하드웨어 > Circuit Collection
TODAY23,702 TOTAL9,411,321
BASIC4MCU | 하드웨어 | OPAMP | Circuit Collection
작성자 키트 작성일2017-08-25 10:59 조회2,780회 댓글0건
new
Quick Intro to the Basic Op Amp SPICE Model
Op Amp Max Slew Rate
Add 2nd and 3rd Poles - Improved Response
OP AMP APPLICATIONS
Function Generator - Part 1
Function Generator - Part 2
Programmable Gain Amplifier (PGA)
Op Amp Triangle Wave Generator
RC Low-Pass Filter with Op Amp Buffer (Single-Pole)
Sallen-Key Low-Pass Filter (Double-Pole)
Op Amp Comparator with Hysteresis
Op Amp PID Controller
Single-Supply AC Inverting Amplifier
H-Bridge Power Amp
Wien Bridge Oscillator
Current Source
Precision Half-Wave Rectifier
Op Amp Limiter
OP AMP BASICS
Inverting Amplifier
Non-Inverting Amplifier
Differential Amplifier
Integrator
Differentiator
Summing Amplifier
Create Waveforms with the Summing Amplifier
I-to-V (Transimpedance) Amplifier
I-to-V Amp with Offset
Input Offset Voltage
Input Offset Voltage Adjustment
Input Bias Current
OP AMP ADVANCED
Op Amp Bandwidth
Op Amp Max Slew Rate      new!
Op Amp with Gain Resistor Errors
Op Amp Feedback Analysis
Driving a Capacitive Load
Op Amp Differentiator - Open Loop Analysis
I-to-V Amp Stabilty
GENERAL CIRCUITS & MODELS
The 555 Timer
Analog Behavioral Modeling
Basic Digital Gates
DC Motor Model
Common Emitter Transistor Amplifier
Voltage Regulator w/ Series-Pass Transistor
Push-Pull Output Stage
Transistor Differential Amplifier
Voltage-Controlled Resistor
Potentiometer Model
Capacitor Model
The Miller Effect
SWITCH-MODE POWER SUPPLIES
SMPS Basics - The Buck Converter
SMPS Power Loss
Buck Converter - Voltage Mode Control
Buck Converter - AC Model
Buck Converter - Compensation
SPICE Power Meter
SWITCHED-CAPACITOR CIRCUITS
Switched-Capacitor Resistor
Switched-Capacitor Integrator
AUDIO AMPLIFIERS
Basic Audio Amplifier
Advanced Audio Amplifier
Diff Amp with Current Mirror
Output Stage
The Miller Integrator
Simplified Audio Amp Model
BJT Current Source
Active Load in Gain Stage
EXCEL (VBA) TOPICS
VBA Basics
Resistor Divider
Sine Wave Generator
Calculate Op_Amp_Gain_BW
ADC Function
Create Waveforms with the Fourier Series
Using the Circuit Collection
Here’s a growing source of circuits from today’s application notes, data sheets and textbooks. Use the collection anyway that works for you:
1. Download the SPICE file and off you go! Simulate, modify, expand it any way you like.
2. Read the circuit notes for a brief tour of how it works along with some hands-on design and analysis. Like a buffet table take as little or as much as you need.
3. Simulate your own circuits. Find a circuit similar to your interest. Then, modify it to fit your needs.
DESIGN TOPICS
Sampling Theory
Pulse Width Modulation
The PID Controller
Component Tolerances - Part I
Component Tolerances - Part II
Noise Analysis - Resistor Example
Power Supply Bypassing
Transmission Line Terminations
ADC INPUT DRIVERS
Single-Ended to Single-Ended
Differential to Single-Ended
Single-Ended to Differential
Differential to Differential
Fully Differential Amplifier
FILTERS
Audio Tone Controls
Multiple Feedback Band-pass Filter
Simple RC Low-Pass Filter
SENSORS & INSTRUMENTATION
Sensor Bridge
Sensor Bridge with Current Bias
Instrumentation Amp (3 Op Amp)
NTC Thermistor Model
Linearized NTC Thermistor
Thermistor Preamp
Thermocouple Model
Thermocouple Preamp
OP AMP MODELS
Op Amp Macro-Models
Basic Op Amp Model
Intermediate Op Amp Model
     Advanced Functions
2nd Gain Stage
Frequency Shaping Stages
Output Voltage Limiting Output Current Limiting
Supply Correction Current
Common-Mode Rejection
Op Amp Input Voff and Ibias
Add 2nd and 3rd Poles - Improved Response      new!
     Easy to Use Functions
Slew Rate Using LIMIT
Slew Rate Using TANH
Output Voltage Limiter
Output Current Limiter
SPICE TOPICS
A Brief History of SPICE
Why Simulate?
Limitations of SPICE!
THE SPICE ALGORITHM
Take a look inside the SPICE engine.   How it works...
Nodal Analysis
Non-Linear DC Analysis
Transient Analysis
Algorithm Overview
조회수 2,780
하드웨어HOME > 하드웨어 > 전체 목록
