아두이노 > tkkrlab - Arduino 37 sensors - KY-025 Reed module
TODAY1,105 TOTAL1,135,959
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-025 Reed module
작성자 키트 작성일2017-09-13 14:30 조회1,100회 댓글0건
Arduino KY-025 Reed module
WARNING this page is a copy/past of a bad google translation so it might contain errors. If you see a error help us to make it better and log in and change it. Big thanks!
Part of Dealextream 37 sensors in a 1 kit
Reed module
Reed module and the interface comes with digital 13 LED build a simple circuit to produce a Reed warning lamp 13 comes with digital interfaces of the LED, the Reed sensor access number 3 interface, when Reed sensors Sensed a key signal, LED lights, otherwise off.
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
int Led = 13 ; / / define LED Interface
int buttonpin = 3/ / define the Reed sensor interfaces
int val ; / / define numeric variables val
void setup ()
  pinMode (Led, OUTPUT) ; / / define LED as output interface
  pinMode (buttonpin, INPUT) ; / / output interface as defined Reed sensor
void loop ()
SunFounder{
  val = digitalRead (buttonpin) ; / / digital interface will be assigned a value of 3 to read val
  if (val == HIGH) / / When the Reed sensor detects a signal, LED flashes
    digitalWrite (Led, HIGH);
    digitalWrite (Led, LOW);
cs
https://tkkrlab.nl/wiki/Arduino_KY-025_Reed_module
조회수 1,100
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1179
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1123
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1373
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 1084
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 1011
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 1092
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 974
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1217
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1159
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1180
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1256
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1338
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 1101
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1239
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 1071
