BASIC4MCU | 하드웨어 | Electronic circuit simulation | Free Electronic Circuit Simulation Software / Circuit Simulators
작성자 키트 작성일2017-08-25 14:21 조회2,332회 댓글0건본문
Free and Open Source Circuit Simulators
You are here: thefreecountry.com (main page) > Free Engineering Software > Free Electronic Circuit Simulation Software / Circuit SimulatorsFree Electronic Circuit Simulation Software / Circuit Simulators
The free and/or open source electronic circuit simulation software on this page allow you to design, analyse and test a circuit virtually on a computer. They simulate the behaviour ("behavior" in US English) of an electronic device/circuit, and are often used because it is cheaper, quicker and often more practical to simulate a circuit than to physically build one. The programs below may provide either analogue ("analog") or digital simulation capabilities or both, have a schematic editor, a waveform viewer, support resistors, capacitors, diodes, etc. (Please read the individual description of each program for the actual features provided with different programs.)
Related Pages
- How to Start / Create Your Own Website: The Beginner's A-Z Guide
- Important Precautions to Take When Buying a Domain Name
- AutoDesk AutoCAD
- Free C/C++ Compilers and Cross-Compilers for Microcontrollers, PDA, Calculators, Embedded Systems and Other Devices
- Free Software Calculators: Scientific, Graphing, Statistical and Programmable Calculators
- Free Debugging Tools, Static Source Code Analysis Tools, Bug Trackers
- Free HTML Editors and WYSIWYG Web Editors
- Free Hard Disk Backup and Restore, Hard Disk Image and Cloning Utilities
- Free Partitioning Software - Copy, Create, Move, Resize, Convert, Undelete Partitions
- Free x86 / PC Emulators and Virtual Machines
- SPICE: Spice2, Spice3, KSPICE, JSPICE (Unix-based systems, MSDOS)
SPICE is probably one of the best known circuit simulators around. It supports non-linear DC and transient, and linear AC analyses. To quote from its documentation, your circuits may contain "resistors, capacitors, inductors, mutual inductors, independent voltage and current sources, four types of dependent sources, lossless and lossy transmission lines (two separate implementations), switches, uniform distributed RC lines, and the five most common semiconductor devices: diodes, BJTs, JFETs, MESFETs, and MOSFETs". The program is made up of two parts: the back-end simulator and a front-end user interface, called Nutmeg, that displays information for data analysis and plotting. Spice3 is released under the BSD licence ("license"). KSPICE, also available from the above page, is based on a version of SPICE3, has "improved transient analysis of lossy transmission lines". JSPICE is a simulator for superconductor and semiconductor circuits and incorporates the Josephson junction model. Note that all the programs are released in source code form. You will need a compiler to create the executables to run on your system. For Spice3, you will need a C compiler that can compile K&R C, not ANSI C. The GNU gcc apparently works. The program works on Unix-type systems and MSDOS.
- MacSpice (Mac OS, Mac OS X)
This is a Mac version of the SPICE circuit simulator (see elsewhere on this page for more information about SPICE). It works on both the Intel Macs as well as the older PowerPC Macs. You provide a list of components and the nodes these components connect to (called a "network list" or "netlist"), either using a text editor or a schematic capture application, run the command interpreter, and MacSpice builds a numerical model of the circuit and analyses it. The program appears to be free for non-commercial use only (that is, although it uses Spice3 which is open source, the overall Mac port seems to have a more restrictive licence).
- Ngspice (Linux, FreeBSD)
Ngspice is a mixed level, mixed signal circuit simulation engine, based on Spice, Cider and XSpice (see elsewhere on this page). It works on Linux and FreeBSD systems. The program is released under the GNU General Public License.
- Qucs: Quite Universal Circuit Simulator (Windows, Mac OS X, Linux, FreeBSD, Solaris, NetBSD)
Qucs is an integrated circuit simulator with a graphical user interface (GUI). You can basically set up the circuit using the GUI, and the backend program will take your network list and simulate the signal and noise behaviour of the circuit. The data output, the simulation results, can then be displayed. The program is released under the GNU General Public License in source code form, so you will need to compile it yourself before you can run it.
- Cider (Unix-based systems)
CIDER is a mixed-level circuit and device simulator. Devices are described with technology parameters or SPICE's compact models. It is released in source code form, and you will need a C compiler to create the executable before you can use it. It was tested under Ultrix, SunOS, AIX, and Unix, although the authors expect that the program should compile under other Unix-type systems. Note that Cider has been incorporated in Ngspice, listed elsewhere on this page, which runs on Linux.
- XSPICE (Unix-based systems)
XSPICE is an extension to SPICE (also listed on this Free Circuit Simulation Software page) that includes the ability to use code modelling ("modeling") as well as simulate of digital components through an embedded event driven algorithm. Its code model library includes functional blocks like multipliers, summers, integrators, magnetics models, limiters, S-domain transfer functions, digital gates, etc. The program is provided in source code form, and is released into the public domain.
Related Pages
- How to Register Your Own Domain Name
- Free Anonymous Surfing
- Free Antivirus Software and Free Online Virus Scans
- Free CD and DVD Burners and Copying Software
- Free DVD/CD Emulators, Free Virtual CD/DVD Drives
- Free Screen Video Recorders and Screen Capture Software
- Which Web Host Do You Recommend? (FAQ)
Can't Find What You're Looking For?
Newest Pages
- Can I Be My Own Domain Name Registrar So That I Can Avoid Paying Domain Renewal Fees Every Year?
- How to Make Images and Text into Links Using BlueGriffon
- How to Add a Feedback Form to Your Website with Dreamweaver CS6
- Why Is the Pound Symbol ("£") Displayed as a Question Mark or Rectangular Box On My Web Page?
- Which Web Hosting Package / Plan Should You Choose? How to Plan for the Traffic (Bandwidth) and Disk Space You Need
- Can I Recover My Files From a Website Discontinued a Long Time Ago?
- Free Start Menus for Windows 8
- How to Reserve a Domain Name. Do You Need a Web Host if You Want to Reserve a Domain for Future Use?
- What's the Difference Between a Content Management System (CMS), a Blog, a Web Editor and an Online Site Builder?
- How to Create Rounded Corners for Your Box Borders in CSS
Popular Pages
- How to Create/Make Your Own Website: The Beginner's A-Z Guide
- How to Register Your Own Domain Name - how to get your own domain name
- Dreamweaver Tutorial: How to Design a Website with Dreamweaver CS6
- How to Create a Bootable Windows XP Setup CD/DVD on a Preinstalled Windows System
- Free Data Recovery, File and Partition Recovery, Undelete and Unformat Software
- How to Create an Emergency Windows Rescue CD
- Free DVD Authoring and Creation Software
How to Link to This Page
http://www.example.com/">To link to this page from your website, simply cut and paste the following code to your web page.
It will appear on your page as:
Copyright ⓒ 2009-2015 by Christopher Heng. All rights reserved.
thesitewizard™, thefreecountry™ and HowToHaven™ are trademarks of Christopher Heng.
This page was last updated on 27 March 2015.
조회수 2,332등록된 댓글이 없습니다.
