BASIC4MCU | 하드웨어 | AUDIO | 트레머 - 위키
작성자 키트 작성일2017-08-25 14:09 조회1,335회 댓글0건본문
트레머
위키백과, 우리 모두의 백과사전.트레머(Tremor)는 Xiph.Org 재단이 개발한 고정 소수점 방식의 Vorbis 디코더이다. 따라서 부동 소수점 연산 기능이 없는 플랫폼에서도 사용 가능하다.
[숨기기] Xiph.Org 재단Ogg 프로젝트 기타 프로젝트 기타 주제
이 글은 소프트웨어에 관한 토막글입니다. 서로의 지식을 모아 알차게 문서를 완성해 갑시다. Tremor (software)
From Wikipedia, the free encyclopediaTremor by the Xiph.Org Foundation is a fixed-point version of the Vorbis decoder for those platforms without floating point operations.
It is a software library that decodes the Vorbis audio format. It is free software released under the New BSD license. Tremor uses fixed-point and movable-point arithmetic numeric representations in its implementation so that it can be used by small embedded devices, which typically do not have floating-point processors. Thus, Tremor enables small embedded devices to play audio files stored in the Vorbis format. Tremor was originally developed by Xiph.Org as a part of a contract for the Iomega HipZip,[citation needed] but was since opened up to encourage wider use of the Vorbis format. Almost all hardware devices that can play Vorbis, and many software implementations on embedded devices (such as mobile phones) use Tremor or some descendant.
Xiph.Org has expressed interest in modifying Tremor into a floating-point version, which would replace the current floating-point reference decoder, after the release of libogg2.[1]
References[edit]
External links[edit]
- Tremor at the Xiph.Org Foundation wiki
조회수 1,335등록된 댓글이 없습니다.
