아두이노 > tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED module 3MM
TODAY1,454 TOTAL945,419
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED module 3MM
작성자 키트 작성일2017-09-13 14:31 조회1,035회 댓글0건
Arduino KY-029 Yin Yi 2-color LED module 3MM
WARNING this page is a copy/past of a bad google translation so it might contain errors. If you see a error help us to make it better and log in and change it. Big thanks!
Arduino KY-029 Yin Yi 2-color LED module 3MM Sku 135525 2
Buy on Dealextream
Magic light cup module
5mm red and green LED (common cathode) module
Specifications
  • Color: Green + Red
  • Diameter: 5mm
  • Case Color: None
  • Package Type: Diffusion
  • Voltage (V): G :2.3-2 .6 V; R :1.9-2 .2 V
  • Using a current (MA): 20
  • Viewing angle: Wavelength (NM): 571 +625
  • Luminous intensity (MCD) :20-40; 60-80
  • Stent type: long-legged
Our products are widely used in electronic dictionary, PDA, MP3, headphones, digital cameras, VCD, DVD, car audio, communications, computers, Chargers, power amplifier, instrumentation, gifts, electronic toys and mobile phones, and many other fields.
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
// Arduino test code:
int redpin = 11// select the pin for the red LED
int bluepin = 10// select the pin for the blueLED
int val;
void setup () {
  pinMode (redpin, OUTPUT);
  pinMode (bluepin, OUTPUT);
  Serial.begin (9600);
void loop () {
 for(val=255;val>0;val--) {
   analogWrite (11, val);
   analogWrite (10255 - val);
   delay(5);
 for(val=255;val<255;val++) {
   delay(5);
cs
https://tkkrlab.nl/wiki/Arduino_KY-029_Yin_Yi_2-color_LED_module_3MM
조회수 1,035
아두이노HOME > 아두이노 > 전체 목록
MCU BASIC ⓒ 2019
