BASIC4MCU | 구글검색 | 신기술 | Electronic Design News
작성자 키트 작성일2017-08-24 14:30 조회1,720회 댓글0건본문
Send News Tip
30 kHz to 50 GHz Traveling Wave Amplifier
Posted May 21st 2015
The MMA-005022-R4 is a traveling wave amplifier featuring output power and high gain over full 30 kHz to 50 GHz frequency range. The broadband GaAs MMIC traveling wave amplifier (TWA) is optimally designed for broadband applications that requires flat gain and group delay, with excellent input and output matches over the given frequency range. *Features* * Frequency Range: 30 kHz – 40 GHz * P1dB: +22 dBm * Vout: 7 Vp-p at 50 Ω * Gain: 13.5 dB * Vdd = 7 V * Ids = 200 mA * Input and Output...State-of-the-Art Fourth Generation IGBT
Posted May 19th 2015
Fairchild's 4th generation 650 V and 1200 V IGBT devices now offer lower switching loss by 30% for designing highly efficient and reliable industrial and automotive systems. Engineered by various process technologies, Fairchild can deliver state-of-the-art power performance without sacrificing ruggedness and reliability. Test results of several applications using the contemporary approach will be presented by Fairchild at the PCIM Europe 2015. “Manufacturers are extremely interested in more...4-Channel Video Decoder and Encoder
The TW9984, a video encoder and decoder for automotive applications by Intersil, includes four high quality NTSC/PAL/SECAM video decoders that convert analog composite video signal to digital component YCbCr data. Each channel of the device is designed to contain a 10-bit ADC with application selectable differential or single-ended analog video input options, proprietary clamp and gain controllers and utilizes 4H comb filter for separating luminance and chrominance to reduce cross noise...0.7 µA Rail-to-Rail CMOS Comparator
Onlinecomponents.com, an authorized distributor of Seiko Instruments Inc., features the S-89530A/89531A Series. The series are 0.7 µA rail-to-rail CMOS comparators that can be driven at a lower voltage and lower current consumption than existing comparators. With these features, the devices are suitable for use in battery-powered compact portable devices. *Features* * Can be driven lower voltage than existing - general-purpose comparators: VDD = 0.9 V to 5.5 V * Low current consumption: IDD...Video Filter Amplifier with SmartSleep
Posted May 18th 2015
The MAX9508 video filter amplifier provides intelligent power management using Maxim's SmartSleep technology by selectively disabling the filters and output amplifiers based on the presence of video signals or loads attached to the outputs. The MAX9508 filter passband is 6.75 MHz, which makes the device suitable for the higher bandwidth video signals from a DVD chip. The video output amplifiers can both source and sink load current, allowing output loads to be DC- or AC coupled. The MAX9508...High Speed Buffer Amplifier
The MSK 0002 is a high speed buffer amplifier that replaces the LH0002. This device is intended for use with an operational amplifier in a closed loop configuration to increase current output. It is designed with a symmetrical output stage that provides low output impedances to both the positive and negative portions of output pulses. The MSK 0002 is packaged in a hermetic 8 lead low profile T0-5 header and is specified over the full military temperature range. *Features* * Industry Wide...4 GHz FET-Input Amplifiers
Posted May 16th 2015
Linear Technology rolled out the LTC6268-10 single and dual LTC6269-10 4GHz FET-input op amps for high dynamic range and high speed transimpedance amplifier (TIA) applications. These new decompensated amplifiers extend the speed and dynamic range capabilities of this ultralow bias current op amp family for applications with a gain of 10 or higher. Input bias current is 0.9pA max over the -40°C to 85°C temperature range and just 4pA max over the entire -40°C to 125°C temperature range....High Speed Pipelined A/D Converters
Posted May 14th 2015
Microchip Technology rolled out its two new families of high-speed A/D converters, the MCP37DX0-200 and MCP372X0-200 families. These families feature 12- and 14- bit pipelined A/D converters with a maximum sampling rate of 200 Mega samples per second (Msps). The 12- and 14-bit devices feature high performance of over 67 dB Signal-to-Noise Ratio (SNR) and over 96 dB Spurious Free Dynamic Range (SFDR). This enables high-precision measurements of fast input signals. These families operate at...
조회수 1,720등록된 댓글이 없습니다.
