아두이노 > tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module
TODAY877 TOTAL1,145,667
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module
작성자 키트 작성일2017-09-13 14:31 조회1,260회 댓글0건
Arduino KY-027 Magic light cup module
WARNING this page is a copy/past of a bad google translation so it might contain errors. If you see a error help us to make it better and log in and change it. Big thanks!
Arduino KY-027 Magic light cup module Sku 136115 1
Buy on Dealextream
Magic Light Cup modules are easy to Interactive Technology Division developed a can and ARDUINO interactive modules, PWM dimming principle is to use the principle of two modules brightness changes. Mercury switches provide a digital signal that triggers the PWM regulator, through the program design, We can see the light like two cups filled with the effect of shuffling back and forth.
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
int LedPinA = 5;
int LedPinB = 6;
int ButtonPinA = 7;
int ButtonPinB = 4;
int buttonStateA = 0;
int buttonStateB = 0;
int brightness = 0;
void setup ()
  pinMode (LedPinA, OUTPUT);
  pinMode (LedPinB, OUTPUT);
  pinMode (ButtonPinA, INPUT);
  pinMode (ButtonPinB, INPUT);
void loop ()
  buttonStateA = digitalRead (ButtonPinA);
  if (buttonStateA == HIGH && brightness! = 255)
    brightness + +;
  buttonStateB = digitalRead (ButtonPinB);
  if (buttonStateB == HIGH && brightness! = 0)
    brightness -;
  analogWrite (LedPinA, brightness); / / A few Guan Yuan (ii) ? analogWrite (LedPinB, 255 - brightness);
  / / B Yuan (ii) a few Bang ?
  delay (25);
cs
Note: This experiment requires two modules simultaneously, so buy this product is to purchase two groups
https://tkkrlab.nl/wiki/Arduino_KY-027_Magic_light_cup_module
조회수 1,260
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1183
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1129
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1379
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 1088
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 1016
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 1095
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 982
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1221
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1162
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1182
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1261
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1343
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 1103
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1247
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 1075
