아두이노 > tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED module 3MM
TODAY815 TOTAL720,398
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED module 3MM
작성자 키트 작성일2017-09-13 14:31 조회908회 댓글0건
Arduino KY-029 Yin Yi 2-color LED module 3MM
WARNING this page is a copy/past of a bad google translation so it might contain errors. If you see a error help us to make it better and log in and change it. Big thanks!
Arduino KY-029 Yin Yi 2-color LED module 3MM Sku 135525 2
Buy on Dealextream
Magic light cup module
5mm red and green LED (common cathode) module
Specifications
  • Color: Green + Red
  • Diameter: 5mm
  • Case Color: None
  • Package Type: Diffusion
  • Voltage (V): G :2.3-2 .6 V; R :1.9-2 .2 V
  • Using a current (MA): 20
  • Viewing angle: Wavelength (NM): 571 +625
  • Luminous intensity (MCD) :20-40; 60-80
  • Stent type: long-legged
Our products are widely used in electronic dictionary, PDA, MP3, headphones, digital cameras, VCD, DVD, car audio, communications, computers, Chargers, power amplifier, instrumentation, gifts, electronic toys and mobile phones, and many other fields.
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
// Arduino test code:
int redpin = 11// select the pin for the red LED
int bluepin = 10// select the pin for the blueLED
int val;
void setup () {
  pinMode (redpin, OUTPUT);
  pinMode (bluepin, OUTPUT);
  Serial.begin (9600);
void loop () {
 for(val=255;val>0;val--) {
   analogWrite (11, val);
   analogWrite (10255 - val);
   delay(5);
 for(val=255;val<255;val++) {
   delay(5);
cs
https://tkkrlab.nl/wiki/Arduino_KY-029_Yin_Yi_2-color_LED_module_3MM
조회수 908
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 919
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 932
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 993
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 863
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 817
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 884
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 779
100 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 993
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 909
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 948
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 989
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1009
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 859
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 972
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 849
MCU BASIC ⓒ 2019
