아두이노 > tkkrlab - Arduino 37 sensors - KY-010 Optical broken module
TODAY1,142 TOTAL2,933,428
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-010 Optical broken module
작성자 키트 작성일2017-09-13 14:22 조회2,676회 댓글0건
Arduino KY-010 Optical broken module
Arduino KY-010 Optical broken module Sku 135035 2
Buy on Dealextream
KEYES ARDUINO photo interrupter module
Photo interupter module use the buildin arduino led. If the sensor is broken the LED is turned on.
Device senses a signal, LED lights, otherwise off.
Schematic
If you view from the top like on the photo
  • Left = Ground
  • Middle = +5V
  • Right = Signal
Connect the module to the arduino as follows:
  • Arduino pin GND to module GND
  • Arduino digital pin 3 to module Signal
  • Arduino pin 5V to module 5V
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
// Example code for KY-010
// photo interrupter module
int Led = 13 ;// define LED Interface
int buttonpin = 3// define the photo interrupter sensor interface
int val ;// define numeric variables val
void setup ()
  pinMode (Led, OUTPUT) ;// define LED as output interface
  pinMode (buttonpin, INPUT) ;// define the photo interrupter sensor output interface
void loop ()
  val = digitalRead (buttonpin) ;// digital interface will be assigned a value of 3 to read val
  if (val == HIGH) // When the light sensor detects a signal is interrupted, LED flashes
    digitalWrite (Led, HIGH);
    digitalWrite (Led, LOW);
cs
https://tkkrlab.nl/wiki/Arduino_KY-010_Optical_broken_module
조회수 2,676
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
92 아두이노 tkkrlab - Arduino 37 sensors - KY-022 Infrared sensor receiv… 키트 17-09-13 3031
91 아두이노 tkkrlab - Arduino 37 sensors - KY-021 Mini magnetic reed mod… 키트 17-09-13 2884
90 아두이노 tkkrlab - Arduino 37 sensors - KY-020 Tilt switch module 키트 17-09-13 2973
89 아두이노 tkkrlab - Arduino 37 sensors - KY-019 5V relay module 키트 17-09-13 3030
88 아두이노 tkkrlab - Arduino 37 sensors - KY-018 Photo resistor module 키트 17-09-13 2663
87 아두이노 tkkrlab - Arduino 37 sensors - KY-017 Mercury open optical m… 키트 17-09-13 2633
86 아두이노 tkkrlab - Arduino 37 sensors - KY-016 3-color LED module 키트 17-09-13 2921
85 아두이노 tkkrlab - Arduino 37 sensors - KY-015 Temperature and humidi… 키트 17-09-13 2532
84 아두이노 tkkrlab - Arduino 37 sensors - KY-013 Temperature sensor mod… 키트 17-09-13 2894
83 아두이노 tkkrlab - Arduino 37 sensors - KY-012 Active buzzer module 키트 17-09-13 2947
82 아두이노 tkkrlab - Arduino 37 sensors - KY-011 2-color LED module 키트 17-09-13 2702
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-010 Optical broken module 키트 17-09-13 2677
80 아두이노 tkkrlab - Arduino 37 sensors - KY-009 3-color full-color LED… 키트 17-09-13 2653
79 아두이노 tkkrlab - Arduino 37 sensors - KY-008 Laser sensor module 키트 17-09-13 2966
78 아두이노 tkkrlab - Arduino 37 sensors - KY-006 Small passive buzzer m… 키트 17-09-13 2873
