아두이노 > tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module
TODAY930 TOTAL1,145,720
BASIC4MCU | 아두이노 | 아두이노 | tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module
작성자 키트 작성일2017-09-13 14:31 조회1,221회 댓글0건
Arduino KY-031 Sensor module
WARNING this page is a copy/past of a bad google translation so it might contain errors. If you see a error help us to make it better and log in and change it. Big thanks!
Part of Dealextream 37 sensors in a 1 kit
KEYES ARDUINO knock sensor module
13 knock sensor module and a digital interface, built-in LED build a simple circuit to produce percussion flasher. 13 Interface comes with digital LED, will knock sensor connected digital 3 interface, when percussion sensor senses Measure To percussive signals, LED flashing light.
Example Code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
int Led = 13 ; // define LED Interface
int Shock = 3 // define the percussion Sensor Interface
int val ; // define numeric variables val
void setup ()
  pinMode (Led, OUTPUT) ; // define LED as output interface
  pinMode (Shock, INPUT) ; // define knock sensor output interface
void loop ()
  val = digitalRead (Shock) ; // read digital interface is assigned a value of 3 val
  if (val == HIGH) // When the percussion when the sensor detects a signal, LED flashes
    digitalWrite (Led, LOW);
    digitalWrite (Led, HIGH);
cs
https://tkkrlab.nl/wiki/Arduino_KY-031_Sensor_module
조회수 1,221
아두이노HOME > 아두이노 > 전체 목록
아두이노 목록
107 아두이노 tkkrlab - Arduino 37 sensors - KY-038 Microphone sound senso… 키트 17-09-13 1183
106 아두이노 tkkrlab - Arduino 37 sensors - KY-037 Sensitive microphone s… 키트 17-09-13 1129
105 아두이노 tkkrlab - Arduino 37 sensors - KY-036 Metal touch sensor mod… 키트 17-09-13 1379
104 아두이노 tkkrlab - Arduino 37 sensors - KY-035 Class Bihor magnetic s… 키트 17-09-13 1089
103 아두이노 tkkrlab - Arduino 37 sensors - KY-034 Automatic flashing col… 키트 17-09-13 1016
102 아두이노 tkkrlab - Arduino 37 sensors - KY-033 Hunt sensor module 키트 17-09-13 1095
101 아두이노 tkkrlab - Arduino 37 sensors - KY-032 Obstacle avoidance sen… 키트 17-09-13 982
현재글 아두이노 tkkrlab - Arduino 37 sensors - KY-031 knock Sensor module 키트 17-09-13 1222
99 아두이노 tkkrlab - Arduino 37 sensors - KY-029 Yin Yi 2-color LED mod… 키트 17-09-13 1162
98 아두이노 tkkrlab - Arduino 37 sensors - KY-028 Temperature sensor mod… 키트 17-09-13 1182
97 아두이노 tkkrlab - Arduino 37 sensors - KY-027 Magic light cup module 키트 17-09-13 1261
96 아두이노 tkkrlab - Arduino 37 sensors - KY-026 Flame sensor module 키트 17-09-13 1343
95 아두이노 tkkrlab - Arduino 37 sensors - KY-025 Reed module 키트 17-09-13 1103
94 아두이노 tkkrlab - Arduino 37 sensors - KY-024 Linear magnetic Hall s… 키트 17-09-13 1247
93 아두이노 tkkrlab - Arduino 37 sensors - KY-023 XY-axis joystick modul… 키트 17-09-13 1075
