BASIC4MCU | 8051/PIC | DT-516 강좌 | DT516-140.c - 2명이 즐기는 FND DICE
작성자 키트 작성일2017-08-24 11:00 조회1,505회 댓글0건첨부파일
// XTAL : 22.1184Hz
// filename: DT516-140.c
// 2명이 즐기는 FND DICE
#include
#define U_C unsigned char
#define U_I unsigned int
#define U_L unsigned long
#define I_C idata char
#define I_I idata int
#define I_L idata long
#define I_F idata float
#define IU_C idata unsigned char
#define IU_I idata unsigned int
#define IU_L idata unsigned long
#define X_C xdata char
#define X_I xdata int
#define X_L xdata long
#define X_F xdata float
#define XU_C xdata unsigned char
#define XU_I xdata unsigned int
#define XU_L xdata unsigned long
#define C_C code char
#define C_I code int
#define C_L code long
#define C_F code float
#define CU_C code unsigned char
#define CU_I code unsigned int
#define CU_L code unsigned long
#define FND_COM1 P40
#define FND_COM2 P41
#define FND_COM3 P42
#define FND_COM4 P43
#define FND_SEG P0
CU_C Seg_Data[]={
0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xFF,0xF7 //0123456789AbcdEF,sp,_
bit delay_flg=0;
U_C FND_CNT=0, FND_BUF[4]={16,16,16,16};
U_I delay_buf=0,i=0;
void Timer_0_Interrupt(void) interrupt 1{ // 225Hz주기
P4=0xFF; // FND OFF
switch(FND_CNT){
case 0: P0=Seg_Data[FND_BUF[0]]; FND_COM1=0; break;
case 1: P0=Seg_Data[FND_BUF[1]]; FND_COM2=0; break;
case 2: P0=Seg_Data[FND_BUF[2]]; FND_COM3=0; break;
case 3: P0=Seg_Data[FND_BUF[3]]; FND_COM4=0; break;
if(++FND_CNT>3)FND_CNT=0;
if(delay_buf){ if(--delay_buf==0)delay_flg=1; }
void delay_ms(U_I d){
delay_buf=(U_I)((float)d*0.225);
if(delay_buf==0)delay_buf=1;
TH0=0; delay_flg=0; while(!delay_flg);
void main(){
ET0=1; TR0=1; TR1=1; EA=1;
while(P34); delay_ms(100); while(!P34); delay_ms(100);
FND_BUF[0]=FND_BUF[1]=FND_BUF[2]=FND_BUF[3]= 8; delay_ms(1000);
FND_BUF[0]=FND_BUF[1]=FND_BUF[2]=FND_BUF[3]= 16;
FND_BUF[1]=17; i=1; while(P20){ FND_BUF[0]=i++; if(i>=7)i=1; delay_ms(25); };
i=TH1; i<<=8; i+=TL1; i%=6; FND_BUF[0]=i+1;
delay_ms(100); while(!P20); delay_ms(100); FND_BUF[1]=16;
FND_BUF[2]=17; i=1; while(P23){ FND_BUF[3]=i++; if(i>=7)i=1; delay_ms(25); };
i=TH1; i<<=8; i+=TL1; i%=6; FND_BUF[3]=i+1;
delay_ms(100); while(!P23); delay_ms(100); FND_BUF[2]=16;
조회수 1,505등록된 댓글이 없습니다.
