diff than debounce
        if(typecounter[i]>0&&--typecounter[i]==0){         // decrease debounce counter and check to see if=0
          if((typecurrent&(1<<i)))type=i;                  // if debounce counter=0 toggle debounced state
ISR(TIMER1_COMPA_vect){ //timer 1 interrupt
  if(++t>=period)t=0;
  switch(type){
    case 0if(pulseWidthScaled<=t)wave=255else wave=0break//pulse
    case 1//triangle
        if((period-t)>t){
          if(t==0)triByte=0else triByte+=triInc;
        else triByte-=triInc;
        if(triByte>255)triByte=255else if(triByte<0)triByte=0;
        wave=triByte; break;
    case 2if(t=0)sawByte=0else sawByte+=sawInc; wave=sawByte;        break//saw
    case 3: sinNum=t*sinInc;  wave=pgm_read_byte_near(sine20000+sinNum); break//sine
  PORTD=wave;
  checkFreq();
  checkShape();
  checkPW();
  PORTB=1<<type;
cs
1949137565_IQWXNPM1_2367BC3F532161AD1D43E7
코드가 AVRstudio 스타일로 작성 되어 있습니다.
  if(++t>=period)t=0;
  switch(type){
    case 1//triangle
        if((period-t)>t){
  PORTD=wave;
사인파를 제외하면 규칙적으로 변하는 파형이니 크게 어려운 것이 없고
어려운 사인파는 만들어둔 사인값 테이블을 불러서 포트D에 출력합니다.
조회수 1,143
아두이노HOME > 아두이노 > 전체 목록
