8051/PIC > DT516-026.c 딜레이함수를 사용한 FND 대기(?) 표시
TODAY197 TOTAL2,275,306
BASIC4MCU | 8051/PIC | DT-516 강좌 | DT516-026.c 딜레이함수를 사용한 FND 대기(?) 표시
작성자 키트 작성일2017-08-21 17:18 조회1,402회 댓글0건
첨부파일
// XTAL : 22.1184Hz
// filename: DT516-026.c
// 딜레이함수를 사용한 FND 대기(?) 표시
#include <REG_MPC82G516.H>
#define  U_C      unsigned char
#define  U_I      unsigned int
#define  U_L      unsigned long
#define  I_C      idata char
#define  I_I      idata int
#define  I_L      idata long
#define  I_F      idata float
#define  IU_C     idata unsigned char
#define  IU_I     idata unsigned int
#define  IU_L     idata unsigned long
#define  X_C      xdata char
#define  X_I      xdata int
#define  X_L      xdata long
#define  X_F      xdata float
#define  XU_C     xdata unsigned char
#define  XU_I     xdata unsigned int
#define  XU_L     xdata unsigned long
#define  C_C      code char
#define  C_I      code int
#define  C_L      code long
#define  C_F      code float
#define  CU_C     code unsigned char
#define  CU_I     code unsigned int
#define  CU_L     code unsigned long
#define  FND_COM1  P40
#define  FND_COM2  P41
#define  FND_COM3  P42
#define  FND_COM4  P43
#define  FND_SEG   P0
CU_C Seg_Data[]={
    0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E //0123456789AbcdEF
CU_C Test_Data[12][4]={
    0xFE,0xFF,0xFF,0xFF, // a,□,□,□,
    0xFF,0xFE,0xFF,0xFF, // □,a,□,□,
    0xFF,0xFF,0xFE,0xFF, // □,□,a,□,
    0xFF,0xFF,0xFF,0xFE, // □,□,□,a,
    0xFF,0xFF,0xFF,0xFD, // □,□,□,b,
    0xFF,0xFF,0xFF,0xFB, // □,□,□,c,
    0xFF,0xFF,0xFF,0xF7, // □,□,□,d,
    0xFF,0xFF,0xF7,0xFF, // □,□,d,□,
    0xFF,0xF7,0xFF,0xFF, // □,d,□,□,
    0xF7,0xFF,0xFF,0xFF, // d,□,□,□,
    0xEF,0xFF,0xFF,0xFF, // e,□,□,□,
    0xDF,0xFF,0xFF,0xFF, // f,□,□,□,
void delay_ms(U_I d){
    U_I i,j;
    for(i=0;i<d;i++){ for(j=0;j<920;j++); }       // @22.118400Hz
void main(){
    U_I i,k;
        for(i=0;i<12;i++){
            for(k=0;k<50;k++){          // 5ms * 4 = 20ms, 20ms * 50 = 1000ms
                P4=0xFF; P0=Test_Data[i][0]; FND_COM1=0; delay_ms(5);
                P4=0xFF; P0=Test_Data[i][1]; FND_COM2=0; delay_ms(5);
                P4=0xFF; P0=Test_Data[i][2]; FND_COM3=0; delay_ms(5);
                P4=0xFF; P0=Test_Data[i][3]; FND_COM4=0; delay_ms(5);
조회수 1,402
