아두이노 > tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module
TODAY805 TOTAL1,145,595
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module
작성자 키트 작성일2017-09-13 14:30 조회1,342회 댓글0건
Arduino KY-026 Flame sensor module
Arduino KY-026 Flame sensor module Sku 135038 2
Buy on Dealextream
KEYES ARDUINO flame module
Flame module Interface module and number 13 comes with LED build a simple circuit to produce flame warning lamp 13 comes with digital interfaces of the LED, the flame sensor connected digital three interfaces, when the flame sensor senses There are key signal detected, LED lights, otherwise off.
Sensor for flame wavelengths between 760 nm to 1100 nm infrared is most sensitive 60 degree detection sensor Two outputs mode: AO: analog output- real-time output voltage signal on the thermal resistance DO: when the temperature reaches a certain threshold- the output high and low signal threshold adjustable via potentiometer
Schematic
  • Arduino GND --> Module G
  • Arduino +5V --> Module +
  • Arduino digital 4 --> Module D0
  • Arduino A3 --> Module A0
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
//Example for KY-026
//TkkrLab
int Led = 13 ;// define LED Interface
int buttonpin = 3// define the flame sensor interface
int analoog = A3; // define the flame sensor interface
int val ;// define numeric variables val
float sensor; //read analoog value
void setup ()
  pinMode (Led, OUTPUT) ;// define LED as output interface
  pinMode (buttonpin, INPUT) ;// output interface defines the flame sensor
  pinMode (analoog, INPUT) ;// output interface defines the flame sensor
void loop ()
  sensor = analogRead(analoog);
  Serial.println(sensor);  // display tempature
  val = digitalRead (buttonpin) ;// digital interface will be assigned a value of 3 to read val
    if (val == HIGH) // When the flame sensor detects a signal, LED flashes
    digitalWrite (Led, HIGH);
    digitalWrite (Led, LOW);
cs
https://tkkrlab.nl/wiki/Arduino_KY-026_Flame_sensor_module
조회수 1,342
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1183
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1128
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1378
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 1088
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 1016
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 1095
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 982
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1220
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1162
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1182
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1260
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1343
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 1103
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1246
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 1075
