◎초보자가이드 > 30 LED Projects
TODAY756 TOTAL2,230,438
BASIC4MCU | ◎초보자가이드 | LED DIY | 30 LED Projects
작성자 키트 작성일2017-09-12 11:36 조회3,272회 댓글0건
Save 30 LED Projects  as.doc (957KB) or .pdf (770KB)  (21-5-2011)
For our other free eBooks,
 50 - 555 Circuits
 1 - 100 Transistor Circuits  and:  101 - 200 Transistor Circuits
 100 IC Circuits
For a list of every electronic symbol, see: Circuit Symbols.
For more articles and projects for the hobbyist: see TALKING ELECTRONICS WEBSITE
                                           email Colin Mitchell:   talking@tpg.com.au
3660040653_eD1vfsb6_300x15blank.gif                                         to Index
INTRODUCTION
This e-book covers the Light Emitting Diode.
The LED (Light Emitting Diode) is the modern-day equivalent to the light-globe.
It has changed from a dimly-glowing indicator to one that is too-bright to look at.
However it is entirely different to a "globe."
A globe is an electrical device consisting of a glowing wire while a LED is an electronic device.
A LED is more efficient, produces less heat and must be "driven" correctly to prevent it being damaged.
This eBook shows you how to connect a LED to a circuit plus a number of projects using LEDs.
It's simple to use a LED - once you know how.
CONNECTING A LED
A LED must be connected around the correct way in a circuit and it must have a resistor to limit the current.
The LED in the first diagram does not illuminate because a red LED requires 1.7v and the cell only supplies 1.5v. The LED in the second diagram is damaged because it requires 1.7v and the two cells supply 3v. A resistor is needed to limit the current to about 25mA and also the voltage to 1.7v, as shown in the third diagram.  The fourth diagram is the circuit for layout #3 showing the symbol for the LED, resistor and battery and how the three are connected. The LED in the fifth diagram does not work because it is around the wrong way.
CHARACTERISTIC VOLTAGE DROP
When a LED is connected around the correct way in a circuit it develops a voltage across it called the CHARACTERISTIC VOLTAGE DROP.
A LED must be supplied with a voltage that is higher than its "CHARACTERISTIC VOLTAGE" via a resistor - called a VOLTAGE DROPPING RESISTOR  or CURRENT LIMITING RESISTOR - so the LED will operate correctly and provide at least 10,000 to 50,000 hours of illumination.
A LED works like this:  A LED and resistor are placed in series and connected to a voltage.
As the voltage rises from 0v, nothing happens until the voltage reaches about 1.7v. At this voltage a red LED just starts to glow. As the voltage increases, the voltage across the LED remains at 1.7v but the current through the LED increases and it gets brighter.
We now turn our attention to the current though the LED.  As the current increases to 5mA, 10mA, 15mA, 20mA the brightness will increase and at 25mA, it will be a maximum. Increasing the supply voltage will simply change the colour of the LED slightly but the crystal inside the LED will start to overheat and this will reduce the life considerably.
This is just a simple example as each LED has a different CHARACTERISTIC VOLTAGE DROP and a different maximum current.
In the diagram below we see a LED on a 3v supply, 9v supply and 12v supply. The current-limiting resistors are different and the first circuit takes 6mA, the second takes 15mA and the third takes 31mA. But the voltage across the red LED is the same in all cases. This is because the LED creates the
CHARACTERISTIC VOLTAGE DROP and this does not change. 3660040653_y8T5MePo_LEDvoltageDrop.gif
It does not matter if the resistor is connected above or below the LED. The circuits are the SAME in operation:
HEAD VOLTAGE
Now we turn our attention to the resistor.
As the supply-voltage increases, the voltage across the LED will be constant at 1.7v (for a red LED) and the excess voltage will be dropped across the resistor. The supply can be any voltage from 2v to 12v or more.
In this case, the resistor will drop 0.3v to 10.3v.
This is called HEAD VOLTAGE - or HEAD-ROOM or OVERHEAD-VOLTAGE. And the resistor is called the CURRENT-LIMIT resistor.
The following diagram shows HEAD VOLTAGE:
The voltage dropped across this resistor, combined with the current, constitutes wasted energy and should be kept to a minimum, but a small HEAD VOLTAGE is not advisable (such as 0.5v). The head voltage should be a minimum of 1.5v - and this only applies if the supply is fixed.
The head voltage depends on the supply voltage. If the supply is fixed and guaranteed not to increase or fall, the head voltage can be small (1.5v minimum).
But most supplies are derived from batteries and the voltage will drop as the cells are used.
Here is an example of a problem:
Supply voltage:  12v
7  red LEDs in series = 11.9v
Dropper resistor = 0.1v
As soon as the supply drops to 11.8v, no LEDs will be illuminated.
Example 2:
Supply voltage 12v
5 green LEDs in series @ 2.1v = 10.5v
Dropper resistor = 1.5v
The battery voltage can drop to 10.5v
But let's look at the situation more closely.
Suppose the current @ 12v = 25mA.
As the voltage drops, the current will drop.
At 11.5v, the current will be 17mA
At 11v, the current will be 9mA
At 10.5v, the current will be zero
You can see the workable supply drop is only about 1v.
Many batteries drop 1v and still have over 80% of their energy remaining. That's why you need to design your circuit to have a large
HEAD VOLTAGE.
A large Head Voltage is also needed when a plug-pack (wall wart) is used. These devices consist of a transformer, set of diodes and an electrolytic. The voltage marked on the unit is the voltage it will deliver when fully loaded. It may be 200mA, 300mA or 500mA. When this current is delivered, the voltage will be 9v or 12v. But if the current is less than the rated current, the output voltage will be higher. It may be 1v, 2v or even 5v higher.
This is one of the characteristics of a cheap transformer. A cheap transformer has very poor regulation, so to deliver 12v @ 500mA, the transformer produces a higher voltage on no-load and the voltage drops as the current increases.
You need to allow for this extra voltage when using a plug-pack so the LEDs do not take more than 20mA to 25mA.
TESTING A LED
If the cathode lead of a LED cannot be identified, place 3 cells in series with a 220R resistor and illuminate the LED.  4.5v allows all types of LEDs to be tested as white LEDs require up to 3.6v.  Do not use a multimeter as some only have one or two cells and this will not illuminate all types of LEDs. In addition, the negative lead of a multimeter is connected to the positive of the cells (inside the meter) for resistance measurements - so you will get an incorrect determination of the cathode lead.
CIRCUIT TO TEST ALL TYPES OF LEDs
IDENTIFYING A LED
 A LED does not have a "Positive" or "Negative" lead. It has a lead identified as the "Cathode" or Kathode" or "k". This is identified by a flat on the side of the LED and/or by the shortest lead.
This lead goes to the 0v rail of the circuit or near the 0v rail (if the LED is connected to other components).
Many LEDs have a "flat" on one side and this identifies the cathode. Some surface-mount LEDs have a dot or shape to identify the cathode lead and some have a cut-out on one end.
Here are some of the identification marks: 3660040653_sIRNarYw_LED-Outlines.jpg
LEDs ARE CURRENT DRIVEN DEVICES
A LED is described as a CURRENT DRIVEN DEVICE.  This means the illumination is determined by the amount of current flowing through it.
This is the way to see what we mean: Place a LED and 100R resistor in series and connect it to a variable power supply.
As the voltage is increased from 0v, to 1v, the LED will not produce any illumination, As the voltage from the power-supply increases past 1v, the LED will start to produce illumination at about 1.6v to 1.7v (for a red LED). As the voltage is increased further, the illumination increases but the voltage across the LED does not increase. (It may increase 0.1v) but the brightness will increase enormously. That's why we say the LED is a CURRENT DRIVEN DEVICE.
The brightness of a LED can be altered by increasing or decreasing the current. The effect will not be linear and it is best to experiment to determine the best current-flow for the amount of illumination you want. High-bright LEDs and super-bright LEDs will illuminate at 1mA or less, so the quality of a LED has a lot to do with the brightness. The life of many LEDs is determined at 17mA. This seems to be the best value for many types of LEDs.
1mA to 5mA LEDs
Some LEDs will produce illumination at 1mA. These are "high Quality" or "High Brightness" LEDs and the only way to check this feature is to test them @1mA as shown below.
THE 5v LED
Some suppliers and some websites talk about a 5v white or blue LED. Some LEDs have a small internal resistor and can be placed on a 5v supply. This is very rare.
Some websites suggest placing a white LED on a 5v supply. These LEDs have a characteristic voltage-drop of 3.6v and should not be placed directly on a voltage above 3.6v. If placed on a voltage below 3.6v, the LED will not glow very brightly. If you have a voltage EXACTLY 3.6v, you can connect the LED, but most voltages are higher than 3.6v and thus you need a resistor.
The only LED with an internal resistor is a FLASHING LED. These LEDs can be placed on a supply from 3.5v to 12v and flash at approx 2Hz. The LED is very weak on 3.5v but it flashing can be used to drive a powerful LED (see circuits section). It can also be used to produce a beep for a beeper FM transmitter.
NEVER assume a LED has an internal resistor. Always add a series resistor. Some high intensity LEDs are designed for 12v operation. These LEDs have a complete internal circuit to deliver the correct current to the LED. This type of device and circuitry is not covered in this eBook.
LEDs IN SERIES
LEDs can be placed in series providing some features are taken into account. The main item to include is a current-limiting resistor.
A LED and resistor is called a string. A string can have 1, 2, 3 or more LEDs.
Three things must be observed:
1. MAXIMUM CURRENT through each string = 25mA.
2. The CHARACTERISTIC VOLTAGE-DROP must be known so the correct number of LEDs are used in any string.
3. A DROPPER RESISTOR must be included for each string.
The following diagrams show examples of 1-string, 2-strings and 3-strings:
LEDs IN PARALLEL
LEDs CANNOT be placed in parallel - until you read this:
LEDs "generate" or "possess" or "create" a voltage across them called the
CHARACTERISTIC VOLTAGE-DROP  (when they are correctly placed in a circuit).
This voltage is generated by the type of crystal and is different for each colour as well as the "quality" of the LED (such as high-bright, ultra high-bright etc). This characteristic cannot be altered BUT it does change a very small amount from one LED to another in the same batch. And it does increase slightly as the current increases.
For instance, it will be different by as much as 0.2v for red LEDs and 0.4v for white LEDs from the same batch and will increase by as much as 0.5v when the current is increased from a minimum to maximum.
You can test 100 white LEDs @15mA and measure the CHARACTERISTIC VOLTAGE-DROP to see this range.
If you get 2 LEDs with identical
CHARACTERISTIC VOLTAGE-DROP, and place them in parallel, they will each take the same current. This means 30mA through the current-limiting resistor will be divided into 15mA for each LED.
However if one LED has a higher
CHARACTERISTIC VOLTAGE-DROP, it will take less current and the other LED will take considerably more. Thus you have no way to determine the "current-sharing"  in a string of parallel LEDs.  If you put 3 or more LEDs in parallel, one LED will start to take more current and will over-heat and you will get very-rapid LED failure.  As one LED fails, the others will take more current and the rest of the LEDs will start to self-destruct. The reason why they take more current is this: the current-limit resistor will have been designed so that say 60mA will flow when 3 LEDs are in parallel. When one LED fails, the remaining LEDs will take 30mA each.
Thus LEDs in PARALLEL should be avoided.
Diagram A below shows two green LEDs in parallel. This will work provided the Characteristic Voltage Drop across each LED is the same.
In diagram B the Characteristic Voltage Drop is slightly different for the second LED and the first green LED will glow brighter.
In diagram C the three LEDs have different Characteristic Voltage Drops and the red LED will glow very bright while the other two LEDs will not illuminate. All the current will pass through the red LED and it will be damaged.
The reason why the red LED will glow very bright is this: It has the lowest Characteristic Voltage Drop and it will create a 1.7v for the three LEDs. The green and orange LEDs will not illuminate at this voltage and thus all the current
from the dropper resistor will flow in the red LED and it will be destroyed.
THE RESISTOR
The value of the current limiting resistor can be worked out by Ohms Law.
Here are the 3 steps:
1. Add up the voltages of all the LEDs in a string.   e.g:  2.1v + 2.3v + 2.3v + 1.7v = 8.4v
2. Subtract the LED voltages from the supply voltage.  e.g:  12v - 8.4v = 3.6v
3. Divide the 3.6v (or your voltage) by the current through the string.
for 25mA:   3.6/.025 =144 ohms
for 20mA:   3.6/.02  = 180 ohms
for 15mA:   3.6/.015 = 250 ohms
for 10mA:   3.6/.01   = 360 ohms
This is the value of the current-limiting resistor.
Here is a set of strings for a supply voltage of 3v to 12v and a single LED:
Here is a set of strings for a supply voltage of 5v to 12v and a white LED: 3660040653_L1PuJRac_Strings-WhiteLED.gif
Here is a set of strings for a supply voltage of 5v to 12v and two LEDs:
LED series/parallel array wizard
The LED series/parallel array wizard below, is a calculator that will help you design large arrays of single-colour LEDs.
This calculator has been designed by Rob Arnold and you will be taken to his site:
 http://led.linear1.org/led.wiz when you click: Design my array
The wizard determines the current limiting resistor value for each string of the array and the power consumed. All you need to know are the specs of your LED and how many you'd like to use. The calculator only allows one LED colour to be used. For mixed colours, you will have to use the 3 steps explained above. The result is not always correct. Read the discussion below: "THE DANGERS OF USING A "LED WIZARD" to understand the word "HEAD VOLTAGE."  The HEAD VOLTAGE should be as high as possible to allow for the differences in Characteristic Voltage and the variations in power supply voltage.
http://led.linear1.org/led.wiz" method="post"> Source voltage Help src
diode forward voltage Help src
diode forward current (mA) Help src
number of LEDs in your array
View output as: ASCII schematic wiring diagram Help src
help with resistor colour codes
Resistor Calculator
Use this JavaScript resistor calculator to work out the value of the current-limiting resistor:
Source voltage=
LED forward voltage drop=
LED current in milliamps=
Current-limiting resistance in Ohms=
Closest 5% Resistor=
Resistor wattage=
Actual current=
Power dissipated by LED      (watts)=
Power dissipated by resistor (watts)=
LED VOLTAGE AND CURRENT
LED characteristics are very broad and you have absolutely no idea of any value until you test the LED.
However here are some of the generally accepted characteristics:
You can find a LED WIZARD on the web that gives you a circuit to combine LEDs in series and/or parallel for all types of arrays.
Here is an example, provided by a reader. Can you see the major fault?
The characteristic voltage (the colour of the LED) is not important in this discussion. Obviously white LEDs will not work as they require 3.4v to 3.6v to operate.
The main fault is the dropper resistor.
Read our article on LEDs.
The most important component is the DROPPER RESISTOR.
It must allow for the difference between the maximum and minimum supply voltage and ALSO the maximum and minimum CHARACTERISTIC VOLTAGE of the string of LEDs.
When we say a red LED has a CHARACTERISTIC VOLTAGE of 1.7v, we need to measure the exact maximum and minimum value for the LEDs we are installing.
Some high-bright and super-high-bright LEDs have a Characteristic Voltage of 1.6v to 1.8v and this will make a big difference when you have 8 LEDs in series.
Secondly, the 12v supply may rise to 13.6v when the battery is being charged and fall to 10.8v at the end of its life.
Thirdly, you need to know the current required by the LEDs.
The normal value is 17mA for long life.
This can rise to 20mA but must not go higher than 25mA
You should also look at the minimum current. Many high-bright LEDs will perform perfectly on 5-10mA and become TOO BRIGHT on 20mA.
As you can see, it is much more complex than a WIZARD can handle.
That's why it produced the absurd result above.
The maximum characteristic voltage for 8 red LEDs is 8x1.8v = 14.4v
This means you can only put 6 LEDs in series. = 10.8v
The LEDs will totally die when the battery reaches 10.8v
The value of the dropper resistor for 6 LEDs and a supply of 12v @20mA = 60 ohms. When the battery voltage rises to 13.6v during charging, the current will be: 46mA. This is too high.
The CURRENT LIMITING resistor is too low.
We need to have a higher-value CURRENT LIMITING resistor and fewer LEDs.
Use 5 LEDs:
The characteristic voltage for 5 LEDs will be:  5 x 1.7v = 8.5v
Allow a current of 20mA when the supply is 12.6v   Dropper resistor = 200 ohms.
Current at 10.8v will be 11mA. And current at 13.6v will be 25mA
Now you can see why the value of the CURRENT LIMITING RESISTOR has to be so high.
SOLDERING LEDs
LEDs are the most heat-sensitive device of all the components.
When soldering surface-mount LEDs, you should hold the LED with tweezers and "tack" one end. Then wait for the LED to cool down and solder the other end very quickly. Then wait a few seconds and completely solder the first end. Check the glow of each LED with 3 cells in series and a 220R resistor. If you have overheated the LED, its output will be dim, or a slightly different colour, or it may not work at all. They are extremely sensitive to heat - mainly because the crystal is so close to the soldering iron.
HIGH-BRIGHT LEDs
LEDs have become more efficient over the past 25 years.
Originally a red LED emitted 17mcd @20mA. These LEDs now emit 1,000mcd to 20,000mcd @20mA.
This means you can lower the current and still produce illumination. Some LEDs operate on a current as low as 1mA
LEDs as LIGHT DETECTORS
LEDs can also be used to detect light.
Green LEDs are the best, however all LEDs will detect light and produce a voltage equal to the CHARACTERISTIC VOLTAGE-DROP, providing they receive sufficient light. The current they produce is miniscule however high-bright and super-bright LEDs produce a higher output due to the fact that their crystal is more efficient at converting light into electricity.
The Solar Tracker project uses this characteristic to track the sun's movement across the sky.
BI-COLOUR, TRI-COLOUR, FLASHING LEDS and 7-colour LEDs
LEDs can also be obtained in a range of novelty effects as well as a red and green LED inside a clear or opaque lens. You can also get red, blue, white, green or any combination inside a LED with 2 leads.
Simply connect these LEDs to a 6v supply and 330R series dropper resistor to see the effects they produce.
Some LEDs have 3 leads and the third lead needs to be pulsed to change the pattern.
Some LEDs can be reversed to produce a different colour. These LEDs contain red and green and by reversing the voltage, one or the other colour will illuminate.
When the voltage is reversed rapidly, the LED produces orange.
Sometimes it is not convenient to reverse the voltage to produce orange.
In this case three leaded LEDs are available to produce red, green and orange.
FLASHING LEDs
Flashing LEDs contain a chip and inbuilt current-limiting resistor. They operate from 3.5v to 12v. The flash-rate will alter slightly on different supply voltage. You can get 3mm and 5mm versions as well as high-bright types and surface-mount.
NOVELTY LEDs
Novelty LEDs can have 2 or three leads. They
contain a microcontroller chip, inbuilt current-limiting resistor and two or three colours.
The two leaded LEDs cycle through a range of colours, including flashing and fading.
The three leaded LEDs have up to 16 different patterns and the control lead must be taken from 0v to rail volts to activate the next pattern.
LEDs LEDs LEDs
There are hundreds of circuits that use a LED or drive a LED or flash a LED and nearly all the circuits in this eBook are different.
Some flash a LED on a 1.5v supply, some use very little current, some flash the LED very brightly and others use a flashing LED to create the flash-rate.
You will learn something from every circuit. Some are interesting and some are amazing. Some consist of components called a "building Block" and they can be added to other circuits to create a larger, more complex, circuit.
This is what this eBook is all about.
It teaches you how to build and design circuits that are fun to see working, yet practical.
You will learn a lot  . . . . even from these simple circuits.
Colin Mitchell
TALKING ELECTRONICS.
talking@tpg.com.au
SI NOTATION
All the schematics in this eBook have components that are labelled using the System International (SI) notation system. The SI system is an easy way to show values without the need for a decimal point. Sometimes the decimal point is difficult to see and the SI system overcomes this problem and offers a clear advantage.
Resistor values are in ohms (R), and the multipliers are: k for kilo, M for Mega. Capacitance is measured in farads (F) and the sub-multiples are u for micro, n for nano, and p for pico.  Inductors are measured in Henrys (H) and the sub-multiples are mH for milliHenry and uH for microHenry.
A 10 ohm resistor would be written as 10R and a 0.001u capacitor as 1n.
Some countries use the letter "E" to represent Ohm, such as 100E = 100 ohms = 100R.
The markings on components are written slightly differently to the way they are shown on a circuit diagram (such as 100p on a circuit and 101 on the capacitor or 10 on a capacitor and 10p on a diagram) and you will have to look on the internet under Basic Electronics to learn about these differences.
We have not provided lengthy explanations of how any of the circuits work. This has already been covered in TALKING ELECTRONICS Basic Electronics Course, and can be obtained on a CD for $10.00 (posted to anywhere in the world)
For photos of nearly every electronic component, see this website: https://www.egr.msu.edu/eceshop/Parts_Inventory/totalinventory.php
How good is your power of observation?
Can you find the LED:
POWERING A PROJECT
The safest way to power a project is with a battery. Each circuit requires a voltage from 3v to 12v. This can be supplied from a set of AA cells in a holder or you can also use a 9v battery for some projects.
If you want to power a circuit for a long period of time, you will need a "power supply."
The safest power supply is a Plug Pack (wall-wort, wall wart,
wall cube, power brick, plug-in adapter, adapter block, domestic mains adapter, power adapter, or AC adapter). Some plug packs have a switchable output voltage: 3v, 6v, 7.5v, 9v, 12v) DC with a current rating of 500mA. The black lead is negative and the other lead with a white stripe (or a grey lead with a black stripe) is the positive lead.
This is the safest way to power a project as the insulation (isolation) from the mains is provided inside the adapter and there is no possibility of getting a shock.
The rating "500mA" is the maximum the Plug Pack will deliver and if your circuit takes just 50mA, this is the current that will be supplied. Some pluck packs are rated at 300mA or 1A and some have a fixed output voltage. All these plug packs will be suitable.
Some Plug Packs are marked "12vAC."  This type of plug pack is not suitable for these circuits as it does not have a set of diodes and electrolytic to convert the AC to DC. All the circuits in this eBook require DC.
PROJECTS
FLASHING A LED
These 7 circuits flash a LED using a supply from 1.5v to 12v.
They all have a different value of efficiency and current consumption. You will find at least one to suit your requirements.
The simplest way to flash a LED is to buy a FLASHING LED as shown in figure A. It will work on 3v to 9v but it is not very bright - mainly because the LED is not high-efficiency.
A Flashing LED can be used to flash a super-bright red LED, as shown in figure B.
Figure C shows a flashing LED driving a buffer transistor to flash a white LED. The circuit needs 4.5v - 6v.
Figure D produces a very bright flash for a very short period of time - for a red, green, orange or white LED.
Figure E uses 2 transistors to produce a brief flash - for a red, green, orange or white LED.
Figure F uses a single cell and a voltage multiplying arrangement to flash a red or green LED.
Figure G flashes a white LED on a 3v supply.
CONSTANT CURRENT
These four circuits delivers a constant 12mA to any number of LEDs connected in series (to the terminals shown) in the following arrangements.
The circuits can be connected to 6v, 9v or 12v and the brightness of the LEDs does not alter.
You can connect:
1 or 2 LEDs to 6v,
1, 2 or 3 LEDs to 9v or
1, 2, 3 or 4 LEDs to 12v.
The LEDs can be any colour.
The constant-current section can be considered as a MODULE and can be placed above or below the load:
WHITE LED on 1.5v SUPPLY
This circuit will illuminate a white LED using a single cell.
See LED Torch Circuits article for more details.
2 WHITE LEDs on 1.5v SUPPLY
This circuit will illuminate two white LEDs using a single cell.
WHITE LED FLASHER
This circuit will flash a white LEDs using a single cell.
10 LEDs on a 9v BATTERY
This circuit will illuminate 10 LEDs on a 9v battery.
It was designed in response to a readers request:
SHAKE TIC TAC LED TORCH
In the diagram, it looks like the coils sit on the “table” while the magnet has its edge on the table. This is just a diagram to show how the parts are connected. The coils actually sit flat against the slide (against the side of the magnet) as shown in the diagram:
3660040653_y1PegMm4_ShakeTicTacLEDtorch.gifThe output voltage depends on how quickly the magnet passes from one end of the slide to the other. That's why a rapid shaking produces a higher voltage. You must get the end of the magnet to fully pass though the coil so the voltage will be a maximum. That’s why the slide extends past the coils at the top and bottom of the diagram.
The circuit consists of two 600-turn coils in series, driving a voltage doubler. Each coil produces a positive and negative pulse, each time the magnet passes from one end of the slide to the other.
The positive pulse charges the top electrolytic via the top diode and the negative pulse charges the lower
electrolytic, via the lower diode.
The voltage across each electrolytic is combined to produce a voltage for the white LED. When the combined voltage is greater than 3.2v, the LED illuminates. The electrolytics help to keep the LED illuminated while the magnet starts to make another pass.
LED DETECTS LIGHT
The LED in this circuit will detect light to turn on the oscillator. Ordinary red LEDs do not work. But green LEDs, yellow LEDs and high-bright white LEDs and high-bright red LEDs work very well.
The output voltage of the LED is up to 600mV when detecting  very bright illumination.
When light is detected by the LED, its resistance decreases and a very small current flows into the base of the first transistor. The transistor amplifies this current about 200 times  and the resistance between collector and emitter decreases. The 330k resistor on the collector is a current limiting resistor as the middle transistor only needs a very small current for the circuit to oscillate. If the current is too high, the circuit will "freeze."
The piezo diaphragm does not contain any active components and relies on the circuit to drive it to produce the tone.
8 MILLION GAIN!
This circuit is so sensitive it will detect "mains hum."  Simply move it across any wall and it will detect where the mains cable is located. It has a gain of about 200 x 200 x 200 = 8,000,000 and will also detect static electricity and the presence of your hand without any direct contact. You will be amazed what it detects!  There is static electricity EVERYWHERE! The input of this circuit is classified as very high impedance.
Here is a photo of the circuit, produced by a constructor.
3660040653_eD1vfsb6_300x15blank.gifto Index
3660040653_wvDqzty1_LEDs2520on2520240v.gif LEDs on 240v
I do not like any circuit connected directly to 240v mains. However Christmas tress lights (globes) have been connected directly to the mains for 30 years without any major problems.
Insulation must be provided and the lights (LEDs) must be away from prying fingers.
You need at least 50 LEDs in each string
to prevent them being damaged via a surge through the 1k resistor - if the circuit is turned on at the peak of the waveform. As you add more LEDs to each string, the current will drop a very small amount until eventually, when you have 90 LEDs in each string, the current will be zero.
For 50 LEDs in each string, the total characteristic voltage will be 180v so that the peak voltage will be 330v - 180v = 150v. Each LED will see less than 7mA peak during the half-cycle they are illuminated (because the voltage across the 0.22u is 150v and this voltage determines the current-flow). The 1k resistor will drop 7v - since the RMS current is 7mA  (7mA x 1,000 ohms = 7v). No rectifier diodes are needed. The LEDs are the "rectifiers."  Very clever. You must have LEDs in both directions to charge and discharge the capacitor. The resistor is provided to take a heavy surge current through one of the strings of LEDs if the circuit is switched on when the mains is at a peak. This can be as high as 330mA if only 1 LED is used, so the value of this resistor must be adjusted if a small number of LEDs are used. The LEDs above detect peak current. The LEDs are turned on and off 50 times per second and this may create "flickering" or "strobing."  To prevent this flicker, see the DC circuit below:
A 100n cap will deliver 7mA RMS or 10mA peak in full wave or 3.5m
조회수 3,272
◎초보자가이드HOME > ◎초보자가이드 > 전체 목록
