하드웨어 > Glue Logic Family Selection
TODAY1,093 TOTAL2,933,379
BASIC4MCU | 하드웨어 | TTL,CMOS | Glue Logic Family Selection
작성자 키트 작성일2017-08-25 09:52 조회2,158회 댓글0건
Which Logic family do I need,
Why would I chose one logic family over another
http://www.google.com/" id="cse-search-box">http://cse.google.com/cse/intl/en/images/google_custom_search_watermark.gif); background-attachment: initial; background-size: initial; background-origin: initial; background-clip: initial; background-position: 0% 50%; background-repeat: no-repeat;" />
What are the different glue logic families
There are four basic types of logic chip families: Bi-Polar, CMOS, BICMOS, and ECL.
Bi-Polar devices are the normal TTL series of devices. These consist of the 74xx, 74S, 74LS, 74AS, 74ALS, 74F.... type devices.
CMOS devices which consist of the 4000 series of devices, and all the parts that are identified by the 'C' in the part number.
ECL devices consist of the 10K, 100K, or 10E [EcLinPS] series of devices.
BiCMOS devices consist of the ABT, BCT and others.
The graphic below lists most Glue Logic family types. Another view of the Glue Logic family list which may be more up-to-date
Different IC Families
All of the Glue Logic parts ever designed [shown above] are still being produced. However a great many types are not recommended for new designs. Note the color code legend in the right hand corner.
Bi-Polar devices use transistors as the inputs and outputs for their devices. The output transistors are operated in the saturated region and draw a large amount of current.
ECL devices also use transistors, but are operate in the linear region.
CMOS devices use MOSFETs
BiCMOS devices use bipolar and MOSFET circuits
Which glue logic family are in full production
All types of Glue Logic families are still in mass production, but a number of families may soon be obsolete. Below is a copy of a four year old graphic from a Texas Instruments; TI CD. Based on the graphic the 4000 series CMOS family, and many of the TTL [only] families are moving to obsolescence.
IC in Production
Given the list of possible glue logic families; the first step in selecting a logic family to use is based on weather or not you are producing a new design or working on a previous design. If you have a previous design and don't want to put additional engineering effort into the product then the selection of the same logic family used is called for. A new design would want to use devices which could be procured for years to come.
I have a new design, should I use one of the TTL glue logic families
Not really. There are very few reasons to use one of the TTL glue logic families. The TTL logic families are slower and consume large amounts of power [10x more than CMOS]. How ever, there may be that one case that you don't care about power consumption and can't deal with the higher switching speeds of the newer CMOS families. In most cases the same part number is used for either type.
Which glue logic family consumes the most power
Glue logic families will normally be selected by the speed at which they switch [operate at], or by the power they consume. How ever, in some cases, by selecting a device based on speed there is a price to pay, as increased current consumption. See the graph below to determine the speed vs power for the different logic families. For a better graphic see Logic Speed x Power Chart {This Web Site}. Low power consumption is the best reason to select a CMOS logic family over selecting a TTL logic family. While not switching (changing state) or in their Quiescent state CMOS devices have basically zero power consumption. TTL device on the other hand TTL logic families consume power regardless of what they do.
IC Speed vs Power
What are the Glue Logic Switching Levels
The voltage level a device [by family] switches at determines how well the logic device will handle any noise in the system. CMOS devices will output near 5 volts, while TTL devices will only output 2.4 volts given a 5 volt power supply. This is one of the best reasons why a CMOS logic family is better than a TTL logic family. Of course the best reason to use CMOS is the near zero power consumption.
IC Switching Levels
What are the Low Voltage Glue Logic Switching Levels
Low Voltage [LV] families switch at the same voltage levels as the normal TTL glue logic families
Detailed Digital Low Voltage Logic Threshold Level per Logic Family
What are the details of the different logic families
74AC: A high speed CMOS logic family with CMOS input switching levels and buffered CMOS outputs that can drive +/- 24mA of IOH and IOL.
74ACT: A high speed CMOS logic family with the same buffered CMOS outputs that can drive +/- 24mA of IOH and IOL. This family has a TTL-to-CMOS input buffer stage. The inputs will interface with TTL outputs operating at 5 volts with VOH = 2.4 volts and VOL = 0.4 volts. The devices have the same output buffered structures as the AC family.
74LCX: These devices have a mixed 3volt-to-5 volt capability for use with applications that have both 3 volt and a 5 volt devices which interface with one another.
74LVX: This family consists of low cost devices with 5 volt tolerant inputs. The devices can receive and output 3 volts or 5 volts.
74LVQ: This family consists of low cost devices designed for 3.3 volt only applications.
74LVT: This family has both high speed and a high output drive. These devices have a +64mA / -32mA output drive currents. The chips are 5 volt tolerant and are designed to be used with applications that have both 3v and 5v devices which interface with one another.
74ALCX: This devices are about the same as the LVT family with out the high drive currents.
74xx: The first TTL family developed. The 74xx family offers a wide variety of logic functions. There are a number of other TTL logic families which offer either higher speed or lower power.
74Lxx: This is the Low power version of the TTL family above. The value of the internal device resistors have been increased by a factor of 10x. The family offers 1/10 the power consumption as the previous family, but operates at 1/3 the speed.
74LSxx: devices adds a Schottky diode between the Base and Collector of the transistor. The Schottky diode prevents the transistor from going into full saturation. So the 74LS family operates at the same speed as the 74 family [10nS] with only 2mW of power dissipation compared to 10mW for 74xx or 1mW for the 74L family [at 33nS].
74Sxx: gains its speed using the same Schottky diode as the 74LS family, but the value of the internal device resistors have been decreased by half the original values of the 74xx family. So the speed increases [3nS] and the power consumption also increases [20mW].
74ALSxx: The advanced LS family offers near same high speed as the 74Sxx family at 4nS at a power dissipation of only 1mW. Except for the 74Sxx family, the 74ALS family outperforms the other three TTL families listed. If the design calls for a TTL family which needs to operate at 3nS, this is the family to use.
74ASxx: If the design needs to operate faster than 3nS then the 74AS family should be use. This family is twice as fast as the 74ALS family with a propagation delay of only 1.5nS. The price is a 7mW power dissipation.
What is the pricing for Glue Logic Family devices
The table shows the cost of a standard NAND gate for several different logic families. The prices were obtained on 3/23/03 for one piece qty.
Glue Logic Family Pricing
Function740074LS0074F0074AS0074C0074HC0074AHC0074AHCT0074AC0074ACTQ0074VHC00
NAND Gate0.880.480.470.801.490.560.520.520.420.920.50
NOR Gate0.960.53--0.92--0.420.520.520.56----
Additional considerations
Noise Margin Calculation
Noise Margin Output high = VOH [driving device] - VIH [receiving device]
Noise Margin Output low = VIL [receiving device] - VOL [driving device]
The higher the numbers the better, with negative numbers indicating interoperability . Use Minimum numbers for output High, and maximum numbers for Output Low.
Noise Margin
--VOHVIHVoltage MarginVILVOLVoltage Margin
TTL [5volt]2.4v2.0v400mV0.8v0.5v300mV
FCT [5volt]2.5v2.0v500mV0.8v0.5v300mV
BTL [5volt]2.1v1.62v480mV1.47v1.1v370mV
GTL [5volt]1.5v1.05v450mV0.95v0.55v400mV
CMOS [5volt]4.9v3.85v1050mV1.35v0.11340mV
LVTTL [3volt]2.4v2.0v400mV0.8v0.4v400mV
LVCMOS [3volt]2.8v2.0v800mV0.8v0.2v600mV
CMOS [2.5v]2.0v1.7v300mV0.7v0.4v300mV
CMOS [1.8v]1.35v1.1v250mV0.66v0.45v210mV
FanOut
The number of gates a device can drive is determined by the current it can source and sink. The lower of the two numbers indicates the possible fanout.
With the output high => IOH [driving device] / IIH [receiving device] = number of possible gates driven
With the output low => IOL [driving device] / IIL [receiving device] = number of possible gates driven.
To increase fan-out some families allow the devices output [in the same package] to be paralleled, or connected together. FanOut Definition
Slew Rate
Device Slew Rate
DeviceFALSABTACHCAHCAHCLVTALVCLVCLV
Propagation
Delay {nS}
462.75135.58.32.42.04.510
Voltage
Swing {V}
3334.84.84.833333
Slew
Rate {V/nS}
1.31.01.02.00.90.80.51.21.30.90.7
VCC = 5.0v
VCC = 3.3v
See the Device Slew Rate page for additional information and a better description
Back to the Logic Design page.
조회수 2,158
하드웨어HOME > 하드웨어 > 전체 목록
하드웨어 목록
현재글 TTL,CMOS Glue Logic Family Selection 이미지 키트 17-08-25 2159
328 TTL,CMOS Electronic Components 키트 17-08-25 1706
327 TTL,CMOS Logic IC Numbering 이미지 키트 17-08-25 1662
326 TTL,CMOS Logic IC Families 이미지 키트 17-08-25 1620
325 TTL,CMOS 100 IC Circuits 이미지 키트 17-08-25 3261
324 TTL,CMOS 74LVC Family 이미지 키트 17-08-25 1764
323 TTL,CMOS packages 이미지 키트 17-08-25 2571
322 TTL,CMOS Digital Clock 2 이미지 키트 17-08-25 3428
321 TTL,CMOS List of 7400 series★★★ 키트 17-08-25 1607
320 TTL,CMOS 디지털 IC TTL과 CMOS 이미지 키트 17-08-25 1610
319 TTL,CMOS 트랜지스터로배우는디지털회로Ⅱ 이미지 키트 17-08-25 2938
318 TTL,CMOS 7400 ~ 7438 TTL MOS 핀배치도 이미지 키트 17-08-25 2613
317 TTL,CMOS [펌] TTL 74 시리즈 목록 키트 17-08-25 2892
316 TTL,CMOS Level Shifting Made Easy with the 74LVC06A and 74LVC07A 키트 17-08-25 1513
315 TTL,CMOS Level Shifting CMOS Switching Levels 키트 17-08-25 1502
