C언어 > Components and Code examples
TODAY282 TOTAL2,579,451
BASIC4MCU | C언어 | 델파이 | Components and Code examples
작성자 master 작성일2018-09-28 17:26 조회1,852회 댓글0건
Lazarus-CCR Released Components
멀티미디어
  • ACS - Audio Component Suite port from ACS
  • Bluetooth - Accessing Bluetooth devices. For example the Wiimote.
그래픽
  • GLScene - A port of the visual OpenGL graphics Library GLScene
  • TOpenGLBox - A barebones OpenGL component for Lazarus that provides an OpenGL rendering area.
  • SMNetGradient - A Gradient Fill component for Lazarus.
  • TAChart - Charting component for Lazarus
  • PlotPanel - A plotting and charting component for animated graphs
  • LazRGBGraphics - A package for fast in memory image processing and pixel manipulations (like scan line).
  • TMetafile/TMetafileCanvas - EnhMetafile API implementation for Windows.
Tools
  • FpSystools - Conversion of TurboPower's Systools for Kylix package to Lazarus/FPC
  • DCPcrypt - DCPcrypt Cryptographic Component Library
  • RXfpc - Some of the well known RXlib components components converted to Lazarus
  • MultiLog - A Log system designed for FPC-Lazarus
  • OnGuard - A port of Turbo Power OnGuard
  • UniqueInstance - A component to force only one instance running at same time
  • XDev Toolkit - Cross-platform development tools.
  • MouseAndKeyInput - Tool for cross-platform manipulation with mouse and key input.
  • PascalSane - bindings for the libsane scanner API, with demo application.
압축
  • Zlibar - Objects to create and extract a zlib compressed archive containing multiple files
  • FreePascalArchivePackage - Conversion of TurboPower Software's Abbrevia library for the Free Pascal Compiler
  • ZipFile - Component that encapsulates a zipfile, you can read and write from it as if it's a filesystem
  • libtar - Classes for .TAR archives by Stefan Heymann, who kindly relicensed so that they are now in the FPC 2.1.1 and later distributions. Can be combined by zstream to create .tar.gz files.
에디터와 뷰어
  • PowerPDF - Port of the PowerPDF (visual) components for Lazarus
  • RichView - Port of the TRichView Freeware Edition Components to Lazarus
  • Fshcomp - Edit components.
  • SynEdit - Source Editor component (used by the IDE)
네트워킹
  • Hprose - Hprose is a High Performance Remote Object Service Engine. It is a fast serialize and RPC library for Delphi and FreePascal.
  • Sockets - TCP/IP Sockets components
  • lNet - Networking components for TCP and UDP connections
  • FPC and Apache Modules - Headers for creating Apache modules with fpc
  • Web Services Toolkit - Web Services authoring and consumption
데이터베이스
  • fb embedded2 Laz - Using embedded FireBird 3 with Lazarus
  • TPSQL - Components for connecting to PostgreSQL database servers
  • tiOPF - TechInsite Object Persistent Framework (Ver. 2)
  • TParadoxDataSet - An TDataSet implementation that can read Paradox files up to Version 7 (and up ??)
  • ZeosDBO - Component for connecting to multiple database (Firebird, PostgreSQL, MySQL, Oracle)
시스템
  • EpikTimer - Precision timer component written specifically for Lazarus.
  • TrayIcon - A multiplatform System Tray component
  • TPopupNotifier - How to use TPopupNotifier to show "balloon help".
  • MultiDoc - A component to write pseudo-MDI application with Lazarus.
  • MDButtonsBar - ButtonsBar to MultiDoc Component.
  • MPICH - Bindings for the MPI - Message Passing Interface. Distributed computing.
비주얼 컴포넌트
  • VirtualTreeview - A port of the fast virtual treeview from SoftGems
  • Turbopower Visual PlanIt - A port of the Planner Components
  • RingChart and AnalogWatch - Another Elliptical Chart and an Analogic Watch for Lazarus and FPC
  • ColorBox - Color picker with preview
  • Spook's Panel Components - A collection of panel components
  • HistoryFiles - A component for store the recent files list into an .ini file and show the result into a menu.
  • ColorPalette - A color palette grid with ability to use custom palette.
  • OrphPort - Subset of TurboPower's Orpheus controls.
  • TSubForm - A Data-Aware SubForm that replicates controls based on records in a dataset.
  • Lui Controls - A set of visual controls (TToggleLabel, TMenuButton)
  • JvXPBar - A port of JVCL's TJvXPBar control that can display an icon, a header and zero or more clickable items in its client area.
  • CmdLine - A Prompt as VCL Control.
  • Wile64 - Components for Lazarus (TGifAnim, TColorProgress, TLabelCut...)
  • TGradButton - A new good looking Button Component
  • TMyRollOut and ExpandPanel - A collapsable panel with a button (like TJvRollOut); these panels can be arranged with "Expandpanel"
그 외 FPC/Lazarus 용 패키지들 (외부 링크)
  • 2007, Brain Patchwork DX, LLC. has ported their TCP/UDP Client and Server Components to Lazarus 0.9.22/FPC 2.0.4 - visual and non-visual implementation are supported (www.bpdx.com)
  • Starting with version 32, Lucas Gebauer's outstanding Synapse TCP/IP library is now compatible with Free Pascal and Lazarus. Lucas has also just released version 12 of his Synaser serial port communications suite that also runs under Free Pascal.
  • Indy
  • Castle Game Engine, a 3D game engine especially focused on VRML/X3D formats.
  • CUPS for Lazarus project Common UNIX Printing System for FPC/Lazarus.
  • FIBL FreeIBComponents package porting for Lazarus.
  • RackCtls a collection of components with an "Hi-fi system" appearance.
예제 프로그램
기타등등
Projects using Lazarus
Original contributors and changes
This page has been imported from the epikwiki version.
http://wiki.freepascal.org/Components_and_Code_examples/ko
조회수 1,852
C언어HOME > C언어 > 전체 목록
