◎ STM32F > port to MMC/SD
TODAY104 TOTAL2,271,571
BASIC4MCU | ◎ STM32F | STM32 | port to MMC/SD
작성자 키트 작성일2017-09-13 09:52 조회1,593회 댓글0건
port to MMC/SD
Unfortunately, I can't make the modules pC/FAT and pC/FFS freely accessible. However, I can give here a simplified version of the MMC/SD-Card Ports on the SPI-connection for miscellaneous controller.
By using this ports you can use another FileSystem on this interface and with it accessing the MMC- and SD-Cards. Or, like my tests, a MMC/SD-to-USB adapter can be realized in software. This works like an USB-Device as MassStorage (removable media) on the PC and you have access to the MMC- and SD-cards like an professional adapter in hardware (only slower, since SPI-mode and software realization).
Here a overview over the SD-Card versions:
SD card versions
Restrictions of the simplified MMC/SD-ports:
- no interrupt- or DMA-mode
- no detailed media infos
- no read / write in call-back mode
- no direct RTOS-support
pCFAT_Port_SPI
download simplified pC/FAT Ports to MMC/SD (as ZIP)
(with MMCplus/HD-MMC/M-Bridge/SDHC/SDXC support)
(with optional McEx/ASSD-support)
On a porting to further controllers, additional to the SPI-speed adaptation only some parameters of the hardware must be known and to setup. This are the used PIO-pins for WP (WriteProtect), CD (CardDetect) plus the correct settings for MOSI, MISO, SCLK and /SS. Additional the matching SPI-mode 3 must be enabled.
to used SPI-mode of the controller (master)
Following diagram shows the SPI-mode, that is required for the communication with MMC- and SD-cards in the SPI-mode:
SPI-master mode
To the topic "speed"
In the following table, all important parameters of here present MMC/MMCplus/M-Bridge/SD/SDHC-cards are listed as confrontation. This illustrates quite well that the performance statements of the manufacturers speed for MMC/SD-mode is only indirect/relative with the context in SPI-mode.
The paramters Nac and Nbs are from special interest.
- Nac = maximum cycles between Read_CMD and data
- Nbs = maximum cycles between Write_CMD+data and End-of-Busy
These parameters partly fluctuate very strongly between the different cards/manufacturers. They give an information about how fast read and write of the internal storage can be really. BUT! also these values represent the respective absolute maximum-worth. That is but also on the other hand, a card with high Nbs nevertheless can possibly be faster ready with a Write-CMD, as a card with lower Nbs. However yields these statements a tendency over the cycles at most possible/expected/permissible from the respective manufacturer.
pC_FAT MMC_SD_Port_1
Card
MMC
16MB
Infineon
MMC
32MB
Infineon
MMC
64MB
Transcend
MMC
128MB
SanDisk
MMC
1GB
Hama
MMCmicro
512MB
X4store
RS-MMC
32MB
SanDisk
MMCmobile
64MB
Transcend
MID-OID
01-0000
01-0000
06-0000
02-0000
48-FFFF
6F-0000
02-0000
2C-0000
maxclk
20MHz
20MHz
20MHz
20MHz
20MHz
20MHz
20MHz
20(26)MHz
usedclk*
8MHz
8MHz
8MHz
8MHz
8MHz
8MHz
8MHz
8MHz
Nac
10.012
10.012
10.012
10.012
800.000
50.000
100.000
50.000
Nbs
40.048
40.048
40.048
40.048
102.400.000
1.600.000
400.000
1.600.000
maxsectors
31.424
62.720
125.440
250.880
2.007.040
1.003.520
62720
125.440
sectorsize
512
512
512
512
512
512
512
512
pC_FAT MMC_SD_Port_2
Card
MMCmobile
512MB
Transcend
MMCmobile
1GB
extreme
MMCmobile
2GB
green
memory
MMCmobile
2GB
Kingston
MMCplus
512MB
Transcend
MMC
1GB
extreme
MMCplus
2GB
Transcend
MMCplus
4GB
Pretec
MID-OID
15-0000
00-0000
6F-0000
70-0000
1E-FFFF
4B-4342
1E-FFFF
19-5944
maxclk
20(26)MHz
20MHz
20(52)MHz
20(52)MHz
20(52)MHz
20(?)MHz
20(52)MHz
20(52)MHz
usedclk*
8MHz
8MHz
8MHz
8MHz
8MHz
8MHz
8MHz
8MHz
Nac
15.012
30.000
10.000
200.012
50.000
35.000
200.000
200.012
Nbs
1.921.536
480.000
1.280.000
25.601.536
1.600.000
1.120.000
6.400.000
25.601.536
maxsectors
1.003.520
1.935.360
1.945.600
1.983.488
990.208
2.022.912
1.981.952
1.988.096
sectorsize
512
512
1024
1024
512
512
1024
2048
조회수 1,593
◎ STM32FHOME > ◎ STM32F > 전체 목록
◎ STM32F 목록
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 11834
공지 사이트 이용 안내댓글[25] master 17-10-29 31142
82 STM32 Migration and compatibility guidelines for STM32 microcontro… 키트 17-09-14 2671
81 STM32 ST마이크로일렉트로닉스, 모든 STM32 MCU 디바이스에 로우 레이어 API 탑재 이미지 키트 17-09-14 2915
80 STM32 STM32 자료실 키트 17-09-14 3673
79 STM32 HAL vs LL 키트 17-09-14 3118
78 STM32 STM32F103 응용 - SignalTech 이미지 키트 17-09-14 3731
77 STM32 VGA Output from STM32F4 Discovery board 이미지 키트 17-09-13 2698
76 STM32 STM32-MP3NL/COD - Audio Engine MP3 Codec and Utilities 이미지 키트 17-09-13 4688
75 STM32 Arduino for STM32 키트 17-09-13 3004
74 STM32 ARDUINO and STM32 이미지 키트 17-09-13 2664
73 STM32 stm32circle.com 키트 17-09-13 2611
72 STM32 stm32f4-discovery.net 키트 17-09-13 2845
71 STM32 STM32 Nucleo community 키트 17-09-13 3047
70 STM32 stm32 | Projects & Libraries 이미지 키트 17-09-13 2747
