◎ STM32F > STM32-MP3NL/COD - Audio Engine MP3 Codec and Utilities
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > ◎ STM32F
STM32 | STM32-MP3NL/COD - Audio Engine MP3 Codec and Utilities
작성자 키트 작성일17-09-13 11:26 조회1,449회 댓글0건
STM32-MP3NL/COD
STMicroelectronics STM32 Audio Engine is a set of software libraries allowing customers to build audio applications with high-quality and professional results.
The popular MP3 format is part of the formats a professional application should support to ensure the best musical experience.
Therefore, the MP3 codec library is a must. It removes the need for an external MP3 codec component. Moreover, unlike many open-source solutions, it was written specifically for STM32, and is therefore highly optimized, leaving room for other application tasks to run concurrently with the audio encoding/decoding.
In addition, it comes with a set of impressive add-ons such as a channel mixer, a standalone 5-band parametric equalizer and loudness control to provide a complete plug-and-play solution for STM32 customers.
The MP3 codec library is not available for all STM32 family members.
Key Features
  • MPEG-1, 2 or 2.5 formats
  • Layers 1, 2 and 3
  • Constant bit rate and variable bit rate
  • Mono or stereo input streams
  • PCM (Pulse Code Modulation) output
  • Solution optimized for STM32
  • MP3 decoder with built-in equalizer
  • MP3 encoder
  • Audio utilities:
    • Channel mixer utility (for volume and mute control)
    • Standalone 5-band parametric equalizer utility
  • Loudness control utility
  • Object codes, accessed by the user application through an extensive API in C
  • Full documentation included, demo software available
  • Demo project available for IAR EWARM, Keil MDK-ARM and Raisonance RIDE
DESIGN
Technical Documentation
Product Specifications
DescriptionVersionSize
DB1245DB1245: STM32 audio engine – MP3 codec library2.173 KB
3660040649_acYFNr32_25EC25A0259C25EB25AA25A9_25EC2597258625EC259D258C.png3Ftype3Dw740
STM32F4-Discovery as MP3 player - GitHub
2014. 9. 28. - STM32F4-Discovery as MP3 player. ... Just raw copy and edit from BenjaminProject(http://vedder.se/2012/12/stm32f4-discovery-usb-host-and ... This code implement MP3 playervia USB HOST using STM32-Discovery Board.
STM32F4 Discovery USB host and MP3 player | Benjamin's robotics
vedder.se/2012/12/stm32f4-discovery-usb-host-and-mp3-player/
이 페이지 번역하기
2012. 12. 27. - STM32F4 Discovery USB host and MP3 player. Posted on ...... I modified the projectto work in the stm32 HAL libraries now. Secondly, has ...
STM32 MP3 Player with USB for fun | STMicroelectronics Community
5일 전 - About this project : STM32F103VET6 with VS chip, SDIO and USB interfacing for MP3 player Project infoType : my own PCB for ...
STM32F4 Discovery MP3 player working - with source code - ChibiOS ...
www.chibios.com › Board index › ChibiOS General › User Projects
이 페이지 번역하기
2012. 3. 15. - 댓글 9 - ‎작성자 8
All MP3 files in the cards root are then played in a loop in the order they are ... You can find the according eclipse project with all sources and a ...
STM32F4 Discovery MP3 Player - komplett mit Code - Mikrocontroller.net
2012. 3. 15. - 댓글 32 - ‎작성자 7
Leider. http://www.stm32circle.com/projects/project.php?id=82 Hier gibts ein .... Ziel sind erstmal zweiMP3 Player für die Kids in Holzkisten.
Ethernet MP3 player for STM32 | C Programming | Microcontroller
C Programming & Microcontroller Projects for $213. I ma looking for someone to develop a Ethernet based MP3 player for STM32 processor. The person ...
DF-Player mini (aka FN-M16P) extended library for STM32 - Arduino ...
www.stm32duino.com › ... › Working / ported libraries
이 페이지 번역하기
2015. 7. 6. - 댓글 9 - ‎작성자 4
Hello, as needed for my wooden-mp3-player project, I've completely rewritten the original library (now all commands are included!) You can get ...
게시물 10개
2015년 6월 22일
게시물 10개
2015년 5월 31일
게시물 10개
2015년 4월 27일
Embedded MP3 Player & Recorder | Open Electronics
2015. 1. 27. - Home > Open Source Projects > Embedded MP3 Player & Recorder ... the standard for various devices such as portable audio players, by ...
stm32 mp3 player project에 대한 이미지 검색결과
댓글 : 0
조회수 : 1,449
◎ STM32F 목록
PC버전
