아두이노 > tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor module
TODAY1,766 TOTAL949,907
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor module
작성자 키트 작성일2017-09-13 14:31 조회1,062회 댓글0건
Arduino KY-028 Temperature sensor module
WARNING this page is a copy/past of a bad google translation so it might contain errors. If you see a error help us to make it better and log in and change it. Big thanks!
Arduino KY-028 Temperature sensor module Sku 140022 1
Buy on Dealextream
Magic light cup module
KEYES ARDUINO digital temperature module
Digital temperature module and a digital interface, built-in 13 LED build a simple circuit, making the temperature warning lamp 13 comes with digital interfaces of the LED, the digital temperature sensor connected digital three interfaces, when the digital temperature Sensor senses a key signal, LED lights, otherwise off.
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
int Led = 13 ; / / define LED Interface
int buttonpin = 3/ / define the digital temperature sensor interface
int val ; / / define numeric variables val
void setup ()
  pinMode (Led, OUTPUT) ; / / define LED as output interface
  pinMode (buttonpin, INPUT) ; / / define digital temperature sensor output interface
void loop ()
  val = digitalRead (buttonpin) ; / / digital interface will be assigned a value of 3 to read val
  if (val == HIGH) / / when the digital temperature sensor detects a signal, LED flashes
    digitalWrite (Led, HIGH);
    digitalWrite (Led, LOW);
cs
이 소스는 제대로 된 소스가 아닙니다.
아나로그 온도센서로 LM35D를 사용한 것이므로 아나로그 입력으로 읽어야합니다.​
조회수 1,062
아두이노HOME > 아두이노 > 전체 목록
MCU BASIC ⓒ 2019
