AVR 따라하기 > 답변 : LED 잔상시계 (홀센서 리스) 시간 문자 표시 AVRstudio용
TODAY947 TOTAL611,532
BASIC4MCU | AVR 따라하기 | 2015년 강좌 | 답변 : LED 잔상시계 (홀센서 리스) 시간 문자 표시 AVRstudio용
작성자 master 작성일2018-10-16 19:42 조회151회 댓글0건
// DateTime : 2018-10-16 오후 7:46:21
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define data_1   PORTD|=0x80 //PD7
#define data_0   PORTD&=~0x80
#define latch_1  PORTD|=0x40 //PD6
#define latch_0  PORTD&=~0x40
#define clk_1    PORTD|=0x20 //PD5
#define clk_0    PORTD&=~0x20
//#define SW200  PINE.4
//#define WSH315 PINE.6
//#define sw2    PINF.1
//#define sw3    PINF.6
unsigned char font[11][6]={
  { 0x00,0x3E,0x51,0x49,0x45,0x3E},// 0
  { 0x00,0x00,0x42,0x7F,0x40,0x00},// 1
  { 0x00,0x42,0x61,0x51,0x49,0x46},// 2
  { 0x00,0x21,0x41,0x45,0x4B,0x31},// 3
  { 0x00,0x18,0x14,0x12,0x7F,0x10},// 4
  { 0x00,0x27,0x45,0x45,0x45,0x39},// 5
  { 0x00,0x3C,0x4A,0x49,0x49,0x30},// 6
  { 0x00,0x01,0x71,0x09,0x05,0x03},// 7
  { 0x00,0x36,0x49,0x49,0x49,0x36},// 8
  { 0x00,0x06,0x49,0x49,0x29,0x1E},// 9
  { 0x00,0x00,0x00,0x36,0x36,0x00//:
//0x00,0x42,0x7F,0x40,0x00,// 1
//  00000000
//  01000010
//  01111111
//  01000000
//  00000000
// HH: M M: SS<--8*5=40<--0~20count~40~59count
unsigned char angle=0,ss=0,mm=5,hh=7;
void clk_out()  { clk_1clk_0; }
void out_0()    { data_0clk_1clk_0; }
void out_1()    { data_1clk_1clk_0; }
void latch_out(){ latch_1latch_0; }
void clr_led(int n){
  int i;
  data_0;
  for(i=0i<ni++){ clk_out(); clk_out(); clk_out(); }
  latch_out();
void set_led(int n){
  int i;
  for(i=0i<ni++){ out_0(); clk_out(); out_1(); }
  latch_out();
char conv_m2l(unsigned char c){
  char r=0,i;
  for(i=0i<8i++){
    r>>=1;
    if(c&(0x80>>i))r|=0x80;
  return r;
ISR(TIMER1_COMPA_vect){
  unsigned char k,t;
  long s=0x01000000,m=0x01000000,h=0x01000000// 시계테두리 원
  if(angle==0){ s|=0x02000000OCR1A=19275; } // 12시 적색표시
  elseOCR1A=19298;
    if((angle%5)==0){ s|=0x02000000m|=0x02000000h|=0x02000000; } // 5마다 끝에 점을 표시
  if(angle==ss)s|=0x007fffff;
  if(angle==mm)m|=0x0007ffff;
  if(angle==(hh*5+mm/12))h|=0x00007fff;
  if((angle<24)||(angle>=36)){ // HH: MM: SS
    if(angle<6){ m=(m&0x03ffff00)|conv_m2l(font[mm%10][angle]); } // M 1
    else if(angle<12){ //:
      t=font[10][angle-6];
      h=(h&0x03ffff00)|tm=(m&0x03ffff00)|ts=(s&0x03ffff00)|t//백색
    else if(angle<18){ s=(s&0x03ffff00)|conv_m2l(font[ss/10][angle-12]); } // S 10
    else if(angle<24){ s=(s&0x03ffff00)|conv_m2l(font[ss%10][angle-18]); } // S 1
    else if(angle<42){ h=(h&0x03ffff00)|conv_m2l(font[hh/10][angle-36]); } // H 10
    else if(angle<48){ h=(h&0x03ffff00)|conv_m2l(font[hh%10][angle-42]); } // H 1
    else if(angle<54){ //:
      t=font[10][angle-48];
    elsem=(m&0x03ffff00)|conv_m2l(font[mm/10][angle-54]); } // M 10
  for(k=0k<26k++){
    if(h&(0x02000000>>k))out_1(); else out_0(); //B,hh
    if(m&(0x02000000>>k))out_1(); else out_0(); //G,mm
    if(s&(0x02000000>>k))out_1(); else out_0(); //R,ss
  latch_out();
  if(++angle>59)angle=0;
ISR(TIMER3_COMPA_vect){
  if(++ss>59){ ss=0;
    if(++mm>59){ mm=0if(++hh>11)hh=0; }
int main(void){
  DDRD=0xE0;
  //PORTF=0x42; // sw2,3 내부풀업저항
  //PORTE=0x10; // SW200 내부풀업저항
  clr_led(26);
  TCCR1B=0x09OCR1A=19298;     TIMSK=0x10//16000000/1/(1+19298)=829.0585.../60=0.0012061875...
  TCCR3B=0x0COCR3AH=62499>>8OCR3AL=62499&0xFFETIMSK=0x10//16000000/256/(1+62499)=1Hz=1sec
  SREG=0x80;
  while(1){ }
//14745600/64/(1+396)=580.35264483627204030226700251889Hz  /42=13.817920115149334292911119107593
//16000000/1/(1+19298)=829.05850044043732835898233069071Hz /60=13.817641674007288805983038844845
//16000000/1/(1+19298)/60=13.817641674007288805983038844845=0.07237125sec  clock
//14745600/64/(1+396)/42=13.817920115149334292911119107593=0.072369791666666666666666666666667sec   motor
//1.4583333333333333333333333333333us=23.333333333333333333333333333333 mcu-clock
버그가 있는지는 모르겠지만 AVRStudio용을 찾는 분이 있어서 변경했습니다.
조회수 151
AVR 따라하기HOME > AVR 따라하기 > 전체 목록
AVR 따라하기 목록
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 613
공지 사이트 이용 안내댓글[8] 이미지 master 17-10-29 7670
171 2015년 강좌 106 - [타이머인터럽트-19] 누른시간 & 뗀시간 & 더블클릭 체크 키트 17-08-23 1192
170 2015년 강좌 105 - [타이머인터럽트-18] 스위치 누르는 시간 & 스위치 누르지 않는 시간 체크댓글[3] 키트 17-08-23 1718
169 2015년 강좌 WS2812B [1개]- 테스트 - AVRstudio 키트 17-08-23 872
168 2015년 강좌 delay_us()보다 더 짧은 딜레이 함수 - 2 키트 17-08-23 1127
167 2015년 강좌 delay_us()보다 더 짧은 딜레이 함수 - 1 키트 17-08-23 1241
166 2015년 강좌 104 - [부저] 회로내장형 키트 17-08-23 1275
165 2015년 강좌 103 - [타이머인터럽트-17] 스위치 누르는 시간 체크 키트 17-08-23 1297
164 2015년 강좌 102 - [타이머인터럽트-16] 스위치 누를 때마다 1칸씩 좌우시프트 키트 17-08-23 1356
163 2015년 강좌 101 - [타이머인터럽트-15] 스위치 8개 SRAM에 읽어서 LED에 출력 키트 17-08-23 946
162 2015년 강좌 100 - [타이머인터럽트-14] 스위치 8개 읽어서 LED에 출력 (포트 다이렉트) 키트 17-08-23 1077
161 2015년 강좌 099 - [타이머인터럽트-13] 스위치 1개 SRMA에 읽어서 LED에 출력 키트 17-08-23 638
160 2015년 강좌 098 - [타이머인터럽트-12] 스위치 1개 읽어서 LED에 출력 키트 17-08-23 884
159 2015년 강좌 096 - [타이머 CTC 토글-3] 스위치 8개 피아노 키트 17-08-23 833
