BASIC4MCU | 라즈베리파이 | 라즈베리파이 | Arduino|Raspberry Pi|Electronic Circuits|AVR|PIC|8051|Electronic Projects - engineersgarage.com
작성자 키트 작성일2017-09-13 15:52 조회1,266회 댓글0건본문
Arduino Projects & Tutorials
An Arduino Board is AVR microcontroller based board which follows the standard arduino schematic and is flashed with the arduino boot-loader. The arduino is referred as open source hardware, since the standard schematic is open to everyone and anybody can make their own version of arduino board following the standard schematic. All arduino boards should be compatible with the arduino IDE which can be used to program the arduino boards. The arduino IDE is also open source and anybody can contribute their libraries to the arduino.
The arduino board has all the required circuitry to get the built-in AVR microcontroller running. The output or inputs can be taken from the boards or given to the board using convenient connectors. Both digital and analog inputs and outputs are available in all arduino boards. The arduino boards can also communicate with other devices using standard communication ports like USART, IIC, and USB etc. The most impressive thing is that most of the arduino boards are bread-board compatible which makes both the hobbyist and developers happy.
This section of EG Labs brings you some basic tutorials and interesting arduino projects based on Arduino Pro Mini Board. Explained with the help of circuit diagrams, source codes, and working videos, these arduino projects can serve as a good reference for final year electronics engineering projects.
Latest Arduino Projects
This is a project based on Arduino board which can measure the unknown AC and DC voltages. When we connect the unknown voltage on the breadboard circuit, the 16x2 LCD displays the voltage value. The project uses an Arduino pro mini board whose ADC feature is used along with the concept of Voltage Divider circuit to develop this Voltmeter.
조회수 1,266등록된 댓글이 없습니다.
