아두이노 > tkkrlab - Arduino 37 sensors - KY-013 Temperature sensor module
TODAY1,168 TOTAL2,933,454
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-013 Temperature sensor module
작성자 키트 작성일2017-09-13 14:24 조회2,894회 댓글0건
Arduino KY-013 Temperature sensor module
400xp
Part of Dealextream 37 sensors in a 1 kit
Analog temperature sensor
First, the module introduces The module is based on the thermistor (resistance increases with the ambient temperature changes) works, a sense of real-time To know the temperature of the surrounding environment changes, we send the data to the Arduino analog IO, then come down as long as we go through Jane Single programming will be able to convert the sensor output data Celsius temperature values and displayed, it is still easy to use, It effectively, thereby widely used in gardening, home alarm systems and other devices. Second, the use And the general temperature sensor is the same, are three-line package, when we use the power cord connected OK signal output Into the end on the line, because the module output is an analog signal, we want to signal output terminal connected to the Arduino analog IO On sampling, so as to correctly read the temperature value; Up to this point generally know how to use it, then we need to know about how it is the next temperature measurement?
Specifications
  • The temperature sensor is a NTC thermistor
  • Multi-point temperature measurement Measures temperatures: -55°C / +125°C
  • Accuracy: + / - 0.5°C
Hardware devices
  • Arduino controller × 1
  • USB data cable × 1
  • the analog temperature sensor module × 1
We must have the above things can test to see if an original is a simple thermal how to help us measure the temperature.
Schematic
  • Arduino pin analoog A5 --> module S (Signal)
  • Arduino pin GND - module -
  • Arduino pin 5+ --> middel pin 5V
This code don't give the right values, in a room that was kind of ok it gave a tempature of 10 C. That isn't right so the calculation in the code should be checked.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
#include <math.h>
int sensorPin = A5; // select the input pin for the potentiometer
double Thermistor(int RawADC) {
  double Temp;
  Temp = log(10000.0*((1024.0/RawADC-1)));
  Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
  Temp = Temp - 273.15;            // Convert Kelvin to Celcius
   //Temp = (Temp * 9.0)/ 5.0 + 32.0; // Convert Celcius to Fahrenheit
   return Temp;
void setup() {
void loop() {
 int readVal=analogRead(sensorPin);
 double temp =  Thermistor(readVal);
 Serial.println(temp);  // display tempature
 //Serial.println(readVal);  // display tempature
 delay(500);
cs
https://tkkrlab.nl/wiki/Arduino_KY-013_Temperature_sensor_module
조회수 2,894
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
92 아두이노 tkkrlab - Arduino 37 sensors - KY-022 Infrared sensor receiv… 키트 17-09-13 3031
91 아두이노 tkkrlab - Arduino 37 sensors - KY-021 Mini magnetic reed mod… 키트 17-09-13 2884
90 아두이노 tkkrlab - Arduino 37 sensors - KY-020 Tilt switch module 키트 17-09-13 2973
89 아두이노 tkkrlab - Arduino 37 sensors - KY-019 5V relay module 키트 17-09-13 3030
88 아두이노 tkkrlab - Arduino 37 sensors - KY-018 Photo resistor module 키트 17-09-13 2663
87 아두이노 tkkrlab - Arduino 37 sensors - KY-017 Mercury open optical m… 키트 17-09-13 2633
86 아두이노 tkkrlab - Arduino 37 sensors - KY-016 3-color LED module 키트 17-09-13 2922
85 아두이노 tkkrlab - Arduino 37 sensors - KY-015 Temperature and humidi… 키트 17-09-13 2532
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-013 Temperature sensor mod… 키트 17-09-13 2895
83 아두이노 tkkrlab - Arduino 37 sensors - KY-012 Active buzzer module 키트 17-09-13 2947
82 아두이노 tkkrlab - Arduino 37 sensors - KY-011 2-color LED module 키트 17-09-13 2703
81 아두이노 tkkrlab - Arduino 37 sensors - KY-010 Optical broken module 키트 17-09-13 2677
80 아두이노 tkkrlab - Arduino 37 sensors - KY-009 3-color full-color LED… 키트 17-09-13 2653
79 아두이노 tkkrlab - Arduino 37 sensors - KY-008 Laser sensor module 키트 17-09-13 2967
78 아두이노 tkkrlab - Arduino 37 sensors - KY-006 Small passive buzzer m… 키트 17-09-13 2873
