8051/PIC > DT516-023.c 16비트 타이머 인터럽트를 사용한 9999 카운터
TODAY740 TOTAL2,272,991
BASIC4MCU | 8051/PIC | DT-516 강좌 | DT516-023.c 16비트 타이머 인터럽트를 사용한 9999 카운터
작성자 키트 작성일2017-08-21 17:13 조회1,367회 댓글0건
첨부파일
3660040649_UP6yr0wL_dt516-023-25C725C125B625F525C425A125BD25BA25C425DA2528francis11012529_ekit.jpg3Ftype3Dw740
// XTAL : 22.1184Hz
// filename: DT516-023.c
// 16비트 타이머 인터럽트를 사용한 9999 카운터
#include
#define  U_C      unsigned char
#define  U_I      unsigned int
#define  U_L      unsigned long
#define  I_C      idata char
#define  I_I      idata int
#define  I_L      idata long
#define  I_F      idata float
#define  IU_C     idata unsigned char
#define  IU_I     idata unsigned int
#define  IU_L     idata unsigned long
#define  X_C      xdata char
#define  X_I      xdata int
#define  X_L      xdata long
#define  X_F      xdata float
#define  XU_C     xdata unsigned char
#define  XU_I     xdata unsigned int
#define  XU_L     xdata unsigned long
#define  C_C      code char
#define  C_I      code int
#define  C_L      code long
#define  C_F      code float
#define  CU_C     code unsigned char
#define  CU_I     code unsigned int
#define  CU_L     code unsigned long
#define  FND_COM1  P40
#define  FND_COM2  P41
#define  FND_COM3  P42
#define  FND_COM4  P43
#define  FND_SEG   P0
CU_C Seg_Data[]={
    0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E //0123456789AbcdEF
bit delay_flg=0;
U_C FND_CNT=0;
U_I delay_buf=0, counter=0;
void Timer_0_Interrupt(void) interrupt 1{  // 1ms 주기
    TR0=0; TL0=63693&0xFF; TH0=63693>>8; TR0=1;
    P4=0xFF; // FND OFF
    switch(FND_CNT){
        case 0: P0=Seg_Data[counter/1000];     FND_COM1=0; break;
        case 1: P0=Seg_Data[(counter/100)%10]; FND_COM2=0; break;
        case 2: P0=Seg_Data[(counter/ 10)%10]; FND_COM3=0; break;
        case 3: P0=Seg_Data[counter%10];       FND_COM4=0; break;
    if(++FND_CNT>3)FND_CNT=0;
    if(delay_buf){ if(--delay_buf==0)delay_flg=1; }
void delay_ms(U_I d){
    if(d==0)delay_buf=1;
    else    delay_buf=d;
    TL0=63693&0xFF; TH0=63693>>8; delay_flg=0; while(!delay_flg);
void main(){
    // 22118400/12/1843=1000.1085Hz=0.99989ms, 65536-1843=63693
    TMOD=1; TL0=63693&0xFF; TH0=63693>>8; ET0=1; TR0=1; EA=1;
        for(counter=0;counter<10000;counter++)delay_ms(1000);
16비트 타이머 모드로 타이머0을 구동 하는 예제입니다.
TL0과 TH0에 63693을 넣어주고 0xFFFF까지 카운트 한후 0으로 오버플로우 할 때에 인터럽트가 발생 합니다.
63693 부터 65536까지의 1843 갯수만큼 카운트 하고나서 인터럽트가 걸리므로 1ms 주기가 됩니다.
오버플로우가 발생 하고나서 인터럽트 함수가 실행 될 때까지의 시간과
카운터 값을 갱신 할 때까지 걸리는 시간만큼 시간지연이 더 발생하며
긴 명령어를 수행 하다가 오버플로우가 발생 하는 때
짧은 명령어를 수행 하다가 오버플로우가 발생 하는 때가 각각 다르므로
인터럽트 함수에 진입 할 때까지의 시간이 매번 다릅니다.
인터럽트가 발생 해도 하던 명령어는 실행을 마치고 인터럽트가 수행 됩니다.
오버플로우 인터럽트로는 정확한 시간을 만들지 못 하므로 정확한 시계용으로 사용 하지 않습니다.
조회수 1,367
