아두이노 > tkkrlab - Arduino 37 sensors - KY-021 Mini magnetic reed modules
TODAY69 TOTAL2,933,526
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-021 Mini magnetic reed modules
작성자 키트 작성일2017-09-13 14:29 조회2,884회 댓글0건
Arduino KY-021 Mini magnetic reed modules
Ky021
Buy on Dealextream
MINI reed switch module
A reed module is a magnetic sensor that is normally open and get closed when exposed to a magnetic field.
In our example turn off the buildin LED on pin 13 if the sensor is closed. For this you need to keep a magnet near the sensor.
The module includes a 10 K Ohm resistor, so no additional parts needed.
Schematic
  • Arduino GND --> Module pin -
  • Arduino +5V --> Module PLUS (middle pin)
  • Arduino Digital pin 3 --> Module S
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
// Example code for sensor KY021
int Led = 13 ;// define LED Interface
int buttonpin = 3// define the Reed sensor interfaces
int val ;// define numeric variables val
void setup ()
  pinMode (Led, OUTPUT) ;// define LED as output interface
  pinMode (buttonpin, INPUT) ;// output interface as defined Reed sensor
void loop ()
  val = digitalRead (buttonpin) ;// digital interface will be assigned a value of 3 to read val
  if (val == HIGH) // When the Reed sensor detects a signal, LED flashes
    digitalWrite (Led, HIGH);
    digitalWrite (Led, LOW);
cs
https://tkkrlab.nl/wiki/Arduino_KY-021_Mini_magnetic_reed_modules
조회수 2,884
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
92 아두이노 tkkrlab - Arduino 37 sensors - KY-022 Infrared sensor receiv… 키트 17-09-13 3031
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-021 Mini magnetic reed mod… 키트 17-09-13 2885
90 아두이노 tkkrlab - Arduino 37 sensors - KY-020 Tilt switch module 키트 17-09-13 2973
89 아두이노 tkkrlab - Arduino 37 sensors - KY-019 5V relay module 키트 17-09-13 3030
88 아두이노 tkkrlab - Arduino 37 sensors - KY-018 Photo resistor module 키트 17-09-13 2663
87 아두이노 tkkrlab - Arduino 37 sensors - KY-017 Mercury open optical m… 키트 17-09-13 2633
86 아두이노 tkkrlab - Arduino 37 sensors - KY-016 3-color LED module 키트 17-09-13 2922
85 아두이노 tkkrlab - Arduino 37 sensors - KY-015 Temperature and humidi… 키트 17-09-13 2533
84 아두이노 tkkrlab - Arduino 37 sensors - KY-013 Temperature sensor mod… 키트 17-09-13 2895
83 아두이노 tkkrlab - Arduino 37 sensors - KY-012 Active buzzer module 키트 17-09-13 2947
82 아두이노 tkkrlab - Arduino 37 sensors - KY-011 2-color LED module 키트 17-09-13 2703
81 아두이노 tkkrlab - Arduino 37 sensors - KY-010 Optical broken module 키트 17-09-13 2677
80 아두이노 tkkrlab - Arduino 37 sensors - KY-009 3-color full-color LED… 키트 17-09-13 2653
79 아두이노 tkkrlab - Arduino 37 sensors - KY-008 Laser sensor module 키트 17-09-13 2967
78 아두이노 tkkrlab - Arduino 37 sensors - KY-006 Small passive buzzer m… 키트 17-09-13 2873
