C언어 > printf Substitution Types
TODAY4,265 TOTAL11,518,527
BASIC4MCU | C언어 | C언어 | printf Substitution Types
작성자 master 작성일2018-02-05 23:42 조회2,965회 댓글0건
Type field[edit]
The Type field can be any of:
CharacterDescription
%Prints a literal % character (this type doesn't accept any flags, width, precision, length fields).
diint as a signed decimal number. %d and %i are synonymous for output, but are different when used with scanf() for input (where using %i will interpret a number as hexadecimal if it's preceded by 0x, and octal if it's preceded by 0.)
uPrint decimal unsigned int.
fFdouble in normal (fixed-point) notation. f and F only differs in how the strings for an infinite number or NaN are printed (infinfinity and nan for fINFINFINITY and NAN for F).
eEdouble value in standard form ([-]d.ddd e[+/-]ddd). An E conversion uses the letter E (rather than e) to introduce the exponent. The exponent always contains at least two digits; if the value is zero, the exponent is 00. In Windows, the exponent contains three digits by default, e.g. 1.5e002, but this can be altered by Microsoft-specific _set_output_format function.
gGdouble in either normal or exponential notation, whichever is more appropriate for its magnitude. g uses lower-case letters, G uses upper-case letters. This type differs slightly from fixed-point notation in that insignificant zeroes to the right of the decimal point are not included. Also, the decimal point is not included on whole numbers.
xXunsigned int as a hexadecimal number. x uses lower-case letters and X uses upper-case.
ounsigned int in octal.
snull-terminated string.
cchar (character).
pvoid * (pointer to void) in an implementation-defined format.
aAdouble in hexadecimal notation, starting with 0x or 0Xa uses lower-case letters, A uses upper-case letters.[3][4] (C++11 iostreams have a hexfloat that works the same).
nPrint nothing, but writes the number of characters successfully written so far into an integer pointer parameter.
Java: indicates a platform neutral newline/carriage return.[5]
Note: This can be utilized in Uncontrolled format string exploits.
https://en.wikipedia.org/wiki/Printf_format_string
조회수 2,965
C언어HOME > C언어 > 전체 목록
C언어 목록
125 C언어 Timeline of programming languages 이미지 master 18-09-05 4592
124 C언어 printf format string - 위키 백과 이미지 master 18-08-24 3836
현재글 C언어 printf Substitution Types master 18-02-05 2966
122 C언어 Escape sequence master 18-02-05 2969
121 운영체제 없는 프로그래밍 강좌 [펌] qt로 프로그램 만들기 강좌 채팅 서버와 클라이언트 키트 17-09-12 3803
120 운영체제 없는 프로그래밍 강좌 [펌] qt로 프로그램 만들기 강좌 - 서버 키트 17-09-12 2878
119 운영체제 없는 프로그래밍 강좌 [펌] qt로 gui 프로그램 만들기 강좌 - 파일 열기 타이머 키트 17-09-12 3172
118 운영체제 없는 프로그래밍 강좌 [펌] qt로 gui 프로그램 만들기 강좌 - 미로 탈출 키트 17-09-12 2717
117 운영체제 없는 프로그래밍 강좌 [펌] qt로 gui 프로그램 만들기 강좌 - 미로 맵 출력 키트 17-09-12 3154
116 운영체제 없는 프로그래밍 강좌 [펌] qt로 gui 프로그램 만들기 강좌 - 그림띄우기와 충돌처리 키트 17-09-12 2804
115 운영체제 없는 프로그래밍 강좌 [펌] qt로 gui 프로그램 만들기 강좌 - 오늘의 유머 랜덤 베오베 글 키트 17-09-12 2775
114 운영체제 없는 프로그래밍 강좌 [펌] qt로 gui프로그램 만들기 강좌 - 더하기 출력 키트 17-09-12 4427
113 운영체제 없는 프로그래밍 강좌 [펌] 운영체제 없는 프로그래밍 강좌 문자열 출력 키트 17-09-12 2683
112 운영체제 없는 프로그래밍 강좌 [펌] 운영체제 없는 프로그래밍 강좌 문자 1개 출력 키트 17-09-12 2662
111 운영체제 없는 프로그래밍 강좌 [펌] 운영체제 없이 화면에 점찍기 키트 17-09-12 3100
