BASIC4MCU | C언어 | C언어 | printf format string - 위키 백과
작성자 master 작성일2018-08-24 16:34 조회2,702회 댓글0건본문
Jump to navigationJump to search
This article needs additional citations for verification. (February 2015) (Learn how and when to remove this template message)
printf format string refers to a control parameter used by a class of functions in the input/output libraries of C and many other programming languages. The string is written in a simple template language: characters are usually copied literally into the function's output, but format specifiers, which start with a % character, indicate the location and method to translate a piece of data (such as a number) to characters.
"printf" is the name of the most-used C output function, and stands for "print formatted". printf format strings are complementary to scanf format strings, which provide formatted input (parsing). In both cases these provide simple functionality and fixed format compared to more sophisticated and flexible template engines or parsers, but are sufficient for many purposes.
Many languages other than C copy the printf format string syntax closely or exactly in their own I/O functions.
Mismatches between the format specifiers and type of the data can cause crashes and other vulnerabilities. The format string itself is very often a string literal, which allows static analysis of the function call. However, it can also be the value of a variable, which allows for dynamic formatting but also a security vulnerability known as an uncontrolled format string exploit.
Contents
History[edit]
Early programming languages such as Fortran used special statements with completely different syntax from other calculations to build formatting descriptions:
WRITE OUTPUT TAPE 6, 601, IA, IB, IC, AREA 601 FORMAT (4H A= ,I5,5H B= ,I5,5H C= ,I5,8H AREA= ,F10.2, 13H SQUARE UNITS)ALGOL 68 had more function-like api, but still used special syntax (the $ delimiters surround special formatting syntax):
printf(($"Color "g", number1 "6d,", number2 "4zd,", hex "16r2d,", float "-d.2d,", unsigned value"-3d"."l$, "red", 123456, 89, BIN 255, 3.14, 250));But using the normal function calls and data types simplifies the language and compiler, and allows the implementation of the input/output to be written in the same language. These advantages outweigh the disadvantages (such as a complete lack of type safety in many instances) and in most newer languages I/O is not part of the syntax.
C's
printf
has its origins in BCPL'swritef
function (1966). *N is a newline, and the order of field width and type are swapped from printf:[1]
WRITEF("%I2-QUEENS PROBLEM HAS %I5 SOLUTIONS*N", NUMQUEENS, COUNT)Probably the first copying of the syntax to outside the C language was the Unix printf shell command, which first appeared in Version 4, as part of the porting to C.[2]
Format placeholder specification[edit]
Formatting takes place via placeholders within the format string. For example, if a program wanted to print out a person's age, it could present the output by prefixing it with "Your age is ". To denote that we want the integer for the age to be shown immediately after that message, we may use the format string:
printf("Your age is %d", age);Syntax[edit]
The syntax for a format placeholder is
%[parameter][flags][width][.precision][length]typeParameter field[edit]
This is a POSIX extension and not in C99. The Parameter field can be omitted or can be:
Character Description n$
n is the number of the parameter to display using this format specifier, allowing the parameters provided to be output multiple times, using varying format specifiers or in different orders. If any single placeholder specifies a parameter, all the rest of the placeholders MUST also specify a parameter.
For example,printf("%2$d %2$#x; %1$d %1$#x",16,17)
produces17 0x11; 16 0x10
.Flags field[edit]
The Flags field can be zero or more (in any order) of:
Character Description -
(minus)Left-align the output of this placeholder. (The default is to right-align the output.) +
(plus)Prepends a plus for positive signed-numeric types. positive = +
, negative =-
(The default doesn't prepend anything in front of positive numbers.)
(space)Prepends a space for positive signed-numeric types. positive = , negative =
. This flag is ignored if the+
flag exists.
(The default doesn't prepend anything in front of positive numbers.)0
(zero)When the 'width' option is specified, prepends zeros for numeric types. (The default prepends spaces.)
For example,printf("%2X",3)
produces3
, whileprintf("%02X",3)
produces in03
(hash)Alternate form:
Forg
andG
types, trailing zeros are not removed.
Forf
,F
,e
,E
,g
,G
types, the output always contains a decimal point.
Foro
,x
,X
types, the text0
,0x
,0X
, respectively, is prepended to non-zero numbers.Width field[edit]
The Width field specifies a minimum number of characters to output, and is typically used to pad fixed-width fields in tabulated output, where the fields would otherwise be smaller, although it does not cause truncation of oversized fields.
The width field may be omitted, or a numeric integer value, or a dynamic value when passed as another argument when indicated by an asterisk
. For example,printf("%*d", 5, 10)
will result in10
being printed, with a total width of 5 characters.Though not part of the width field, a leading zero is interpreted as the zero-padding flag mentioned above, and a negative value is treated as the positive value in conjunction with the left-alignment
flag also mentioned above.Precision field[edit]
The Precision field usually specifies a maximum limit on the output, depending on the particular formatting type. For floating point numeric types, it specifies the number of digits to the right of the decimal point that the output should be rounded. For the string type, it limits the number of characters that should be output, after which the string is truncated.
The precision field may be omitted, or a numeric integer value, or a dynamic value when passed as another argument when indicated by an asterisk
. For example,printf("%.*s", 3, "abcdef")
will result inabc
being printed.Length field[edit]
The Length field can be omitted or be any of:
Character Description hh
For integer types, causes printf
to expect anint
-sized integer argument which was promoted from achar
.h
to expect anint
-sized integer argument which was promoted from ashort
.l
to expect along
-sized integer argument.For floating point types, this has no effect.[3]
ll
to expect along long
-sized integer argument.L
For floating point types, causes printf
to expect along double
argument.z
to expect asize_t
-sized integer argument.j
to expect aintmax_t
-sized integer argument.t
to expect aptrdiff_t
-sized integer argument.Additionally, several platform-specific length options came to exist prior to widespread use of the ISO C99 extensions:
Characters Description I
For signed integer types, causes printf
to expectptrdiff_t
-sized integer argument; for unsigned integer types, causesprintf
to expectsize_t
-sized integer argument. Commonly found in Win32/Win64 platforms.I32
to expect a 32-bit (double word) integer argument. Commonly found in Win32/Win64 platforms.I64
to expect a 64-bit (quad word) integer argument. Commonly found in Win32/Win64 platforms.q
to expect a 64-bit (quad word) integer argument. Commonly found in BSD platforms.ISO C99 includes the
inttypes.h
header file that includes a number of macros for use in platform-independentprintf
coding. These need to not be inside double-quotes, e.g.printf("%" PRId64 "\n", t);
Example macros include:
Macro Description PRId32
Typically equivalent to I32d
(Win32/Win64) ord
PRId64
Typically equivalent to I64d
(Win32/Win64),lld
(32-bit platforms) orld
(64-bit platforms)PRIi32
Typically equivalent to I32i
(Win32/Win64) ori
PRIi64
Typically equivalent to I64i
(Win32/Win64),lli
(32-bit platforms) orli
(64-bit platforms)PRIu32
Typically equivalent to I32u
(Win32/Win64) oru
PRIu64
Typically equivalent to I64u
(Win32/Win64),llu
(32-bit platforms) orlu
(64-bit platforms)PRIx32
Typically equivalent to I32x
(Win32/Win64) orx
PRIx64
Typically equivalent to I64x
(Win32/Win64),llx
(32-bit platforms) orlx
(64-bit platforms)Type field[edit]
The Type field can be any of:
Character Description %
Prints a literal %
character (this type doesn't accept any flags, width, precision, length fields).d
,i
int
as a signed decimal number.%d
and%i
are synonymous for output, but are different when used withscanf()
for input (where using%i
will interpret a number as hexadecimal if it's preceded by0x
, and octal if it's preceded by0
.)u
Print decimal unsigned int
.f
,F
double
in normal (fixed-point) notation.f
andF
only differs in how the strings for an infinite number or NaN are printed (inf
,infinity
andnan
forf
;INF
,INFINITY
andNAN
forF
).e
,E
double
value in standard form ([-
]d.ddde
]ddd). AnE
conversion uses the letterE
(rather thane
) to introduce the exponent. The exponent always contains at least two digits; if the value is zero, the exponent is00
. In Windows, the exponent contains three digits by default, e.g.1.5e002
, but this can be altered by Microsoft-specific_set_output_format
function.g
,G
double
in either normal or exponential notation, whichever is more appropriate for its magnitude.g
uses lower-case letters,G
uses upper-case letters. This type differs slightly from fixed-point notation in that insignificant zeroes to the right of the decimal point are not included. Also, the decimal point is not included on whole numbers.x
,X
unsigned int
as a hexadecimal number.x
uses lower-case letters andX
uses upper-case.o
unsigned int
in octal.s
null-terminated string. c
char
(character).p
void *
(pointer to void) in an implementation-defined format.a
,A
double
in hexadecimal notation, starting with0x
or0X
.a
uses lower-case letters,A
uses upper-case letters.[4][5](C++11 iostreams have ahexfloat
that works the same).n
Print nothing, but writes the number of characters successfully written so far into an integer pointer parameter.
Java: indicates a platform neutral newline/carriage return.[6]
Note: This can be utilized in Uncontrolled format string exploits.Custom format placeholders[edit]
There are a few implementations of
printf
-like functions that allow extensions to the escape-character-based mini-language, thus allowing the programmer to have a specific formatting function for non-builtin types. One of the most well-known is the (now deprecated) glibc'sregister_printf_function()
. However, it is rarely used due to the fact that it conflicts with static format string checking. Another is Vstr custom formatters, which allows adding multi-character format names.Some applications (like the Apache HTTP Server) include their own
printf
-like function, and embed extensions into it. However these all tend to have the same problems thatregister_printf_function()
has.The Linux kernel
printk
function supports a number of ways to display kernel structures using the generic%p
specification, by appendingadditional format characters.[7] For example,%pI4
prints an IPv4 address in dotted-decimal form. This allows static format string checking (of the%p
portion) at the expense of full compatibility with normal printf.Most non-C languages that have a
printf
-like function work around the lack of this feature by just using the%s
format and converting the object to a string representation. C++ offers a notable exception, in that it has aprintf
function inherited from its C history, but also has a completely different mechanism that is preferred.Vulnerabilities[edit]
Invalid conversion specifications[edit]
If the syntax of a conversion specification is invalid, behavior is undefined, and can cause program termination. If there are too few function arguments provided to supply values for all the conversion specifications in the template string, or if the arguments are not of the correct types, the results are also undefined. Excess arguments are ignored. In a number of cases, the undefined behavior has led to "Format string attack" security vulnerabilities.
Some compilers, like the GNU Compiler Collection, will statically check the format strings of printf-like functions and warn about problems (when using the flags
-Wall
or-Wformat
). GCC will also warn about user-defined printf-style functions if the non-standard "format"__attribute__
is applied to the function.Field width versus explicit delimiters in tabular output[edit]
Using only field widths to provide for tabulation, as with a format like
%8d%8d%8d
for three integers in three 8-character columns, will not guarantee that field separation will be retained if large numbers occur in the data. Loss of field separation can easily lead to corrupt output. In systems which encourage the use of programs as building blocks in scripts, such corrupt data can often be forwarded into and corrupt further processing, regardless of whether the original programmer expected the output would only be read by human eyes. Such problems can be eliminated by including explicit delimiters, even spaces, in all tabular output formats. Simply changing the dangerous example from before to%7d %7d %7d
addresses this, formatting identically until numbers become larger, but then explicitly preventing them from becoming merged on output due to the explicitly included spaces. Similar strategies apply to string data.Programming languages with printf[edit]
Languages that use format strings that deviate from the style in this article (such as AMPL and Elixir), languages that inherit their implementation from the JVM or other environment (such as Clojure and Scala), and languages that do not have a standard native printf implementation but have external libraries which emulate printf behavior (such as JavaScript) are not included in this list.
- awk (via sprintf)
- C
- C++ (also provides overloaded shift operators and manipulators as an alternative for formatted output – see iostream and iomanip)
- Objective-C
- D
- F#
- G (LabVIEW)
- GNU MathProg
- GNU Octave
- Go
- Haskell
- J
- Java (since version 1.5) and JVM languages
- Lua (string.format)
- Maple
- MATLAB
- Max (via the sprintf object)
- Mythryl
- PARI/GP
- Perl
- PHP
- Python ( via % operator)
- R
- Red/System
- Ruby
- Tcl (via format command)
- Transact-SQL (via xp_sprintf)
- Vala (via
print()
andFileStream.printf()
)- The printf utility command, sometimes built in the shell like some implementations of the Korn shell (ksh), Bourne again shell (bash), or Z shell (zsh). These commands usually interpret C escapes in the format string.
See also[edit]
- Format (Common Lisp)
- C standard library
- Format string attack
- iostream
- ML (programming language)
- printf debugging
- printf (Unix)
- printk (print kernel messages)
- scanf
- string interpolation
References[edit]
- Jump up^ "BCPL". www.cl.cam.ac.uk. Retrieved 19 March 2018.
- Jump up^ McIlroy, M. D. (1987). A Research Unix reader: annotated excerpts from the Programmer's Manual, 1971–1986 (PDF) (Technical report). CSTR. Bell Labs. 139.
- Jump up^ ISO/IEC (1999). ISO/IEC 9899:1999(E): Programming Languages - C§7.19.6.1 para 7
- Jump up^ ""The GNU C Library Reference Manual", "12.12.3 Table of Output Conversions"". Gnu.org. Retrieved 2014-03-17.
- Jump up^ "printf" (
%a
added in C99)- Jump up^ "Formatting Numeric Print Output". The Java Tutorials. Oracle Inc. Retrieved 19 March 2018.
- Jump up^ "Linux kernel Documentation/printk-formats.txt". Git.kernel.org. Retrieved 2014-03-17.
External links[edit]
- C++ reference for
std::fprintf
- gcc printf format specifications quick reference
- The Single UNIX Specification, Issue 7 from The Open Group
: print formatted output – System Interfaces Reference,- The
Formatter
specification in Java 1.5- GNU Bash
printf(1)
builtin
https://en.wikipedia.org/wiki/Printf_format_string
조회수 2,702등록된 댓글이 없습니다.
