아두이노 > tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick module
TODAY946 TOTAL1,145,736
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick module
작성자 키트 작성일2017-09-13 14:30 조회1,075회 댓글0건
Arduino KY-023 XY-axis joystick module
Arduino KY-023 XY-axis joystick module Sku 121340 3
Buy on Dealextream
PS2 game joystick axis sensor module
product description
The company produces PS2 game joystick axis sensor module consists of using original quality metal PS2 joystick potentiometer system For the (X, Y) a 2-axis analog output and for (Z) 1 digital output channel button.
Specifications
The joystick is a combination of 2 analoog potentiometer and a digital switch.
Test
  • Arduino controller × 1
  • USB data cable × 1
  • PS2 Game sensor module × 1
Schematic
  • Arduino GND --> Module pin -
  • Arduino +5V --> Module pin +5V
  • Arduino Analoog 0 --> Module VRx
  • Arduino Analoog 1 --> Module VRy
  • Arduino Digital --> Resistor??-->Module SW
you need a resistor, you can use Arduino internal pullup resistor, Instruccion (pimode(pin, INPUT_PULLUP);) does the job
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
// Module KY023
int JoyStick_X = A0; // x
int JoyStick_Y = A1; // y
int JoyStick_Z = 3// key
void setup ()
  pinMode (JoyStick_X, INPUT);
  pinMode (JoyStick_Y, INPUT);
  pinMode (JoyStick_Z, INPUT_PULLUP);
  Serial.begin (9600); // 9600 bps
void loop ()
  int x, y, z;
  x = analogRead (JoyStick_X);
  y = analogRead (JoyStick_Y);
  z = digitalRead (JoyStick_Z);
  Serial.print (x, DEC);
  Serial.print (",");
  Serial.print (y, DEC);
  Serial.print (",");
  Serial.println (z, DEC);
  delay (100);
cs
https://tkkrlab.nl/wiki/Arduino_KY-023_XY-axis_joystick_module
조회수 1,075
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1183
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1129
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1379
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 1089
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 1017
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 1095
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 982
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1222
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1162
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1182
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1261
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1343
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 1103
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1247
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 1076
