BASIC4MCU | 8051/PIC | DT-516 강좌 | DT516-025.c 13비트 타이머 인터럽트를 사용한 시계(시분) & 시계(분초)
작성자 키트 작성일2017-08-21 17:16 조회1,413회 댓글0건첨부파일
// XTAL : 22.1184Hz
// filename: DT516-025.c
// 13비트 타이머 인터럽트를 사용한 시계(시분)
#include <REG_MPC82G516.H>
#define U_C unsigned char
#define U_I unsigned int
#define U_L unsigned long
#define I_C idata char
#define I_I idata int
#define I_L idata long
#define I_F idata float
#define IU_C idata unsigned char
#define IU_I idata unsigned int
#define IU_L idata unsigned long
#define X_C xdata char
#define X_I xdata int
#define X_L xdata long
#define X_F xdata float
#define XU_C xdata unsigned char
#define XU_I xdata unsigned int
#define XU_L xdata unsigned long
#define C_C code char
#define C_I code int
#define C_L code long
#define C_F code float
#define CU_C code unsigned char
#define CU_I code unsigned int
#define CU_L code unsigned long
#define FND_COM1 P40
#define FND_COM2 P41
#define FND_COM3 P42
#define FND_COM4 P43
#define FND_SEG P0
CU_C Seg_Data[]={
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E //0123456789AbcdEF
bit delay_flg=0, H_SecFlg=0;
U_C FND_CNT=0, Tcnt0=0, Sec=0, Min=0, Hour=0;
U_I delay_buf=0;
void Timer_0_Interrupt(void) interrupt 1{ // 225Hz주기
P4=0xFF; // FND OFF
if(Tcnt0<113)H_SecFlg=1;
else H_SecFlg=0;
if(++Tcnt0>=225){ Tcnt0=0; Sec++;
if(Sec >=60){ Sec=0; Min++; }
if(Min >=60){ Min=0; Hour++; }
if(Hour>=24){ Hour=0; }
switch(FND_CNT){
case 0: P0=Seg_Data[Hour/10]; FND_COM1=0; break;
case 1: P0=Seg_Data[Hour%10]; if(H_SecFlg)P07=0; FND_COM2=0; break;
case 2: P0=Seg_Data[Min /10]; FND_COM3=0; break;
case 3: P0=Seg_Data[Min %10]; FND_COM4=0; break;
if(++FND_CNT>3)FND_CNT=0;
if(delay_buf){ if(--delay_buf==0)delay_flg=1; }
void delay_ms(U_I d){
delay_buf=(U_I)((float)d*0.225);
if(delay_buf==0)delay_buf=1;
TH0=0; delay_flg=0; while(!delay_flg);
void main(){
ET0=1; TR0=1; EA=1;
while(1){}
// XTAL : 22.1184Hz
// filename: DT516-025-1.c
// 13비트 타이머 인터럽트를 사용한 시계(분초)
#define FND_SEG P0
CU_C Seg_Data[]={
U_I delay_buf=0;
P4=0xFF; // FND OFF
else H_SecFlg=0;
switch(FND_CNT){
case 0: P0=Seg_Data[Min/10]; FND_COM1=0; break;
case 1: P0=Seg_Data[Min%10]; if(H_SecFlg)P07=0; FND_COM2=0; break;
case 2: P0=Seg_Data[Sec/10]; FND_COM3=0; break;
case 3: P0=Seg_Data[Sec%10]; FND_COM4=0; break;
void main(){
ET0=1; TR0=1; EA=1;
while(1){}
조회수 1,413등록된 댓글이 없습니다.
