BASIC4MCU | C언어 | 델파이 | freepascal - TARGET Embedded
작성자 master 작성일2018-09-29 13:33 조회1,294회 댓글0건본문
TARGET Embedded
Embedded port
Status
- best support is available in svn trunk version
- compilers are working, register definitions are available, but libs for peripheral's access are rare to non-existing. Hardware can be accessed via hardware registers.
- Not all controllers of each family are supported. If you're interested in support for further controllers, please subscribe to the fpc-devel mailing list and write a mail so adding the support can be discussed
ARM Embedded
Build
Get latest FPC from svn:
svn co http://svn.freepascal.org/svn/fpc/trunk fpcGet arm-embedded binutils.
For windows, they are available at http://svn.freepascal.org/svn/fpcbuild/binaries/i386-win32. You can either checkout the whole directory with or download only arm-embedded-ar.exe, arm-embedded-as.exe, arm-embedded-ld.exe, arm-embedded-strip.exe, arm-embedded-objdump.exe and arm-embedded-objcopy.exe manually. Put these utils in a directory included in your path.
To build binutils from sources http://wiki.lazarus.freepascal.org/Binutils has instructions, for example, ./configure --target=arm-linux --prefix=/opt/embarm/ --program-prefix=arm-embedded- --disable-werror, has been known to work on binutils 2.21.1 to build the binaries in the form that the fpc target embedded build desires.
Build FPC for arm-embedded (OABI):
cd fpc make clean buildbase installbase CROSSINSTALL=1 OS_TARGET=embedded CPU_TARGET=arm SUBARCH=armv4This builds only the compiler and the RTL instead of the whole FPC. Because of the limited capabilities of the embedded systems supposed to be used, building all packages is not useful. However, one must be careful to avoid overwriting an existing arm compiler on the system. If this is the case, INSTALL_PREFIX should be used to install into a different directory and switch between those.
SUBARCH is required and should match your target processor, e.g.:
- for the LPC 21xx parts which are ARM7TDMI (not to be confused with armv7!) based use SUBARCH=armv4
- for cortex-m3 parts (stellaris, stm32, etc) use SUBARCH=armv7m
- for cortex-m devices that support DSP extensions use SUBARCH=armv7em. The compiler does not yet support the cortex-m* FPU
- for cortex-m0 devices use -Cparmv6m
Testing
Below you find a simple example program for the LPC2124 microcontroller, save it as tled1.pp to follow the description. The program is made for development boards like the LPC-WEB from OLIMEX (http://www.olimex.com/dev/lpc-e2124.html). When you press button 1, led 1 lights for a certain time, same for button 2 and led 2.
procedure Wait(d : dword); begin while d<>0 do dec(d); end; begin { initialize PLL } InitPLL(2,1); { initialize LEDs } { port 0.8: output } TBitvector32(GPIO0_IODIR)[8]:=1; { port 0.10: output } TBitvector32(GPIO0_IODIR)[10]:=1; { turn off both LEDs } TBitvector32(GPIO0_IOSET)[8]:=1; TBitvector32(GPIO0_IOSET)[10]:=1; { initialize button inputs } { port 0.9: input } TBitvector32(GPIO0_IODIR)[9]:=0; { port 0.15: input } TBitvector32(GPIO0_IODIR)[15]:=0; { endless loop} while true do begin { button 1 pressed } if TBitvector32(GPIO0_IOPIN)[15]=0 then begin { turn on LED, inverse logic } TBitvector32(GPIO0_IOCLR)[8]:=1; { wait } Wait(500000); { turn off LED, inverse logic } TBitvector32(GPIO0_IOSET)[8]:=1; end; { button 2 pressed } if TBitvector32(GPIO0_IOPIN)[9]=0 then begin { turn on LED, inverse logic } TBitvector32(GPIO0_IOCLR)[10]:=1; { wait } Wait(500000); { turn off LED, inverse logic } TBitvector32(GPIO0_IOSET)[10]:=1; end; end; end.If FPC for arm-embedded is installed as described above, the program can be compiled by
fpc -Parm -Tembedded -Wplpc2124 tled1.pp-Parm
tells the compiler to compile for arm.
-Tembedded
tells the compiler to compile for the embedded target.
-Wplpc2124
tells the compiler to compile for the NXP LPC 2124. This has two effects: first, a unit (lpc21x4 in this case) containing the startup code and the port etc. definitions for this controller is loaded. Further, the compiler uses a linker script which fits the needs of this controller.
The result of the compiler is a .hex file which can be programmed by the NXP flash programming utility.
When using a board like the mbed (http://mbed.org) which is cortex-m3 based. Another ARM core but uses only thumb/thumb2 instructions not ARM/thumb instructions. A few subtle differences, first building fpc
make clean buildbase installbase CROSSINSTALL=1 OS_TARGET=embedded CPU_TARGET=arm SUBARCH=armv7mSecond when compiling your program
fpc -Parm -Tembedded -Wplpc1768 -Cparmv7m myprogram.ppThe -Cparmv7m option causes thumb2 code to be generated instead of the default (ARM based), probably not a bad idea to use the -Cp for processors using ARM instructions as well. -Wp as with the example above specifies the specific target, in this case microcontroller, to build for.
Adding new controllers
Adding a new controller type requires basically three steps: first, extend the compiler so it knows about the name of the controller then add a linker script and finally create an RTL unit with the register definitions and the startup code.
Add the controller type to the compiler
This is done in the file compiler/arm/cpuinfo.pas Here you need to add an identifier for the controller in the tcontrollertype enum At the same time you must update the embedded_controllers array. The array holds information about the amount of flash and sram in the controller, and what rtl unit should be included by default when compiling for that controller.
Note: Make sure the string of the two arrays are long enough to contain the strings you write
Add the linker script to the compiler
Adding a linker script consists of adding the controllertype enum identifier to the case statement in compiler/systems/t_embed.pas If this is not done the compiler will generate an internalerror
Create an RTL unit with startup code and register definitions
Creating an RTL unit means creating a unit that'll automatically be used in a project compiled for the given controller type. This unit should supply an entry point and basic initialization code. Enough to get the controller running
This unit, which must be named the same as the string written in the controllerunitstr field in the embedded_controllers array, goes into the directory rtl/embedded/arm/ where there are some examples already
After that the rtl/embedded Makefile.fpc should be modified, and rebuilt so it also builds the newly added rtl unit
AVR
See wiki page AVR.
Mipsel
See wiki page TARGET Embedded Mipsel.
Useful links
- http://de.wikipedia.org/wiki/Intel_HEX
- http://www.nxp.com/products/microcontrollers/support/software_download/lpc2000/
- http://www.nxp.com/acrobat_download/usermanuals/UM10114_3.pdf
- Jim Lynch: Using Open Source Tools for AT91SAM7 Cross Development - Revision B http://www.atmel.com/dyn/resources/prod_documents/atmel_tutorial_source.zip
See Also
- Small Virtual Machines#WinXp_virtual_machine as have simple example for Teensy. Files released here: [[1]]
http://wiki.freepascal.org/TARGET_Embedded
조회수 1,294등록된 댓글이 없습니다.
