BASIC4MCU | C언어 | C언어 | TrueType™ Reference Manual - apple
작성자 키트 작성일2017-09-12 14:01 조회1,765회 댓글0건본문
- Digitizing Letterforms
- The Font Engine
- Instructing Fonts
- The Graphics State
- The Instruction Set
- Font Tables
- The
'acnt'
(accent attachment) table- The
'ankr'
(anchor point) table- The
'avar'
(axis variation) table- The
'bdat'
(bitmap data) table- The
'bhed'
(bitmap font header) table- The
'bloc'
(bitmap location) table- The
'bsln'
(baseline) table- The
'cmap'
(character code mapping) table- The
'cvar'
(CVT variation) table- The
'cvt '
(control value) table- The
'EBSC'
(embedded bitmap scaling control) table- The
'fdsc'
(font descriptor) table- The
'feat'
(layout feature) table- The
'fmtx'
(font metrics) table- The
'fond'
(font family compatibility) table- The
'fpgm'
(font program) table- The
'fvar'
(font variation) table- The
'gasp'
(grid-fitting and scan-conversion procedure) table- The
'glyf'
(glyph outline) table- The
'gvar'
(glyph variation) table- The
'hdmx'
(horizontal device metrics) table- The
'head'
(font header) table- The
'hhea'
(horizontal header) table- The
'hmtx'
(horizontal metrics) table- The
'just'
(justification) table- The
'kern'
(kerning) table- The
'kerx'
(extended kerning) table- The
'lcar'
(ligature caret) table- The
'loca'
(glyph location) table- The
'ltag'
(language tag) table- The
'maxp'
(maximum profile) table- The
'meta'
(metadata) table- The
'mort'
(metamorphosis) table (deprecated)- The
'morx'
(extended metamorphosis) table- The
'name'
(name) table- The
'opbd'
(optical bounds) table- The
'OS/2'
(compatibility) table- The
'post'
(glyph name and PostScript compatibility) table- The
'prep'
(control value program) table- The
'prop'
(properties) table- The
'sbix'
(extended bitmaps) table- The
'trak'
(tracking) table- The
'vhea'
(vertical header) table- The
'vmtx'
(vertical metrics) table- The
'xref'
(cross-reference) table- The
'Zapf'
(glyph reference) table- Instruction Set Summary
- Glyph Mappings
- Converting Outlines
- Font Feature Registry
Copyright © 1991-2014 by Apple Inc. All rights reserved. No licenses, express or implied, are granted with respect to any of the technology described in this document. Apple retains all intellectual property rights associated with the technology described in this document.
- Apple Inc.
- 1 Infinite Loop
- Cupertino, CA 95014
APDA, Apple, the Apple Logo, LaserWriter and Macintosh are registered trademarks and TrueType is a trademark of Apple Inc., registered in the United States and other countries.
ITC Zapf Dingbats is a registered trademark of International Typeface Corporation.
Times, Palatino and Helvetica are registered trademarks of Linotype-Hell AG and/or its subsidiaries.
PostScript is a registered trademark of Adobe Systems Incorporated.
All other company and product names are trademarks or registered trademarks of the company or manufacturer respectively.
Even though Apple has reviewed this document, APPLE MAKES NO WARRANTY OR REPRESENTATION, EITHER EXPRESS OR IMPLIED, WITH RESPECT TO THIS DOCUMENT, ITS QUALITY, ACCURACY, MERCHANTABILITY, OR FITNESS FOR A PARTICULAR PURPOSE. AS A RESULT, THIS DOCUMENT IS PROVIDED "AS IS", AND YOU ARE ASSUMING THE ENTIRE RISK AS TO ITS QUALITY AND ACCURACY.
IN NO EVENT WILL APPLE BE LIABLE FOR DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES RESULTING FROM ANY DEFECT OR INACCURACY IN THIS DOCUMENT, even if advised of the possibility of such damages.
THE WARRANTY AND REMEDIES SET FORTH ABOVE ARE EXCLUSIVE AND IN LIEU OF ALL OTHERS, ORAL OR WRITTEN, EXPRESS OR IMPLIED. No Apple dealer, agent, or employee is authorized to make any modification, extension, or addition to this warranty.
Some states do not allow the exclusion or limitation of implied warranties or liability for incidental or consequential damages, so the above limitation or exclusion may not apply to you. This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
조회수 1,765등록된 댓글이 없습니다.
