BASIC4MCU | C언어 | 델파이 | Lamwino: Lazarus Arduino Module Wizard: Version 0.1
작성자 master 작성일2018-09-27 16:58 조회1,704회 댓글0건본문
"A wizard to create Arduino loadable module (.hex) using Lazarus/Free Pascal" https://github.com/jmpessoa/lazarduinomodulewizard http://forum.lazarus.freepascal.org/index.php?topic=31513.msg201993 Key Features: 1.Builder for FPC avr/arduino cross compiler 2.New Project option: "Arduino [avr] Module" 3.Install ".hex" module in Arduino device Author: Jose Marques Pessoa jmpessoa_hotmail_com https://github.com/jmpessoa/lazarduinomodulewizard Acknowledgements [all teachings!]: -Ygot, -HatForCat -Engkin ref. http://forum.lazarus.freepascal.org/index.php/topic,30960.msg201921.html#msg201921
Version 0.1 revision 03 - 24 Fev - 2016
NEW! Added string support to Serial NEW! LamwinoDemo4 [String Serial demo] //<---- Please, use some "Serial Monitor" app to send and receive info...
Version 0.1 revision 02 - 22 Feb - 2016
NEW! Added support to Serial [COM] NEW! LamwinoDemo3 [Serial demo] //<---- Please, use some "Serial Monitor" app to send and receive info... WARNING! Please, configure NEW "Path do code Templates" IDE menu "Tools" --> [Lamwino] Arduino Module Wizard --> Settings IMPROVED! Added support to commons Arduino chip IMPROVED! Usability
Version 0.1 revision 01 - 14 Feb - 2016
NEW! Added support to Arduino Mega 2560
Prerequisites/Infrastructure
Arduino IDE: [drives, binutils, toolchains, avrdude, serial monitor, etc...] ref. https://www.arduino.cc/en/Main/Software
SlikSvn: command line SVN client ref. https://sliksvn.com/pub/Slik-Subversion-1.8.11-win32.msi [windows]
Optional: Serial-Monitor-Deluxe [Pure FPC/Lazarus app!!] [windows] ref. http://www.idogendel.com/en/products/serial-monitor-deluxe
Lamwino Install
arduinonewprojectwizard.lpk lamwino_ide_tools.lpk [..../ide-tools]
Lamwino Use
- Settings:
Lazarus IDE menu "Tools" ---> "[Lamwino] Arduino Module Wizard" --> "Settings ..."
3.2. Building FPC AVR/Arduino cross compiler
Lazarus IDE menu "Tools" ---> "[Lamwino] Arduino Module Wizard" --> "Get FPC Source" .[if you do not have it!] Lazarus IDE menu "Tools" ---> "[Lamwino] Arduino Module Wizard" --> "Build FPC Cross Arduino" .Build .Install
3.3 New Project
.Lazarus IDE select "Project" -> "New Project" .Arduino Avr Module [Lamwino] .Path to projects folder .Project Name .Target .Generad Code [to start] [x]Blinking //<---- * LamwinoDemo1, thanks to @ykot! .OK .Save .Lazarus IDE menu "Run" ---> "Build" {------------------------------------- .check for usb/pc/arduino connection .check for arduino COM port used *** -------------------------------------} .Lazarus IDE menu "Run" ---> "[Lamwino] Install/Run" .Congratulations!!! \o/ \o/ \o/ \o/ ***How to Detect Arduino used COM Port 1.Windows 10 Start Menu Settings Devices Connected Devices 2. All Windows: Controls Panel Device Manager Ports(COM & LPT)
3.4 Using Demos [....\demos]
.Go to project ".lpi" and [if needed] change: atmega328p [and avr5] according to you arduino device [and compiler!] <Item0 Name="AVRCHIP" Value="atmega328p"/> <CustomOptions Value="-Cpavr5 -Wpatmega328p -a"/> Note: atmega328p and avr5 are "Arduino Uno" compatibles!
References:
.FPC/Lazarus Arduino Tutorial ref. http://forum.lazarus.freepascal.org/index.php/topic,30960.msg201921.html#msg201921
.Arduino UNO Pinout Diagram ref. http://forum.arduino.cc/index.php?topic=146315.0
.I/O Port Operations in AVR ref. http://maxembedded.com/2011/06/port-operations-in-avr/
.Cduino: Arduino Programming with C and Make ref. http://brittonkerin.com/cduino/lessons.html LamwinoDemo2 <<--- lesson3!
Thanks to All!
by jmpessoa [jmpessoa[AT]hotmail[DOT]com]
http://forum.lazarus.freepascal.org/index.php/topic,30960.30.html
조회수 1,704등록된 댓글이 없습니다.
